QUOTE (DannyH @ Sep 3 2009, 07:55 PM)
If the axle bracket is wider than 1 ½", I will adjust the outside edge dimension so that the inside vertical part will line up with the inside face of the trailer frame.
That's essentially what I did.
Since you found the diagrams on Dexter, I'm posting this for others that might have the same question. The mounting bracket is 2" wide and add 1/4" for the side mount hanger. That makes each bracket 3/4" wider than your frame. Total width (outside of brackets)will be 1.5" wider than the outside of your frame.
Now if you are doing it like me "switching from leading to trailing" don't forget to allow for the height of your dropped floor. Dexter does make a 3" high snowmobile bracket but that was just not enough clearance beneath the floor to allow for the bend in the axle tube for camber.
