MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
3 Pages V  < 1 2 3 >
> Do you tow with a Honda Odyssey?, Put 2nd (AND 3rd) row seats to use!
post Nov 13 2005, 07:37 AM
Post #16
RV Type:1988 16' Scamp Deluxe
Careful Sharon....we "know" you have a problem with leaving chairs behind...don't want to pull out of a campsite with only half of your tugs seating l31.gif
A Hardboiled Egg
Go to the top of the page
+Quote Post
Jeanne and Steve
post Nov 13 2005, 07:48 AM
Post #17
RV Type:Casita 16' 1984; U-Haul CT13 1985
+Quote Post
Brian B-P
post Nov 13 2005, 02:04 PM
Post #18
RV Type:Boler B1700RGH - 1979
Great idea, nicely executed, and a wonderful explanation. Thanks, Frederick.
I have considered doing the same thing with our Sienna seats, but instead for the moment we are just leaving them at home to save weight and free up cargo space in the van. I was going to use bolts as the mounting rods, between pairs of pieces of wood or even metal, since I don't see unthreaded rod in our Home Depot. Just one question: are the rods really just set in the holes in the wood without any kind of fastener? I would consider using set screws (through the wood at right angles to the rods) to pin the rods in place.
As with the Odyssey, for the Sienna this in an option only for the second row seats, as the third row folds into the floor and is not readily removable.
This post has been edited by Brian B-P: Nov 14 2005, 01:37 AM
Share, learn, and consider all information - about our trailers or anything else - thoughtfully, and with the application of your own good judgement.
+Quote Post
Sharon Herman
post Nov 13 2005, 05:19 PM
Post #19
RV Type:1979 13' Trillium
Nice Donna....I forgot about that. 15.gif Boy would my husband be furious if I did that!! 80.gif
+Quote Post
Frederick L. Sim...
post Nov 13 2005, 06:18 PM
Post #20
RV Type:Fiber Stream 1978 Tow with:Odyssey LX 2003
QUOTE (Brian B-P @ Nov 13 2005, 02:04 PM)
(1) I don't see unthreaded rod in our Home Depot.
(2) Just one question: are the rods really just set in the holes in the wood without any kind of fastener?
(1) L 7.gif 7.gif K at the end of the Fastener aisle, toward the center of the building. 94.gif
(2) I used the exact same size hole as the rod diameter. I have to twist each rod as I insert it into it's hole, in order for it to "seat" in the first block. The second block takes some pressure to seat, because I am just pushing it into place over 2 rods. I know that if this were all metal construction, the base blocks would have to be drilled out 1/32" larger than the diameter of the rod, or else it would not even fit through the hole.
Frederick & Robert The Odyssey and the "Eggstasy"
We have not succeeded in answering all of your problems. The answers we have found only serve to raise a whole set of new questions.
In some ways we feel we're as confused as ever, but we believe we're confused on a higher level and about more important things.
+Quote Post
Frederick L. Sim...
post Nov 13 2005, 06:22 PM
Post #21
Robert wants me to engineer a base frame that will turn the chair into a rocker! shg.gif confuse.gif Geez, talk about a challenge! 29.gif
+Quote Post
Lizbeth
post Nov 13 2005, 07:08 PM
Post #22
RV Type:1979 13ft Boler and 1987 Bigfoot 5th wheel
Good job on the van seat mod, very inventive!
Life should not be measured by how many breaths we take, but in moments that take our breath away.
+Quote Post
Kurt & Ann K.
post Nov 13 2005, 07:51 PM
Post #23
RV Type:2000 Casita 19'(formerly 17') FD "Nuestra Casita" pulled by 2000 4WD V8 Tundra
Frederick,
Sounds like a trip to the Goodwill or Salvation Army for a couple of rockers with bad upholstery is in order. Salvaged parts should correct the situation just fine. What a neat Christmas present!
Kurt & Ann K.
Perspective point to ponder: prayer prior to project progress, possibly prevents painful profanity! Kurt K.!
+Quote Post
Brian B-P
post Nov 14 2005, 01:35 AM
Post #24
Frederick - That's the metal stock rack all right, with plates and angles and boxes and threaded rods, but I didn't see any plain rod - I'll have to check again. Isn't it scary that stores in different cities - even different countries - are so alike that the layout of one can be used as instructions for the other?
Kurt - Frederick's explanation was quite clear - I just wanted to confirm that the rods were friction-fit. It can't be that Toyotas need more complex mechanical solutions - I know because I've worked on Hondas!
As for the rocker idea: why not just do the same thing again, but with wider wooden stock with a suitable curve cut on the bottom, and you have a traditional style of rocker. For the fancy mechanical rocker with a fixed base and salvaged rocking mechanism, there may not be enough room under the seat - but it couldn't hurt to try, and would work better in less-than-flat campsite conditions. I suppose engaging and disengaging the seats from rocking bases might be tough, but with the traditional design a couple of chocks would hold things steady.
+Quote Post
Frederick L. Sim...
post Nov 14 2005, 06:36 PM
Post #25
The base blocks are 2" x 2 3/4" stock and I drilled the holes in the longer side, 3/4" from one edge and 2" from the other edge. That 2" rise gives the chair the same rise off the ground as it has off the floor inside the van. I hope that explanation makes sense. confuse.gif
I was discussing this project last May at Cambria. Mr. LeBreaux (of Geezer Egg fame) suggested that I use a single leaf spring on each side as part of a rocker base. I bought a pair off eBay to attempt this; but could not figure out how to fasten the springs to the rods. (Spring steel being a poor candadate for welding.) 15.gif I don't know if I can thread (tap) out the hole (normally used to mount an axle) for an eye bolt, would I be able to catch enough threads for it to hold? Is the spring thich enough? I'd have to grind the tip of the eye bolt flush with the bottom surface. ask.gif Just where to make my mounting points for proper balance; so the chair doesn't flip over backwards. ask.gif I observe that many rocker rails mount close to the front legs of the chair with a long "tail" extending beyond the back legs of the chair... confuse.gif
Thinking of all those considerations just made my head hurt... 29.gif so I decided to make my first prototype a regular chair. shg.gif
+Quote Post
Brian B-P
post Nov 14 2005, 06:58 PM
Post #26
QUOTE (Frederick L. Simson @ Nov 14 2005, 07:36 PM)
...Just where to make my mounting points for proper balance; so the chair doesn't flip over backwards. ask.gif I observe that many rocker rails mount close to the front legs of the chair with a long "tail" extending beyond the back legs of the chair... confuse.gif ...
The centre of the mass of the chair occupant is very close to the hips, meaning way back in the seat, so the centre of the rocker runners is approximately under that - thus the long "tails". That way, rocking is moving back and forth like an upside down pendulum, centred around a balance point. That's also why you can easily push back and balance on the rear legs of a normal chair, but not the front legs.
+Quote Post
Roger H
post Nov 15 2005, 03:58 AM
Post #27
RV Type:Y2K6 Bigfoot 25' 25B25RQ
Frederick... are you SURE you live in San Diego and not the Ozarks? "Why I ain't NEVER seen no better couch fer porch settin' before!" 94.gif l31.gif
Roger
"I was gratified to be able to answer promptly, and I did. I said I didn't know."
Mark Twain- Life on the Mississippi
+Quote Post
Kurt & Ann K.
post Nov 15 2005, 08:15 AM
Post #28
Here we go....
Wasn't there a post about a year ago where someone actually had a portable porch? I think there were even pictures, It may have been a factory made product. Yep, porches and rockers, folks walking by and stopping to "chew the fat". Iced tea, cold beer (or mint juleps, or wine) and a long summer's evening. Now we're talking about Momma having to follow us down the road towing another trailer to tote all this stuff. 33.gif
C'mon, Help paint this word picture. Remember starting a story where each person in the group contributed their part?
Mike, if this idea "takes", I'm sure it'll have to be moved.
Frederick, it's a shame that third row can't be used for visitors but many FGRV folks are used to carrying there own chairs or stools as they walk. You've inspired a lot of thought, and possibly some other ingenious designs. If the rods loosen in the wood over time, you might add a longer third "rod" of all-thread with a nut on each side of the wood pieces.
Kurt & Ann K.
This post has been edited by Kurt & Ann K.: Nov 15 2005, 08:25 AM
+Quote Post
Frederick L. Sim...
post Mar 18 2007, 06:55 PM
Post #29
QUOTE (Kurt & Ann K. @ Nov 15 2005, 09:15 AM) *
Frederick, it's a shame that third row can't be used for visitors...
Kurt & Ann K.
ohmy.gif 94.gif Yes, It can! Thank you for reminding me about that! The 3rd row seat is reversable, and with the 2nd row seats outside, makes for a great tailgating set. 53.gif
+Quote Post
Douglas Knudson
post May 30 2009, 07:42 AM
Post #30
RV Type:1985 16' Casita
QUOTE (Roger H @ Nov 15 2005, 04:58 AM) *
Roger
These folks brought the porch along!
+Quote Post
3 Pages V  < 1 2 3 >
RSS Lo-Fi Version Time is now: 20th November 2009 - 08:31 PM
