Version 2.0 of Steve's Tow Test Box is ready! (Wretched excess, part 2.)
I know everyone's been waiting with bated breath (If you have baited breath, see your dentist or stop eating sushi.
Version 2.0 includes built in volts and amp meters. For the tech weenies, technically the amp meter is reading millivolts across a 50A/50mv shunt. The panel meters were probably the least expensive part of this project at $7 and $9 respectively.
Number of downloads: 59I switched on the reefer to get some sort of amp reading on the ammeter. Otherwise, practically nothing was going into the trailer from the tow.
Version 3.0 will combine the Trailer Test and Tow Test boxes into one box. But I'll need a bigger box. The Tow box is already stuffed with tidbits, (some heavy gauge wire, the backside of two meters, two 7 pin female trailer outlets, shunts, diodes, LEDs, switches, bus bar and terminal strip). The Trailer box has a circuit breaker, scads more switches and a 12vdc outlet. At least it'll share most of the wiring and 7 pin RV connectors.
I wonder how much current a circuit board will carry.
How much current I'd like to try making my own circuit board. That would cut down drastically on the wires. I'll have to search around for that answer.
And to think I hated circuits class in college!
This post has been edited by Steve L.: Jun 21 2009, 06:46 AM
Reason for edit: Edited to answer my own question.
