MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
2 Pages V   1 2 >
> Solar Boler, Pictures of PV panel install on the Boler
kevin61
post Feb 8 2009, 01:30 PM
Post #1
RV Type:13' Boler
Here is a link to some photos of the progress of a Solar Panel install on the Boler.
Will complete a video once the project is complete.
http://flickr.com/photos/76boler/326376209...57613488933155/
Go to the top of the page
+Quote Post
Frederick L. Sim...
post Feb 8 2009, 01:57 PM
Post #2
RV Type:Fiber Stream 1978 Tow with:Odyssey LX 2003
They look pretty slick. How many watts? Do they stay flat all of the time?
Frederick & Robert The Odyssey and the "Eggstasy"
We have not succeeded in answering all of your problems. The answers we have found only serve to raise a whole set of new questions.
In some ways we feel we're as confused as ever, but we believe we're confused on a higher level and about more important things.
+Quote Post
kevin61
post Feb 8 2009, 05:47 PM
Post #3
RV Type:13' Boler
QUOTE (Frederick L. Simson @ Feb 8 2009, 09:57 PM) *
Two 80 watt panels,approximately 42"X42" (together), wired in series. Should give me a Vmp of 33.4 volts, current of 4.8 amps.
The panels can stay flat, tilt towards door side, tilt towards drivers' side or be remotely mounted up to 35 feet away with the addition of a 12 AWG extension cord. I am thinking of adding a set of mounts to the cap of my truck. The trailer can then be parked in the shade and the panels can be secured to the truck which can be parked in the sun.
Also looking into a method to secure (lock) the panels to their mounts to help deter theft.
I'm pretty new to solar so it is taking me a while to get my head around the terminology and different wiring techniques.
A Morningstar MPPT charge controller should arrive for an install next weekend. Once I hook it up and run it through its' paces I will report back with the results.
This post has been edited by kevin61: Feb 8 2009, 05:57 PM
+Quote Post
Gerry
post Feb 14 2009, 02:52 AM
Post #4
RV Type:Boler 13ft
I have a much smaller panel I used last summer while full timeing as camp host and it kept my battery charged for what I needed.
A few questions about your set up because I just moved mine around on its 15 foot lead to capture the max sun. Although it would work in ambiant sun I felt better when I saw ths sun right on it.
Do you plan to keep this panel on top of camper at all times even traveling down the road?
If so, did you build a cover to protect it? Does it need protection?
If not do you bring along a step-ladder so you can set it up?( do not think I would like this idea)
Even to get a cover off you would need to get up there.
Gerry
I may be crazy but I'm not stupid!!!
+Quote Post
kevin61
post Feb 14 2009, 08:39 AM
Post #5
RV Type:13' Boler
QUOTE (Gerry @ Feb 14 2009, 10:52 AM) *
Gerry
I will have mounts on my truck cap and have made a 50 ft extension from #10 AWG wire. (The length of the extension can vary for your installation depending how you have your panel or panels wired (series or parallel) and your particular charge controller.)
I will have the option of leaving the panels on the trailer or transferring them to the tow vehicle. It has been suggested by PeterH that the fibreglass roof may not be able to withstand the forces of the wind on the panels. I will not be doing a road test until April so won't be able to report back until I take it for a few runs. Chances are I will get better gas mileage with the panels mounted on the cap of my truck so the wind can travel over/under and around the panels. You will notice that the aluminum support brackets are broadside to the oncoming wind when the panels are on top of the trailer. The brackets on my truck cap will be turned 90 degrees to allow for better air flow.
Either way the panels will be plugged into the charging circuit so that the batteries are being charged while I am travelling.
The panels weight is only 35 lbs so it is just a matter of stepping up on a small stool to slide them on or off the trailer or truck. An easy one man operation.
There is no need to cover the panels. They are designed to withstand some punishment from the elements such as hail. As well if covered they will not be charging your batteries.
Once the project is complete and warmer weather comes back to Calgary then I will complete a video showing the setup in actual use.
+Quote Post
Chester Taje
post Feb 14 2009, 08:46 AM
Post #6
Location: Grande Cache Alberta . Just shy of Alaska Highway.
RV Type:Looking for a Compact J
Very good job.You should be proud.
Chester & Marie
EH
Glass is Class
+Quote Post
Ed Harris
post Feb 14 2009, 04:49 PM
Post #7
RV Type:82 Fiberstream-3rd time's a charm.
One thing I have found to be helpful is to put a parallel connector from the panel and connect a Voltmeter there.
I have been able to use this to aim the panel for maximum output at any time.
I am always surprised that the angle I think is so different from the angle the meter will peak at.
I just have a cheap dedicated meter just for doing this.
On mine I use Anderson Power pole connectors to make it quick and simple to connect it all.
Ed
+Quote Post
kevin61
post Feb 26 2009, 09:03 AM
Post #8
RV Type:13' Boler
I am placing all the links to the videos of the solar installation here in my original posting to make it easier for those doing a search. (thank you peterh)
Mounting two solar panels together and wiring in series
http://www.youtube.com/watch?v=Kh5b0yYVuvU...feature=channel
NEW TODAY
Solar panel mounting system on top of a 1976 Boler trailer
http://www.youtube.com/watch?v=akufm_DarLY
Installing wiring through roof of Boler trailer
http://www.youtube.com/watch?v=E5PyUbXvXRw
Installation of a Morningstar MPPT charge controller in a 1976 Boler trailer
http://www.youtube.com/watch?v=bP6pDkpe1-o
Initial testing of the solar installation
http://www.youtube.com/watch?v=QrjW8gnKSkY...re=channel_page
Still images
http://flickr.com/photos/76boler/326445047...57613488933155/
+Quote Post
Joseph Domingos
post Feb 26 2009, 09:50 PM
Post #9
RV Type:1973 Compact II Trailer and 2001 Honda CRV SE automatic
Kevin,
Your videos have been very educational, thanks for all your work in sharing them with all of us. You are one careful and meticulous guy! If/when I'm working on projects of my own down the road, you're one that I might bounce a few ideas off of, K? hehe
Happy Modding and keep up the good sharing!
Joe
+Quote Post
kevin61
post Mar 1 2009, 06:03 PM
Post #10
RV Type:13' Boler
QUOTE (kevin61 @ Feb 26 2009, 10:03 AM) *
NEW TODAY
Still images
Todays' project was to design a prototype for a rotating solar panel mount for the cap of my truck.
This short video clip demonstrates the time and effort involved to transfer the panels from truck to trailer.
http://www.youtube.com/watch?v=k7Cjrh-AydA
+Quote Post
kevin61
post Mar 3 2009, 07:14 AM
Post #11
RV Type:13' Boler
This is just an update of the solar installation with all the links located in one location.
The newest video is at the bottom.
Installing wiring through the roof
Installing solar charge controller
Transferring panels from tow vehicle to trailer
Still Photos
NEW TODAY
Tilting and locking system for solar panels
http://www.youtube.com/watch?v=7TDKyE6L1D4...re=channel_page
+Quote Post
kevin61
post Mar 8 2009, 02:01 PM
Post #12
RV Type:13' Boler
VERY IMPORTANT CHANGE TO SOLAR INSTALLATION
In my videos I show a MALE plug coming from my solar panels. This is incorrect and poses a serious SHOCK/SHORT HAZARD. With the panels in full sun the red and black prongs are HOT.
Still Photos
http://www.youtube.com/watch?v=7TDKyE6L1D4...re=channel_page[attachment=22159:connector_warning.jpg]
This post has been edited by kevin61: Mar 8 2009, 02:16 PM
+Quote Post
kevin61
post May 5 2009, 06:33 AM
Post #13
RV Type:13' Boler
I am heading to Langley on Thursday and this will be the "shake down" trip for the solar panel installation on the roof of the Boler.
I decided to follow through on a suggestion by Peterh and have installed a wind deflector in front of my panels to help direct air over the panels. The mounting brackets are broadside to the wind
and the concern was raised that this may cause excessive stress on the panel/roof connection.
I haven't done a wind tunnel test (although my neighbour did suggest a large fan and a 50 lb. bag of flour)I just guessed and "eyeballed" an angle. Hopefully it won't create a vortex and rip the panels off from the back!
Not sure if it will get painted in time for the journey but the trip should also expose any cracks that may occur in the fibreglass/bondo that may occur from the flexing of the roof.
This post has been edited by kevin61: May 5 2009, 06:34 AM
+Quote Post
Jim Bennett
post May 5 2009, 07:48 AM
Post #14
RV Type:'09 Escape 19' ........ '09 Honda Pilot
Kevin, looking forward to seeing your setup on Friday.
JIM
+Quote Post
kevin61
post May 5 2009, 08:33 AM
Post #15
RV Type:13' Boler
Hi Jim,
If you happen to find a couple of solar panels between Calgary and Langley just give me a call.
See you this weekend.
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 20th November 2009 - 08:30 PM
