MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> Wind Deflectors, Anyone have experience?
Roger C H
post Jun 14 2009, 02:15 PM
Post #1
RV Type:2009 American Trillium 1300 "Homelet" + 2000 Outback
Has anyone had any experience with wind deflectors?
http://www.jcwhitney.com/Roof-Top-Wind-Def...s/600001569.jcw
Are they worth the money?
We don't live in America, America lives in us.
Go to the top of the page
+Quote Post
Andrew Gibbens
post Jun 14 2009, 02:57 PM
Post #2
RV Type:
This isn't personal experience, but some tests were conducted back in the 80s when deflectors like this were popular in Europe - these were proper full scale wind tunnel tests by aerodynamicists, rather than claims by manufacturers.
These drawings show the actual profiles of the three test cases - you may recognise the outline of the then Volkswagen Passat car:
In the first and last cases, the drag coefficient is 0.53 while in the middle case with a deflector it is 0.45 - that's a solid 15% drag reduction and so you would expect a fuel economy improvement of at least 10%.
The other part of these tests was to measure the aerodynamic lift on the front of the trailer, as a reduction in hitch weight at 50mph. In the first case, the hitch weight reduced by 75 pounds which, compared to a typical low European hitch weight (typically 100-150 pounds), is very significant.
With the roof deflector, the reduction was 70 pounds, but with a slope-fronted trailer and no deflector, there was no reduction in hitch weight and so no reduction in trailer stability - this is the main reason why you will find a sloping front on just about every European trailer made since then.
Of course these results don't compare directly to typical American towing practice, but it does show categorically that deflectors can work well in the right conditions.
Andrew
+Quote Post
RSS Lo-Fi Version Time is now: 20th November 2009 - 06:06 PM
