MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
4 Pages V  < 1 2 3 4 >
> Converting dinette into a "U" with more accessible storage.
Joe Z
post Oct 6 2008, 06:23 AM
Post #31
RV Type:16' Casita SD
Peter...
You do first class work on every project you take on (like many others on this forum)... always look forward to your posts. goodposting.gif
Joe
Joe & Linda
07' Ram 4 Door Hemi
94' SD 16'
Go to the top of the page
+Quote Post
peterh
post Oct 6 2008, 08:55 PM
Post #32
RV Type:2005 Scamp 5th Wheel
It's a conversion that works very well for us, April. We spent two weeks straight camping in the trailer and found it was comfortable and functional. We'll experiment with different table shapes for a while before we settle on a final size shape and size, though.
One thing I do need to warn you about is I would NOT move the fresh water tank to the back of your conventionally towed trailer! The 5th wheel has enough tongue weight on it that 140 pounds of water (a full 20 gallon tank) at the back of the trailer won't cause instability when we pull it. That's not true with your bumper-hitched trailer, but you can still turn the back bench into a space to tuck lightweight stuff, like clothes and such.
The table width was 30" bench-to-bench, and it's still 30" bench-to-bench. The 24" depth when added to the back bench seat isn't quite the same length as the original table. We made the table a tad shorter to help make it easier to slide in and out of the dinette. We'll probably make another, even shorter table because it's still a little bit of a chore getting up and down.
If you look at my earlier posts there's one where I show the "filler" piece that tucks over the "nose" of the table to fill in the gap when we want to turn the dinette into a sleeping spot.
The bench depth . . . I wish I could remember.
I think it's 16 inches, but the depth was more or less dictated by the size of water tank's 12"x32" footprint. The back wall of the Scamp arches away from the tank from there by a few inches and the tank cover/bench extends a bit further forward, so 16" is probably about right. I'll try to remember to get the measurement this weekend when I go visit my trailer.
As long as you don't go overboard (like I did) this makes a good "starter" project for your trailer, April. Just concentrate on making the back bench with storage underneath and a new, smaller table with a podium leg. Don't remove and cut holes in the benches, re-plumbing everything, cut hatch-holes in the sides of the trailer . . . that would be too much for a first mod, and you'd loose use of your trailer while you made the changes.
Trailer mods are evolving projects. Do one little corner at a time, changing the way just one part of your trailer works while leaving the rest alone. That way you don't get bogged down and locked out of camping in your trailer for months and months at a time. That, and by leaving the existing bench structures intact you can play with the dimensions of your new "U" dinette and table and still go back to the original configuration if you don't like it.
Good luck!
--Peter
This post has been edited by peterh: Oct 6 2008, 08:58 PM
+Quote Post
April Wilcox
post Oct 13 2008, 07:21 PM
Post #33
RV Type:13' scamp 1983
We have decided to go for it! And using your design as our model, I came up with this fabricated photoshop image of what it SHOULD look like when we are done. It's kind of rough, I used snippits of photos I have taken recently. I really like your design, and used parts of your photo to fabricate ours, thanks for the inspriation!!! Thanx.gif
also, we don't have to worry about moving any water tanks, we don't have one. They put a 2 gallon jug under the sink, so we have upgraded to a 6 gallon for now, and will figure out the water system after we have started using it. I'm glad to hear it is a functional upgrade. I like the idea that both of us will have a "lounge" spot when the table is up. I have been trying to think of some way to add a leaf to the table, maybe on a hinge or slide out or something... we will see how that works out.
This post has been edited by April Wilcox: Oct 14 2008, 11:11 AM
+Quote Post
peterh
post Oct 14 2008, 09:26 PM
Post #34
QUOTE (April Wilcox @ Oct 13 2008, 08:21 PM) *
Go for it, April! Have fun and keep it simple!
--Peter
+Quote Post
April Wilcox
post Oct 15 2008, 08:04 AM
Post #35
This is what i got done yesterday. I still have some finishing work to do, sanding, triming and painting. We are still trying to figure the painting part out so they might stay rough for a little while. It amazes me how quickly we can put things together. I will post more detailed photos here:
http://www.fiberglassrv.com/board/index.php?showtopic=32043
+Quote Post
Larry & Carrie
post Oct 15 2008, 02:17 PM
Post #36
RV Type:13' Scamp (a white one) '83, 72 Compact JR (project)
QUOTE (peterh @ Oct 6 2008, 09:55 PM) *
Good luck!
--Peter
Peter---
Thought you might be interested in the table mod I have in the Compact. I'm not the one that thought of it tho. I was at the local auto wrecking yard pulling things out of a derelict camper and scored this. It has a wooden plate attached to the bottom and two simple rabbet cuts to make it slide. Quite handy in the Compact, allows us to sit down then slide the 24" square table in front of us. It slides 7", which really helps one to sit down. We have two table plugs in the floor, use each when different bed configurations are used. Larry
+Quote Post
Dan Passmore
post Oct 15 2008, 02:23 PM
Post #37
RV Type:1988 16' SCAMP
QUOTE (Larry & Carrie @ Oct 15 2008, 05:17 PM) *
Peter---
Larry,
That mod has got to be what I'd call "The Cat's A**" and I would expect that it will be a frequent flyer for the people doing mods in the future. 94.gif
The rebuild of our 88-16' Scamp
+Quote Post
April Wilcox
post Oct 15 2008, 03:10 PM
Post #38
Very cool Lary! We still have not built the table, so I have been trying to figure out some kind of hinged fold up leaf, or slide out that would extend the table a few more inches when we need it, that may be another solution. 54.gif
+Quote Post
peterh
post Oct 20 2008, 01:03 PM
Post #39
QUOTE (Larry & Carrie @ Oct 15 2008, 03:17 PM) *
. . . the 24" square table . . . slides 7", which really helps one to sit down.
I LIKE IT! I'll make one as soon as my schedule gets a little less crazy.
--Peter
+Quote Post
Alf S.
post Oct 20 2008, 05:43 PM
Post #40
RV Type:'07 Escape 5.0 & '02 GMC Tug
QUOTE (peterh @ Oct 20 2008, 05:03 PM) *
--Peter
Hi: Peter... Our Escape Hatch has a sliding table for the U Dinette. Best thing since sliced bread!!! Very accommodating for my middle aged spread!!!
Escape Artists!!!"Finding our way out"
Red Green: "I'm a man I can change...if I have too"
Red Green: "Remember I'm pullin' fer Ya; we're all in this together"
"The more we know, the more we know we don't KNOW!!!"
+Quote Post
Tim Wood
post Oct 26 2008, 03:52 PM
Post #41
RV Type: 1991 Horizon 17'
I just might have to make one of those sliding tables myself, thanks for the pics.
+Quote Post
Scott S.
post Oct 29 2008, 05:54 AM
Post #42
RV Type:1975 SurfSide TM-14 front kitchen
what are you doing with the old lights Peter?
+Quote Post
Scott S.
post Oct 29 2008, 06:02 AM
Post #43
you must be one of those ppl that wakes up in the middle of the night and has to keep a note pad by the bed to empty your brain onto so you can get back to sleep? Scamp should have you on their design dept. payrole. bravo!
+Quote Post
peterh
post Oct 29 2008, 07:42 PM
Post #44
QUOTE (Scott S. @ Oct 29 2008, 06:54 AM) *
We had six of the original Scamp lights and gave a few away to some friends. The rest we are keeping until we either install them in our Surfside trailer project or decide we want some other kind of lights there. That'll be a while off; we plan on starting work on the Surfside next year after I complete the remaining "big ticket" projects in the Scamp 5er.
+Quote Post
Scott S.
post Oct 30 2008, 06:13 AM
Post #45
thanx Peter. I did find one on the internet to order.
I'm going to keep looking to see if I can find a more modern looking one tho.
I only need one so I may also go for a socket conversion.
+Quote Post
RSS Lo-Fi Version Time is now: 20th November 2009 - 09:47 PM
