OK, I paid an RV place $50 to install a closet rod in the privacy room (front to back) and another in the hanging closet (previously had perpendicular-type rod). On the first use, they both came tumbling down and all that was hanging.
I had intended for them to be bolted or secured some way through the fiberglass into the center of the wooden cup that holds the wooden closet rod on each end. They did not. They simply used some sort of glue. I would now like to have it done properly but have never drilled a hole into fiberglass before with my electric drill.
Does someone have a way to do this?
And, I'd also like to make the existing hanging closet a full door instead of just the use of the top half of the closet so I may have some extra storage. Suggestions?
Vintage Pearl 1996 16' Scamp
If you remove stones from the brook, it loses its melody.
