MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
4 Pages V   1 2 3 > »
> New Flooring-Laminate or Vinyl
Tim Wood
post Apr 8 2009, 02:42 PM
Post #1
RV Type: 1991 Horizon 17'
OK, I've started working on the Horizon since its been nice weather, although its been snowing the last couple of days. But I'm going to tear out the carpet and put in either laminate or Home Depot has a flooring that looks like laminate but is vinyl. It looks just like wood. Has anyone used this vinyl type from Home Depot ? And if I were to use a laminate, does it hold up OK in wet weather ? Thanks
Go to the top of the page
+Quote Post
Rick Brown
post Apr 8 2009, 03:54 PM
Post #2
RV Type:Compact Jr
QUOTE (Tim Wood @ Apr 8 2009, 02:42 PM) *
Tim
I have used the flooring from Home Depot and it was one of the best floors I have ever put in. I have a Compact Jr and it took about 1 1/2 hours from start to finish. Plus this floor will not be damaged by water and since it is a floating floor you can remove it with out any problems. I put laminate flooring in my house and I wish I would of seen this floor first. Attached File  cherry_flooring_SMALL.JPG ( 31K ) Number of downloads: 290
This is a picture of our floor
+Quote Post
Jeanne and Steve
post Apr 8 2009, 04:05 PM
Post #3
RV Type:Casita 16' 1984; U-Haul CT13 1985
This post made a big impression on me. I read it after we had already installed laminate flooring in our Casita. Our laminate flooring is beautiful and we haven't had any problems so far, but I'm very careful to wipe up any spills. If we were to do it again, I think we'd go with vinyl.
Jeanne
Attached File  casita_floor_006__Small_.jpg ( 30.61K ) Number of downloads: 202
+Quote Post
Randya
post Apr 8 2009, 04:36 PM
Post #4
RV Type: 05-17' Casita SD/2005 Tundra
Every thing I have read about laminate flooring, it is very durable, but moisture is a killer. It's ok if you keep the spills wiped up. I have 1000 sq. ft. in my house and never had a problem, but I am careful with spills and wet. I never put it in the kitchen or bathrooms. I would go with the vinyl.
This post has been edited by Randya: Apr 8 2009, 04:39 PM
+Quote Post
Jim Bennett
post Apr 8 2009, 04:45 PM
Post #5
RV Type:'09 Escape 19' ........ '09 Honda Pilot
I plan to do cork flooring in my trailer once I get it. If you wish you can use an adhesive that seals the joints. It will add warmth and beauty to the trailer.
JIM
+Quote Post
Tim Wood
post Apr 8 2009, 04:46 PM
Post #6
Thanks Rick,Jeanne,& Randy I appreciate your feedbacks. I kinda thought this post might go this way, as I was looking at the vinyl [at] Home Depot the other day. I thought man this is just the ticket for a camper. Rick by the way I'm still looking for a compact, but I have to sell one of two campers before I pursue one. I'm thinking after I get the mods done on the Horizon I may sell it, and also my 16' side dinnete Scamp too. But I will have to give that some more thought, if I do keep one I don't know which it will be.Jim I just saw your post, I'd like to see that cork. That should be a very durable floor and weather resistant too.
This post has been edited by Tim Wood: Apr 8 2009, 04:49 PM
+Quote Post
Jim Bennett
post Apr 8 2009, 06:17 PM
Post #7
Tim, you can see cork flooring at a lot of lumber/finishing supply stores, or at any flooring store. It is becoming real popular around here. We install lots of it on basement floors, as it gives an easy way to add a real wood floor, plus the added benefit of it being real warm to the touch (of the feet). It costs around $4-5/sf AD, but you don't really need much, and install just like a laminate or any other engineered wood floor. The finish is a polyurethane, just like vinyl or other wood floors.
Cork is also a renewable source. They just strip the bark off the tree, and it regrows itself back again in 9-10 years.
JIM
+Quote Post
Tim Wood
post Apr 8 2009, 06:27 PM
Post #8
Jim, Thanks for the info I will check it out.
+Quote Post
Don N
post Apr 8 2009, 07:10 PM
Post #9
RV Type:1978 Boler 1700
I installed that laminate vinyl in our bathroom over a year ago and absolutely no problems at all. Even with moisture from shower, etc. Real easy to cut and install and priced reasonable. I think it would be ideal for a trailer floor.
+Quote Post
Raya L.
post Apr 8 2009, 08:42 PM
Post #10
RV Type:1974 Boler 13 (Neonex/Winnipeg)
Jim,
Does the cork flooring you know of ever come in a sheet, like vinyl? I ask because in a quick web perusal, I only came up with tiles or "planks." I like the thought of one big sheet in order to not have to think about cracks or seams.
Raya
+Quote Post
Jim Bennett
post Apr 8 2009, 09:55 PM
Post #11
Raya, it does come in tile or plank shapes like you found, just like any laminate or other engineered wood flooring. It is real wood on a structurally stable engineered base. The joints fit real tight. We have put it in in a bunch of kitchens in customers homes and have had no issue. As mentioned, with some brands you can use a glue/sealant between the pieces when you put them in to achieve a sealed bond. I plan on having a nice mat inside the door and always have a ground mat outside as well. We only wear shoes inside if it they are clean and dry.
I pick up my new trailer in a month (exactly, but who is counting wink.gif). I will be installing it almost right away and will take some photos of the installation, and report on how it went.
This post has been edited by Jim Bennett: Apr 9 2009, 08:28 AM
JIM
+Quote Post
Tim Wood
post Apr 9 2009, 03:35 AM
Post #12
Jim, I'm going back to Home Depot this weekend, but I will check into the cork today to see who has it in my area. Don, I too think that vinyl would be just the thing for a camper. I found a place that sells both types of floor, so I'll take a look maybe tomorrow.Thanks,Tim
This post has been edited by Tim Wood: Apr 9 2009, 06:39 AM
+Quote Post
Carolyn Patterso...
post Apr 9 2009, 07:06 AM
Post #13
RV Type: 16' U Haul V.T. - pulled by a 2004 GMC Safari
My Vote is for Vinyl too..
When I brought my 'new to me' trailer home, the first thing I did was take out the carpet. Went to Home Depot (I'd already shopped both there and Lowes for the "hardwood look" I wanted) bought the size I needed off the roll, came home - grabbed a piece of plywood (used to cut the vinyl on) used the carpet as a template, and within less than 30 min I had a 'wood look' floor that takes no time to wipe up. Mine lies there (isn't attached) but this summer I might think about putting trim pieces around the edges. For the past year, it looked fine without it.
Laminate would be wonderful, but my husband isn't real handy when it comes to things like that, so I had to have something I could do on my own. I had laminate installed in my home, and the first thing the installer told me was to be careful about 'mopping' the floor due to the possibility of water seeping thru the cracks.
"I need a lattitude adjustment!!"
+Quote Post
Booker B.
post Apr 9 2009, 08:06 AM
Post #14
RV Type:1976 Trillium 1300
Are you talking about the Traffic Master Allure vinyl laminate? Here are a couple of threads on installing it:
http://www.fiberglassrv.com/board/index.ph...7&hl=allure
http://www.fiberglassrv.com/board/index.ph...1&hl=allure
This post has been edited by Booker B.: Apr 9 2009, 08:07 AM
"Hazel" - our 1976 Trillium Towed by "Zippy" our 2005 Subaru Forester.
Change of plans - skip all that restoring nonsense and start camping!
+Quote Post
brendadave
post Apr 9 2009, 08:36 AM
Post #15
We changed to a Glueless Vinyl after our first year, it has been wonderful, it does not require glue, the edges don't curl up, was easy to cut, and realy easy to keep clean, even as it gets wet on rainy or snowy days.
Oh, and it does look like wood, most people think it is laminate when they look at it.
Best part, it was a remnant we picked up cheap from out local End of the Roll.
+Quote Post
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 20th November 2009 - 09:07 PM
