MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> rehanging the cabinet doors, lower cabinets on burro don't match up anymore
Kelly G
post May 22 2009, 01:19 PM
Post #1
RV Type:1998 17' Burro~aka Frankeggstein's Monster
&We're not happy with the lower cabinets on our burro, they're hinged at the bottom rather than the top. They don't stay closed so the PO rigged up a toggle system for them. We were wondering if you could just attach them from the top like the upper cabinets or if that would cause future problems.
Reason for edit: Embeded pics as per FiberglassRV SOP
Go to the top of the page
+Quote Post
Loren G. Hedahl
post May 22 2009, 03:07 PM
Post #2
RV Type:84 - 16ft Scamp
Of course you could. But I would think access would be terrible if the doors were hinged at the top -- unless there is something I don't understand.
L. Hedahl
+Quote Post
Frederick L. Sim...
post May 22 2009, 03:44 PM
Post #3
RV Type:Fiber Stream 1978 Tow with:Odyssey LX 2003
QUOTE (Loren G. Hedahl @ May 22 2009, 04:07 PM) *
I would think access would be terrible if the doors were hinged at the top.
What kind of closure mechanism did the doors have before the Previous Owner cobbled together that "Toggle" system?
It looks to me that the doors might be binding on the edging material around the opening, especially since you show missing screws in one hinge in your 2nd photo. I would shim out the hinges to stop the binding, then address some kind of positive catch in the top of the opening (magnet, pinch clip) that would be hidden when the door is closed.
If the hinges are the "spring loaded" type, they may not have strong enough springs to hold the door closed against that opening edging...
Frederick & Robert The Odyssey and the "Eggstasy"
We have not succeeded in answering all of your problems. The answers we have found only serve to raise a whole set of new questions.
In some ways we feel we're as confused as ever, but we believe we're confused on a higher level and about more important things.
+Quote Post
Kelly G
post May 22 2009, 04:01 PM
Post #4
QUOTE (Loren G. Hedahl @ May 22 2009, 06:07 PM) *
Yeah, I didn't describe that very well. The cabinets for them are no longer square and the doors don't match up to them, leaving large gaps, making it hard to fasten them. They want to pop open so they're rigged with a cord to stay up.
I'm trying to imagine actually getting into them now that you mention accessibility. Glad you said something, I wasn't looking far enough ahead.
Maybe I need to check into better fasteners, the weight & irregularity are just too much for the current magnetic ones.
This post has been edited by Kelly G: May 22 2009, 04:01 PM
+Quote Post
peterh
post May 22 2009, 09:14 PM
Post #5
RV Type:2005 Scamp 5th Wheel
Here are a couple ideas for you. First would be to look for boat/rv push-button latches that hold your existing doors closed, or you might add some child safety latches that hook the edge of the door frame when the door is opened.
If I were in your place I'd probably re-frame the existing openings with wood frames that have 5/16" wide by 1/4" deep grooves cut in the top and bottom rails and replace the old doors with Masonite hardboard sliding doors.
+Quote Post
RSS Lo-Fi Version Time is now: 21st November 2009 - 12:52 AM
