My Easily Removeable Window Air Conditioner, in Fiber Stream sliding window |
Jul 1 2007, 05:15 PM
RV Type:Fiber Stream 16ft (c) 1982
How much does the window unit weigh, Frederick? I have a similarly sized Haier unit. It weighs 40 pounds which I'm wondering about. It seems a bit heavy for the window to me. Problem is, I haven't found a unit that is lighter
Benita / Sister Scribe
Jul 1 2007, 07:33 PM
RV Type:1976 Trillian 13'
Excellent pictorial tutorial I did something like that last fall, well almost, I got started then it snowed, and the next thing it's now, but axles and frame are on the top of the list now. FRED............................................... QUOTE (Frederick L. Simson @ Jun 16 2006, 09:31 PM)  Everybody get in line behind Robert! He says, "Enuf trailer projects! When am I going to get started on the House list?
Jul 1 2007, 08:15 PM
RV Type:Fiber Stream 1978 Tow with:Odyssey LX 2003
QUOTE (Benita @ Jul 1 2007, 06:15 PM)  How much does the window unit weigh, Frederick? I have a similarly sized Haier unit. It weighs 40 pounds which I'm wondering about. It seems a bit heavy for the window to me. Problem is, I haven't found a unit that is lighter  I guess that no more than 40 pounds might be about right.  It weighs about the same as the Microwave oven, and that I actually weighed; it is 29 pounds. I'll have to weigh it when I go to work tomorrow.
Frederick & Robert The Odyssey and the "Eggstasy" We have not succeeded in answering all of your problems. The answers we have found only serve to raise a whole set of new questions. In some ways we feel we're as confused as ever, but we believe we're confused on a higher level and about more important things.
Jul 2 2007, 04:53 AM
RV Type:1989 Casita Spirit Deluxe
Fred,
Now you know why I put a drain hole (with a plug) in mine. Although my A/C is a permanent mount, draining all the water does keep it from splashing in during travel.
If I recall, you have a drain on yours, it's just not on the bottom. Try cranking your trailer down in the front before you remove it. The remaining water should empty out.
Suz 1989 Spirit Deluxe
Aug 5 2007, 04:48 PM
RV Type:74 13 ft Boler 79 17 ft Boler
Has anyone tried to simply put a 5000 BTU LG or similar unit on a collapsible stand outside, behind the trailer and just duct in the cold air thru about a 6" flex duct into a round hole under the dinette area? ....possibly leaving a vent window open a bit so air circulates....thus a smaller hole with a cover could work....I would think that some of these new units, being priced under a $100 and possibly being fairly light would be worth a try.....the only nuissance would adjusting the temp.....  ...Benny
Aug 6 2007, 03:54 AM
RV Type:1988 16' Scamp Deluxe
QUOTE (Benny K @ Aug 5 2007, 05:48 PM)  Has anyone tried to simply put a 5000 BTU LG or similar unit on a collapsible stand outside,  See CD Smith's and Tom Trostel's posts in this link: Front (or rear) window AC?, it will lead to pics and further discussion.
Donna D. A Hardboiled Egg 1988 16' Scamp Deluxe
May 25 2009, 08:30 AM
Update:
This summer (July 2009) we will be traveling across the mid-west after attending the Oregon Gathering. After spending time with Robert's brother and sister-in-law in Portland, we will go from there to Denver, and then across Kansas to St. Louis, MO.
Much of this leg of the trip will be to make time; we leave Portland Monday morning, July 20 and hope to arrive in St. Louis by Friday afternoon, July 25. If we average 450 miles per day, we will make it on schedule. But the thought of the time and effort involved in removing the AC each morning and re-installing it each evening just so we can get a comfortable night's sleep tires me out even now. I want to be able to leave the Air Conditioner in the window and leave the Bed configured as a bed.
After some study of my design, I just drilled one hole in the top of each piece of angle-aluminum and a corresponding hole in the inside lip of the window frame. Then I tapped (Threaded) the holes for the screws I used to fasten the angle mounts to the window frame. A couple of strips of Duct tape to seal window gaps temporarily finish the job.
The rock guard does not close completely over the Air Conditioner, so I have removed it and saved the parts. The Air Conditioner sits too low on the window frame to fit within the bulge of the unique Fiber Stream rock guard. I tested it this past weekend on my trip home from Palm Springs to San Diego, and it rides in the window just fine. I may have to consider rain while driving during the July trip and possibly caulk the edges around the unit, but I'll cross that bridge when I come to it.
For now, I just wanted to allow the unit to stay in the window while traveling but still keep the easily removable aspect of the design.
May 25 2009, 10:21 AM
RV Type:82 Fiberstream-3rd time's a charm.
Fred
I think you know this already but you will want that AC unit when you are here! The end of July in STL does not make for comfortable sleeping without the AC(understatement!). I also have a portable you are welcome to use should some odd fate befall you on the journey. And of course you are welcome to use my facilities if they can help at all.
Do you know what site you are in yet? I am going to the park this week and I thought I would do Recon for you?
Ed
May 25 2009, 06:11 PM
QUOTE (Ed Harris @ May 25 2009, 11:21 AM)  Do you know what site you are in yet? I am going to the park this week and I thought I would do Recon for you? We have reservations in Babler State Park Campground for site #11.I understand that there is electric service at the site, but no "city water" connection; so while I can run the Air Conditioner, TV/VCR, and Microwave, I must fill the fresh water tank and use my water pump. The website states: Site Type = Electric Includes parking pad, grill, table, lantern post, and electric supply Maximum Amps = 50 Site has 20, 30, and 50 amp serviceThe Air Conditioner worked well for us this past weekend at Palm Springs. While I don't think we'll need it in Oregon, I know we'll need it pretty much continuously after leaving Denver. I'm studying my installation to see if I can raise it to be more centered vertically. If I can achieve that, then I believe the unique Fiber Stream rock guard will close over it while it is mounted in the window.
May 25 2009, 08:50 PM
RV Type:1976 13' Scamp, 2006 Honda Element
Here's a link to photos of the window install I did (posted here some time ago). http://www.hustonfamily.com/gallery2/main....2_itemId=168650The basic idea is one board attached to the AC unit via angle iron... cut to fit into the outside window channel (although my design of window, which seems somewhat rare on the Scamp is probably more conducive to this working well)... a second board fitting inside the inside window channel... and both boards attached together via carriage bolts... it fits very snug and I've logged many miles with it installed... although if need be I can quickly pull it out, loosening no tool knobs. I personally think window installation is the only way to go... I haven't seen a closet installation which cools nearly as well.
This post has been edited by HustonFamily: May 25 2009, 08:52 PM
May 26 2009, 07:09 AM
RV Type:1976 Trillium 1300
What is up with the 4:20 label on the black TV looking stand in your first pic? Should I dare to ask?
May 26 2009, 08:19 AM
QUOTE (Frederick L. Simson @ May 25 2009, 07:11 PM)  I believe the unique Fiber Stream rock guard will close over it while it is mounted in the window.  I just checked the fit, and it won't
May 26 2009, 08:32 AM
QUOTE (Steve Foster @ May 26 2009, 08:09 AM)  What is up with the 4:20 label on the black TV looking stand in your first pic? Should I dare to ask?  The meaning of 4:20
Number of downloads: 61That is just an "inside" joke of mine: Television has the same effect.
