MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> Scamp 16' door and gravel shield renov, Correction of some problem on my scamp
Yvon Chayer
post Apr 26 2009, 04:16 PM
Post #1
RV Type:Bigfoot 17' 1992 & Chevrolet S10 4.3L.
Today i finish the renovation on my Scamp
I have some problem with my door
First the hinge have some loose , i replace it not great renov
Second the lower front end of the door don't close tight , i correct it , i remove the door and remove carpet, and make 3 saw cut on the inside fiberglass, i bent the door with a ratchet strp and make fiberglass to maintain it in the good position i use premix (fiberglass fiber mix with resin )
Premix fiberglass
saw cut
gelcoat application
Now the door fit exactly with the body of the scamp, before i have 1/2 inch opening on bottom
Perfect fit
the third problem , i don't like that the door was sealed on the carpet , i cut them and resuface the contact part of the door with gelcoat , now the seal is in contact with gelcoat not on the carpet
the seal seat
The other correction was the gravel shield i take my old door hinge and modified it
I cut it and reweld with 30 degre angle and use it for sield hinge
old hinge modified
hinge installed
closed
open
Now the rust on fiberglass is finish , i make new lock on the bottom make with a stainless stell flat bar
this job finished my spring modification , next week i start from Quebec Canada to one month vacation to Louisiana
I take some information in the site, when i can give on i make it
Thank again Yvon Chayer
This post has been edited by Yvon Chayer: Apr 26 2009, 04:27 PM
Go to the top of the page
+Quote Post
Jeanne and Steve
post Apr 26 2009, 06:48 PM
Post #2
RV Type:Casita 16' 1984; U-Haul CT13 1985
Hi Yvon,
Your door looks fantastic now - great work! Plus it's neat that you retained some of your trailer's history by using the door hinges on your gravel guard. Thanks for the interesting report.
Best wishes for a fantastic camping trip!
Jeanne
+Quote Post
Raya L.
post Apr 26 2009, 08:06 PM
Post #3
RV Type:1974 Boler 13 (Neonex/Winnipeg)
Thanks for the report and photos, Yvon! It's always so nice to see photo-essays about how people fix up their trailers.
I wish you a wonderful camping trip, and of course we would love to hear how it's going if you get a chance smil.gif Will you look up Cajun/French-speaking people in Louisiana?
Raya
+Quote Post
Roy in TO
post Apr 26 2009, 08:18 PM
Post #4
RV Type:'72 Boler American
Yvon,
Your work looks good.
May I suggest you post pictures rather than links. Sometimes outside photo hosting services stop hosting and we lose the pictures forever. For example Lance did a great slide show on his blue boler and his provider said they would not provide the service just this year, now we have to wait for him to post his pictures all over again.
Here is a link to the tutorial on posting pictures here:
http://www.fiberglassrv.com/board/index.php?showtopic=20738
Plus there are others that tell you how to resize if need be.
Roy
Owning a trashed trailer does not make one trailer trash.
+Quote Post
Pete Dumbleton
post Apr 27 2009, 01:05 AM
Post #5
RV Type:Scamp
Your next project should be a screen door for your visit to Louisiana, where lots of mosquitoes live!
One way to do this is to use wooden inserts on the door jambs to make them straight, then you can fabricate a door from a window screen kit from hardware store and some pop rivets, plus a little scrap aluminum for added stability.
Pete Dumbleton
'91 Scamp 13' & '98 Ranger 4.0L 4WD pickup
+Quote Post
Yvon Chayer
post Apr 27 2009, 05:19 PM
Post #6
Hi Pete I have the factory screen door install in my scamp
After my vacation in Louisiana the next modification is remove front bunk and make a front dinette
I have make some research and after planification it is possible
Roy it's ok , i have read the tutorial and next time i make it
Yvon Chayer
+Quote Post
Raya L.
post Apr 30 2009, 07:17 PM
Post #7
Yvon, I am curious about something:
Did you use fiberglass cloth (or biaxial, etc.) to reinforce your repair? Or was it just resin with some fibers in it? (I'm not sure what is in the can that you show.)
I would have thought one would need cloth, but then I don't know the product you used.
Raya
+Quote Post
james kent
post May 1 2009, 04:19 AM
Post #8
RV Type:boler 84
Interresting concept. I know that Plasto makes compounds for the repair of plastic bumpers and injection mold plastic. Does it also make fiberglass products?
Let us know how it turns out.
+Quote Post
Mary Lynn K.
post May 1 2009, 02:00 PM
Post #9
RV Type:Trillium-13'-1974-1300/ Burro-1986-17'widebody
QUOTE (james kent @ May 1 2009, 07:19 AM) *
Hi Yvon: I'd like to know what rods you used (aluminum?) and how they are held in place, while holding up the rockguard? It looks great!!Have a great/safe trip 4.gif -Mary Lynn K.
+Quote Post
Kirby and Adele
post Jul 16 2009, 01:20 PM
Post #10
RV Type:13' Scamp
I would also like to know what Yvon is using to hold up the gravel shield. When we bought the Scamp we wondered why the gravel shield hadn't been set up to open like an awning. Are they supposed to?
Yvon, répondez s'il vous plait.
+Quote Post
Yvon Chayer
post Jul 17 2009, 02:11 PM
Post #11
For holding the gravel shield , i use a set of main door hinge from Scamp
I replace the main door hinge on my scamp and use the old hinge after modification of the angle of the old hinge
Yvon Chayer
+Quote Post
post Jul 21 2009, 01:01 PM
Post #12
RV Type:1988 16' Scamp Deluxe
QUOTE (Kirby and Adele @ Jul 16 2009, 02:20 PM) *
Joy A provides some instructions on making some struts to hold up the Gravel Guard. They're simple to make... I made mine two years ago and they work great! You'll find her instructions and others too in this topic:
Scamp Window Cover
A Hardboiled Egg
+Quote Post
RSS Lo-Fi Version Time is now: 20th November 2009 - 09:27 PM
