MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
2 Pages V   1 2 >
> Front (or rear) window AC?
Bobbie Mayer
post May 29 2007, 06:01 PM
Post #1
RV Type:TrailsWest Campster 1970
Who has done this and can show me pictures? I don't have a sliding front window; it is fixed.
Bobbie
This post has been edited by Bobbie Mayer: May 30 2007, 10:31 AM
Go to the top of the page
+Quote Post
Frederick L. Sim...
post May 29 2007, 09:03 PM
Post #2
RV Type:Fiber Stream 1978 Tow with:Odyssey LX 2003
My Easily Removeable Air Conditioner
Since your trailer has the entrance in the back, over the bumper, you might see if someone with a classic Casita has a rear window mounted AC. That would more closely approximate your situation.
confuse.gif I seem to remember that Suz posted her instalation, but it was pre-hack. ask.gif
Frederick & Robert The Odyssey and the "Eggstasy"
We have not succeeded in answering all of your problems. The answers we have found only serve to raise a whole set of new questions.
In some ways we feel we're as confused as ever, but we believe we're confused on a higher level and about more important things.
+Quote Post
Bobbie Mayer
post May 30 2007, 10:35 AM
Post #3
Yes, that would be helpful, too. Front window seems a little easier, possibly, since the trailer frame is there to help support the AC if I do it, but essentially it should be the same job. My front window is pretty small- maybe twice the width of an AC.
I haven't really looked at other alternatives yet, and I'm not sure I need one, just thinking ahead.
Bobbie
+Quote Post
CD Smith
post May 30 2007, 11:11 AM
Post #4
RV Type:Casita 17 SD
I liked the one that showed up at 2007 Bluebonnet in Bandera.
It was a room air conditioner that sat on the ground, street side rear, and the cold air was ducted to inside the Scamp with clothes drier flexible hose.
Quite portable and so I was told quite effieicent.
Charlie and Joyce Smith, Grand Prairie, TX
RV: 1999 Casita 17 SD - "The Little Egg"
TV: 2004 Escalade 5.3L V8 2WD 3.73 (ECM Modified)
4L60E Transmission (Shift Modified for Manual Control)
Brake Control: Dexter Predator DX-2
Now: Home
Next: Home
+Quote Post
Paul and Libby S...
post May 30 2007, 12:24 PM
Post #5
RV Type:2001 4wd 6cyl silverado 94 5th scamp
Hi.. seems to me that if you were driving in any type of rain the a/c in the front window would be a water magnet, Paul Orlando fl
+Quote Post
Raymond Brodeur
post May 30 2007, 12:56 PM
Post #6
RV Type:Boler 17ft 1977 (Coquille (Shell)) and 04 Explorer Sport Trac (p'tit Beu (Little Bull))
I know this is not the way you intend to install your air conditioner, but here is the way I did it. inside and outside
This post has been edited by Raymond Brodeur: Aug 22 2009, 08:37 AM
+Quote Post
Bobbie Mayer
post May 30 2007, 02:54 PM
Post #7
QUOTE (Raymond Brodeur @ May 30 2007, 01:56 PM) *
Well, that is a possibility, or something like that. If it is in the front window it would obviously need a cover during travel. I kind of like the outside idea; does that really work? Would it require a portable AC or could a room AC work?
Bobbie
+Quote Post
Raymond Brodeur
post May 30 2007, 04:20 PM
Post #8
QUOTE (Bobbie Mayer @ May 30 2007, 06:54 PM) *
Bobbie
I used a room AC. I took out the metalic cover of the unit, built a duct with 1/4" plywood from upper screen alongside the wall to bring outside air the open top of the unit, and I built an other duct to exhaust hot air to the lower screen.
And that works very well.
(ooops ! I think your question was addressed to CD Smith...)
+Quote Post
Bobbie Mayer
post May 30 2007, 06:56 PM
Post #9
I like your solution, too, though it may be more carpentry than I want to do.
Bobbie
+Quote Post
Tom Trostel
post May 30 2007, 07:23 PM
Post #10
RV Type:1973 Compact Jr.
Bobby,
My Compact has a 5000 BTU window air conditioner mounted in the front window. It was installed by a previous owner. It is supported from below by two steel L brackets bolted through the fiberglass shell and from above by two aluminum straps that are screwed to the window frame. When traveling I cover the outside with a simple vinyl piece. Works great and does not leak.
Tom Trostel
http://albums.photo.epson.com/j/ViewPhoto?...&p=70959859
"Size matters not ..... Look at me. Judge me by size, do you?" Yoda
+Quote Post
CD Smith
post May 30 2007, 07:24 PM
Post #11
QUOTE (Bobbie Mayer @ May 30 2007, 05:54 PM) *
Bobbie
The one I saw at 2007 Bluebonnet was just a standard 115 Vac 'window mount' a/c unit. It was set on a platform on the ground and surrounded by a small white picket fence. It was transported in the bed of the TV. It appeared to be easy to set up/take down. I did not get close enough to see how the duck went from the a/c to the Scamp.
Now: Home
Next: Home
+Quote Post
Tom Trostel
post May 30 2007, 07:33 PM
Post #12
Here is a link to a photo (taken by Lindy) of the 13' Scamp AC. This is the one that Charlie is referring to.
http://good-times.webshots.com/photo/28651...054322218bGTZur
+Quote Post
CD Smith
post May 31 2007, 07:19 AM
Post #13
Thanks Tom, that's the one I was posting about.
Now: Home
Next: Home
+Quote Post
Bobbie Mayer
post May 31 2007, 09:27 AM
Post #14
Thanks, Tom, I'd like to see closer up the mounting hardware, when you get a chance. I'm not going to do anything for awhile, though, first I'll see how much I need AC.
The non-mounted unit has advantages, too; especially the ability to leave it behind when AC is not needed.
Bobbie
+Quote Post
lwehrly
post May 31 2007, 01:12 PM
Post #15
RV Type:boler honey
I have been thinking on this ac thing for a while, and I do like the idea of a non-mounted unit. Just where did the duct enter the trailer? Its obvious that you would lose some of your coolness from the duct, since it isn't insulated. But then, with it outside, none of the heat of the unit comes into the trailer. Is that a wash?
Linda W.
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 20th November 2009 - 11:29 PM
