MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
> "How To:" fiberglass repair video, Where to get?
Mary Lynn K.
post Jun 14 2009, 03:08 PM
Post #1
RV Type:Trillium-13'-1974-1300/ Burro-1986-17'widebody
Hi everyone!! - I have read many an article about fiberglass repair. However, I would prefer having the opportunity of actually seeing a video from start to finish. Most of the wedsites want customers to buy their DVDs. My next thought would be the library, but they are closed today. Any suggestions would be greatly appreciated.-
Go to the top of the page
+Quote Post
Joe Z
post Jun 14 2009, 04:55 PM
Post #2
RV Type:16' Casita SD
Start here ....It's free and try to pick ones with five stars.
Joe
http://www.youtube.com/results?search_type...rglass&aq=f
Joe & Linda
07' Ram 4 Door Hemi
94' SD 16'
+Quote Post
Mary Lynn K.
post Jun 15 2009, 09:29 AM
Post #3
QUOTE (Joe Z @ Jun 14 2009, 07:55 PM) *
Joe
Hi Joe: Thank you for the youtube site. I'll give a try.- Mary Lynn K. woohoo.gif
+Quote Post
curtis c
post Jun 20 2009, 04:15 PM
Post #4
RV Type:1994 lite house
just used the tap plastic gel coat today. Great product. however in the video he uses a piece of plastic to cure the top of the coating. in doing this on the first layer i found that if you slightly move the plastic it will create bubbles. on the second layer i used the hair dryer method. go with that it works great and no bubbles. i also found you have about 20 min of time after you mix catalyst so you have plenty of time. Also instead of having to do many coats. i found that if you coat a layer and then hit it with the hair dryer for a min or so it will thicken up enough to add a second coat with a liberally amount of gel coat on the brush. once again great product.
+Quote Post
RSS Lo-Fi Version Time is now: 20th November 2009 - 07:46 PM
