MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
3 Pages V  < 1 2 3 >
> 78 Boler, Restoration
David Duxbury
post Jul 22 2009, 07:34 AM
Post #16
RV Type:1978 Boler 17'
Hi Again Gang, well 99--? finished, a few more pics posted.
I have installed a AC unit on the floor strange you might say, I cut a hole in the floor and outside wall, picked up a large aluminum pan intalled the AC in it, a wood metal lined vent through the hole, it works well, though probably need a small circulating fan mounted somewere. Oh! installed a a small return air vent cage in the floor vent to keep the criters out, I allways say if you don't try it you dont know if it will work.
I have looked at a few postings of differant ideas of mounting, but though I would try this.
All the Best Dave
Go to the top of the page
+Quote Post
KevinDR
post Jul 22 2009, 08:24 PM
Post #17
RV Type:79 Boler 17'
[Dave, I am reeeeally curious how that AC unit is going to work for you. How big a hole did you put in the floor? And also the outside wall you said?
You better have some pretty good circulation going to make it work. Very creative Idea however. I was wondering were to put a small unit.
Looking forward on a report back from you on this one.
Regards
Kevin.
+Quote Post
james kent
post Jul 23 2009, 03:09 AM
Post #18
RV Type:boler 84
Dave I'm curious, Isn't your jack stand supossed to go UNDER the bumper? roflol.gif
+Quote Post
Alf S.
post Jul 23 2009, 04:28 AM
Post #19
RV Type:'07 Escape 5.0 & '02 GMC Tug
Hi: Dave... All that hard work and sweating the details, looks like it's finally coming together for you!!! Nice trailer!!!
Escape Artists!!!"Finding our way out"
Red Green: "I'm a man I can change...if I have too"
Red Green: "Remember I'm pullin' fer Ya; we're all in this together"
"The more we know, the more we know we don't KNOW!!!"
+Quote Post
David Duxbury
post Jul 23 2009, 06:56 AM
Post #20
Good Day People. thanks for the replys, (and yes to James) the stands have been shortened as the ones that are available are too long to go under the Boler, just aluminum angle and pop rivets, no real weight, forgot to state that.
Madeleine my wife and I are going to Mosport Grand Prix near Bowmanville off the 401Hwy at the end of August we allways park behing the GO-Cart track gate 2 might so if there are any race nuts going might see you there.
All the Best Dave
+Quote Post
Kevin K
post Jul 23 2009, 07:38 AM
Post #21
RV Type: 1983 13' Scamp.... 1999 Silverado, 4.8, Auto, 4x2
Very Nice Trailer.
Try not to fall apart during the day.
+Quote Post
David Duxbury
post Jul 23 2009, 12:03 PM
Post #22
Kevin here are some pics on the AC venting, I just used a Fridge vent for the intake on the side of the boler, underneath a small return air vent with the fins pointing backwards, its mounted just behind the floor brace at the front, to provid protection from water etc.
One could install a cover if needed. Dave
+Quote Post
Don N
post Jul 23 2009, 01:26 PM
Post #23
RV Type:1978 Boler 1700
QUOTE (David Duxbury @ Jul 23 2009, 10:56 AM) *
Madeleine my wife and I are going to Mosport Grand Prix near Bowmanville off the 401Hwy at the end of August we always park behind the GO-Cart track gate 2 might so if there are any race nuts going might see you there.
All the Best Dave
Which race is that Dave? They had the one race in June? We will be going to the Zippo Grand Prix in Watkins Glen on the Sept4th weekend. That is always a real good time.
+Quote Post
KevinDR
post Jul 23 2009, 08:48 PM
Post #24
Very cool Dave.
Permission to steal your design?....but first really want to find out from you how well it works.
I like the small and understated range vent. With the deflector you put, I can see that the A/C fan itself does the air movement.
Terribly curious on how well it chills the whole trailer. (Home Depot is selling 5000 btu units for $100 bucks)
Kevin.
+Quote Post
David Duxbury
post Jul 24 2009, 06:48 AM
Post #25
Hi Kevin. Yeh its one of those 5000 BTU units from Canadian Tire, same price.
It works well, a small circulating fan mounted somewere should do the trick.
As I say if you dont try it you dont know, its not like I was cutting into a expensive new trailer.
I thought a finer screens on the vents to keep the yellow jackets out
Dave.
+Quote Post
KevinDR
post Jul 24 2009, 09:10 PM
Post #26
QUOTE (David Duxbury @ Jul 24 2009, 08:48 AM) *
Dave.
Yah, throw in some window screen/mosquito screen behind each of the vents should do the trick. So the small vent on the side permits enough intake air to prevent the unit from overheating? And the whole trailer gets cool? Does the unit continually run, or does it cycle on and off? Since it is on the floor, does the unit push enough cool air up higher as well? I am being cautious before I cut a hole in the side. Mind you, the hole is relatively small. How is the noise factor? Do you use it to chill the place down prior to sleep? Is it tolerable to run while you are sleeping?
What I like about the whole concept is that if it breaks down and you abandon it, you can simply pull it out, put the cabinet door over top the hole and away to you.
By the way, Nice panelling job on the interior.
Kevin.
+Quote Post
David Duxbury
post Jul 25 2009, 07:01 AM
Post #27
Kevin, the unit is not loud, but the ciculating fan will be a must because of it being on the floor.
I have not really tested it for a long time yet, as you know weather has not been up to par for southern Ont this year.
One could try a unit place it on the floor in a tray and see how it works, along with a fan ???
Dave.
+Quote Post
Raymond Brodeur
post Jul 26 2009, 11:46 AM
Post #28
RV Type:Boler 17ft 1977 (Coquille (Shell)) and 04 Explorer Sport Trac (p'tit Beu (Little Bull))
QUOTE (David Duxbury @ Jul 25 2009, 11:01 AM) *
Dave.
David
Could you not install an upward deflector over the cool air output ? Like something of that kind :
+Quote Post
David Duxbury
post Jul 27 2009, 06:36 AM
Post #29
Hi Raymond,sure but its close to the door , dont want to be hitting it with my legs.
It works well the way it is, The reason I choose the location was its out of the way, and one can sacrifice the space there.
I still think a little circular fan maybe at the back of the Boler mounted under the back cupboards Dave.
+Quote Post
Marty Smiltneek
post Jul 29 2009, 03:54 AM
Post #30
RV Type:Boler American
QUOTE (David Duxbury @ Jul 27 2009, 02:36 PM) *
Hi Dave,
Interesting thread. I have had an air conditioner mounted in my trailer for about three years. This year I had planed to add an electric fan to force air through the air conditioner unit. I will control the fan with the internal circuitry of the air conditioner so it works with the other blowers. (Just havent gotten around to it.) I have the A/C mounted on the floor where the old refrigerator was located. I have the intake air ducted to the sides of the air conditioner and the discharge blowing straight out. I think that the underside intake is probably a better idea and am contemplating that modification. The unit cycles on and off indicating that it is large enough. I have a small circular fan mounted to the wall to circulate air inside the camper. I will post a photo if you want.
Marty
+Quote Post
3 Pages V  < 1 2 3 >
RSS Lo-Fi Version Time is now: 21st November 2009 - 01:08 AM
