Christi: A power drill and drill bit that's slightly larger than the hole in the top of the rivet usually does the trick. Sometimes you have to get someone to hold the back side of the rivet with a pair of pliers to prevent it from spinning while you drill from the other side. You can replace the rivet with a screw, capnut, and a pair of lockwashers, but rivets work really well too.
QUOTE (Ed Harris @ Mar 7 2009, 02:17 PM)
I put a Thinlight Flourescent over the sink in each trailer I have had.
This is the one spot where I really appreciate having enough light.
They are very bright and more effecient than incandescent fixtures without making any real heat.
I like LED's a lot for what they are but I have yet to find any that can replace the Thinlights.
Don't Thinlight fixtures require 110v AC? We have a fluorescent fixture over our curb-side kitchen counter, too, but generally don't use it even when we do have hookups because the light isn't well distributed and our LED fixtures already do a good job of lighting up the trailer.
I made a nice LED fixture using an
LED strip light from LED Wholesalers over the bathroom door in our 5er (the darkest part of the trailer) with that LED light strip and it does a great job there. . .Lights up the whole area really well. We also adapted two sets of IKEA's
Dioder LED puck lights for use over our kitchen counters; the two sets of
Dioders aren't as bright as the single 110v AC flourescent light, but because their light is spread around over the counters on each side of the trailer we have ample light for any kitchen chore.
