MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> 7" LED's on sale at Princess Auto $24.99
kevin61
post May 15 2009, 05:22 PM
Post #1
RV Type:13' Boler
http://downloads.princessauto.com/
Princess Auto has 7" LED tail lights on sale for $24.99 (Canadian $)
Page 7 of the Flyer, Event 09 (Starts 05-19-2009)
Go to the top of the page
+Quote Post
Roy in TO
post May 15 2009, 06:34 PM
Post #2
RV Type:'72 Boler American
Thanks for the heads up Kevin.
Did you notice they redesigned their website? On first glance it looks good, the search works. I'll have to check it out later.
There is also a surface mount, hard wired, switched 16 LED light that looks like it would be good for our trailers. Problem is, they don't say what the voltage is. The 4" task light is on page 8 of the catalogue listed at $14.99
If anybody gets one, please let us know the voltage and actual draw. Looks like it might be good for over the kitchen counter.
Owning a trashed trailer does not make one trailer trash.
+Quote Post
Roy in TO
post May 15 2009, 06:45 PM
Post #3
OK, I checked out the website. Major improvement. The sale items can be viewed online without downloading the catalogue. It looks like from the structure of the site, we should be able to locate items in the store easier too.
+Quote Post
kevin61
post May 16 2009, 04:15 AM
Post #4
RV Type:13' Boler
QUOTE
I did pick up one of these lights to give it a try.
It does have two wires coming from the rear so my assumption is 12 volt. FYI-the brown wire is positive and the black is ground. Not sure if they can withstand the higher voltages from my charging system but, for $15 each I will give them a try.
They are fairly bright (cool white) and draw 0.15-0.20 amps.
I will probably pick up a second one and install both under my overhead cabinet
This post has been edited by kevin61: May 16 2009, 06:23 AM
+Quote Post
Roy in TO
post May 16 2009, 07:19 AM
Post #5
Thanks Kevin,
How high are they?
What is 4"? the LED portion or the whole light?
I'm trying out the new ask a question on the Princess auto web site. I just asked a question about the voltage requirements. Let's see how long it takes to get an answer and what they say.
+Quote Post
kevin61
post May 16 2009, 08:08 AM
Post #6
RV Type:13' Boler
QUOTE (Roy in TO @ May 16 2009, 09:19 AM) *
Thanks Kevin,
How high are they?
The overall dimensions are 1.25 " high X 4" across.
+Quote Post
Roy in TO
post May 16 2009, 06:04 PM
Post #7
Thanks,
How do they compare in brightness to the Superbrights you installed or the other LED bulbs you tested?
+Quote Post
RSS Lo-Fi Version Time is now: 20th November 2009 - 05:53 PM
