MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
3 Pages V   1 2 3 >
> Do you tow with a Honda Odyssey?, Put 2nd (AND 3rd) row seats to use!
Frederick L. Sim...
post Nov 12 2005, 08:29 PM
Post #1
RV Type:Fiber Stream 1978 Tow with:Odyssey LX 2003
The "Back" bucket seats; a.k.a. the Second Row Seats are removeable...
This post has been edited by Frederick L. Simson: Nov 15 2005, 05:39 PM
Frederick & Robert The Odyssey and the "Eggstasy"
We have not succeeded in answering all of your problems. The answers we have found only serve to raise a whole set of new questions.
In some ways we feel we're as confused as ever, but we believe we're confused on a higher level and about more important things.
Go to the top of the page
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 08:31 PM
Post #2
First, fold the back flat...
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 08:33 PM
Post #3
Then, reach under the front outboard corner, pull the release, and rotate the whole seat forward...
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 08:35 PM
Post #4
Now that the seat is released from the floor anchors, it can be removed from the vehicle...
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 08:40 PM
Post #5
Here's where I studied the situation to make my mod. I wanted to re-create the floor anchors in a portable platform that I could use at my campsite. For this I thought and thought about what would be the simplest design to accomplish my goal. I came up with a minimalist frame...
This post has been edited by Frederick L. Simson: Nov 12 2005, 09:35 PM
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:00 PM
Post #6
When I was camping at Cibbets Flats last month, Gina pointed out some abandoned lumber, that someone wanted to burn, but campfires were restricted that weekend. I found 4 identical pieces, 2" x 2 3/4" x 23" long.
Then I studied the floor anchors in the van. They are made out of rods with different diameters. This is so you do not install them in the wrong positions; preserving proper seat belt function. I discovered:
The rear anchor rods on both seats are the same. 3/8" diameter.
The forward anchor rods on the Passenger side seat are 1/2" diameter.
The forward anchor rods on the Driver's side seat are 1/4" diameter.
The forward-to-rear rod spacing on the Passenger side seat is 11 3/8" centerline-to-centerline.
The forward-to-rear rod spacing on the Driver's side seat is 11 5/8" centerline-to-centerline.
I went to Home Depot and bought galvanized steel rods:
2 each at 3/8" diameter
1 each at 1/2" diameter
1 each at 1/4" diameter
They are sold in 36" lengths. I cut them down to 23".
Then I drilled appropriate sized holes, 1 inch deep, at appropriate spacing that was different for each pair of wood blocks.
This got me 4 blocks and 4 rods:
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:01 PM
Post #7
Assemble the rods into the holes in the wood...
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:03 PM
Post #8
...and place the assembled frames on your patio mat next to your trailer...
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:07 PM
Post #9
Now bring the seat you removed from the Odyssey Minivan, and place the front facing frame groove over the forward rod; in the same position you removed it from the Van...
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:10 PM
Post #10
In the same manner that the seats are installed inside the Van, push the rear latches down over the rear rods.
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:12 PM
Post #11
...and bring your seat-back (but no tray table) into an upright position, rotating the armrests down to their useable position.
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:15 PM
Post #12
Repeat the process for the other seat, and viola! A pair of comfortable chairs at your campsite. ...complete with built-in cupholders!
+Quote Post
Frederick L. Sim...
post Nov 12 2005, 09:18 PM
Post #13
They even recline! The seat's forward/back adjustment is fully functional; ensuring that you won't tip over as you recline back!
This post has been edited by Frederick L. Simson: Nov 12 2005, 09:19 PM
+Quote Post
Gina D.
post Nov 12 2005, 09:32 PM
Post #14
RV Type:Burro ~ 17 ft Wide Body, '99, 06 RED Jeep Liberty
Those are great. I wish that would work for Element seats.
Go to your Room! Don't MAKE me get my flying Monkeys, Mr.!
Day 1 of fulltiming: 3-12-2009..It starts with just getting rid of one bag of stuff.. the rest is easy
+Quote Post
Sharon Herman
post Nov 12 2005, 10:09 PM
Post #15
RV Type:1979 13' Trillium
That is definately the coolest thing I have seen!! 53.gif You are so McGeyver. 94.gif My seats come out in my Eurovan. Hmmmm........... ask.gif
+Quote Post
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 20th November 2009 - 10:10 PM
