MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> New external hatch
Roddy D
post Jun 13 2009, 09:58 AM
Post #1
RV Type:Scamp 16'
I added a new external hatch to access little used space under the back table booth seat. Peterh's article and help was greatly appreciated. First I cut the opening for the hatch and epoxied supports around the opening.
I then ran a bead of marine grade silicone around the outside of the opening and attached the hatch using #10 1" stainless steal screws.
The final product installed and ready to use.
I don't have any of the fancy magnets Peterh used to keep his hatch open so I have a temp solution. I used a bar clamp attached to the belly band, shown in the last photo. Thanks for your help peterh....
Roddy D
1982 16' Scamp in progress
Go to the top of the page
+Quote Post
Roy in TO
post Jun 13 2009, 07:33 PM
Post #2
RV Type:'72 Boler American
QUOTE (Roddy D @ Jun 13 2009, 01:58 PM) *
Great idea Roddy, I'll be adding hatches to mine in the future and had never considered using supports. Thanks!
Owning a trashed trailer does not make one trailer trash.
+Quote Post
james kent
post Jun 16 2009, 04:28 PM
Post #3
RV Type:boler 84
Roy.
If you hang the hatch with the hinge at the bottom, instead of on top, then it will hang down when opened and you don't have to hold it up while reaching inside.
I have put one into both rear storage benches.
+Quote Post
Roddy D
post Jun 16 2009, 09:05 PM
Post #4
RV Type:Scamp 16'
I thought of putting the hinge on the bottom, but knowing myself, if I did not secure the hatch door properly there might not be a door left on the hatch. roflol.gif
Roddy D
+Quote Post
Herb Sutton
post Jun 16 2009, 09:45 PM
Post #5
RV Type:1999 Casita 17 SD
The other consideration with a bottom hinged door is that if it touches the ground, it will get crunched if someone steps into the trailer while it is open and causes the trailer to drop down.
+Quote Post
Ellen Smith
post Jun 17 2009, 07:25 AM
Post #6
RV Type:19 ft Escape
Our outside access hatch is also also hinged at the bottom. It is right in line with the stabilizer jacks and so has to be locked when I'm putting down the jacks. Hinging at the top with a clip would be so much handier.
+Quote Post
james kent
post Jun 17 2009, 08:17 AM
Post #7
RV Type:boler 84
I buzzed out and took a couple of quick pics of one of the the hatches on our Boler. Here's the hatch on the road side. I had to relocate the marker light further back and also drilled a few more holes in the outer bracket for the stainless fasteners.
+Quote Post
Roy in TO
post Jun 17 2009, 12:36 PM
Post #8
They are all good ideas, keep them coming so I will know exactly what I want to do before I do it.
I prefer my fore sight to have perfect vision and not wanting to be be affected by my hind sight. The latter lasts longer.
+Quote Post
Jim Bennett
post Jun 17 2009, 12:58 PM
Post #9
RV Type:'09 Escape 19' ........ '09 Honda Pilot
Where is a good place to buy an insulated hatch door? Anyone have any links?
JIM
+Quote Post
Roddy D
post Jun 28 2009, 04:53 PM
Post #10
RV Type:Scamp 16'
I have looked around for insulated hatches with no luck. You might be able to glue some type of insulation onto an uninsulated door!
Good luck.
Roddy D
+Quote Post
Lisa H.
post Jun 28 2009, 05:34 PM
Post #11
RV Type:1970 Campster
QUOTE (Jim Bennett @ Jun 17 2009, 01:58 PM) *
Check out PeterH's mod last August where he added a hatch. Always with an eye for detail, Peter provides a great tutorial and shows how he insulated his hatch. He also added magnets to both the interior wall of the trailer and the inside of the hatch so that the door would stay open without any unsightly catches. Take a peek... you'll be glad you did! 94.gif
This post has been edited by Lisa H.: Jun 28 2009, 05:35 PM
+Quote Post
peterh
post Jun 28 2009, 06:20 PM
Post #12
RV Type:2005 Scamp 5th Wheel
QUOTE (Lisa H. @ Jun 28 2009, 06:34 PM) *
The Adding a Hatch topic I did last year is here . . . And thanks for the compliment, too. 4.gif
+Quote Post
AZCharlie
post Jul 29 2009, 09:12 PM
Post #13
RV Type:94 Casita Spirit Deluxe
The kind of insulated hatch shown is post #7 is available from the Casita factory. It costs about $75.00 including shipping.
+Quote Post
RSS Lo-Fi Version Time is now: 21st November 2009 - 10:58 AM
