MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> Need bracket for 4" rear bumper, I want to mount a 'Travel Box' on the rear bumper!
Michael Pupeza
post May 26 2009, 12:32 PM
Post #1
RV Type:1993 Bigfoot - 17CB
Hi,
I have a Bigfoot 17 and want to move the rear spare tire over to one side and mount an aluminum front drop panel diamond plate storage box onto that 4" square bumper.
I realize that putting weight on the rear is not a good idea, but I am somewhat tongue heavy and want a small storage box on the rear.
My box is 24"W x 20"H and 18" front to back with the front door swinging down forward.
I want to mount plates on that 4 1/4" square rear bumper.
Who, where can I get mounting plates with the square u-bolts to mount the box?
I've googled and searched these forums and haven't been successful. Closest, and perhaps able to be modified, are the rear spare tire mounts, but simpler mounts would be better!
I'm in Ontario, so a CDN source is best, but I can arrange for USA also.
Thanks for any help.
Mike
Go to the top of the page
+Quote Post
Bill K
post May 27 2009, 02:23 PM
Post #2
RV Type:2009 Scamp 16' 2003 Durango
Do you have a company's that specializes in bolts and nuts ?
The reason I ask is the one I use to go to would make up U bolts to your spec.
Bill K
+Quote Post
Dana T
post May 27 2009, 02:47 PM
Post #3
RV Type:1973 Compact Jr
McMaster-Carr is the first place I think of.
Here's their page on square U-bolts:
http://www.mcmaster.com/#square-u-bolts/=227jly
+Quote Post
Phillip
post May 29 2009, 04:12 AM
Post #4
RV Type: 13' Casita
You might consider adding a small reciever hitch,I plan on doing this to my 13' casita to pull my jonboat.. but you could also attach a rack..... this way it could be removed or used for towing a lite boat etc... they have racks that are already to go that mount on reciever hitches also..for say an ice chest or box...check a motorcycle shop for the racks.. or a truck accessories place...
+Quote Post
Michael Pupeza
post May 29 2009, 05:53 AM
Post #5
QUOTE (Phillip @ May 29 2009, 08:12 AM) *
Thanks for the advice!
I have decided to mount my box using 3/8 x 6" bolts. I have cut a sheet of 1/2" plywood for the inside of the box and will use 4 fender washers and bolts to fasten it down to 2 straps of 1/4" thick aluminum under the bumper. Depending on how it is supported, I may bring the straps forward and fasten them to the front of the box, adding more support to the unit!
A receiver hitch on the rear, while a good idea for some purposes, would be too excessive for me, so I'll pass on that idea.
That diamond plate box should look and work well there. I've previously posted a picture of the box - neat item!
Mike
+Quote Post
RSS Lo-Fi Version Time is now: 20th November 2009 - 06:20 PM
