MFROG
Home
Forums
FGRV Map
Calendar
Donations
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
2 Pages V  < 1 2
> Easy Air Condition Option (May-be)
Lloyd (aka Santa...
post Jul 10 2009, 08:23 AM
Post #16
RV Type:2004 Ram-Cummins 2500 2wd, '79 Layton 22' (tinwall). But hey, the price was right, and Santa has to save money for the toys, right?
QUOTE (Bob Haelle @ Jul 10 2009, 08:45 AM) *
Eddie
How do I get into the area where trailers are for sale?
click 'forums' (left column), scroll down to 'for sale'
Go to the top of the page
+Quote Post
Roddy D
post Jul 10 2009, 09:50 AM
Post #17
RV Type:Scamp 16'
When I bought my 16' 1982 Scamp it had a stand alone AC in the closet next to the door. There was one exhaust hole with a venting louvered flap door and a drain hole for the condensation. I live in Texas and during the summer it gets hot! During the day the trailer was cool mid 80's with a fan stirring the air around. At night it was a little cooler but was very noisy. I think this is because the basic design of this air conditioner. I have since removed it and built a closet shelving system in the closet and put a quiet AC under the stove top next to the Frig. The temp in the trailer has averaged 78 when the temp was 98 outside. I also use a fan to stir the air in the trailer, I like the air movement.
Hope this helps!
Roddy D
1982 16' Scamp in progress
+Quote Post
Phillip
post Jul 10 2009, 06:31 PM
Post #18
RV Type: 13' Casita
QUOTE (Lloyd (aka Santa) Coltman @ Jul 10 2009, 07:21 AM) *
Philip, your offer of sharing knowledge is great.
Here's my problem: I have an old Duo-Therm 'Sunchaser' (13,000btu) on my unit, and anything under a 2.5kw generator has a real fight with it, although it works fine with a 15A household breaker. Looking at the schematic, it has no compressor start capacitor, while the later model 'BriskAir' has. The running specs are the same for both, but the 'BriskAir' seems easier starting. Most household refrigerators, freezers, and the 'BriskAir' appear to use a timed start relay and capacitor to reduce start current while increasing start torque. There are also 'hard start' capacitor kits that may even free up stuck compressors. What do you think of adding a start timer/capacitor from a fridge, to my A/C unit?
is it struggling on start up ?? or while running ?? a start capacitor will only give you a boost for a fraction of a sec on start up.. if this is your problem a Hard start kit can be added very simply .. most units have a duel run capacitor the booster kit has 2 wires.. they are installed on the run capacitor if its is a duel capacitor it will be mark as follow Herm/ Fan /C
You attach the 2 lead from the booster to (Herm/C )..
I wouldnt attempt to use a part from a fridge on my A/C... 76.gif
This post has been edited by Phillip: Jul 10 2009, 06:33 PM
+Quote Post
Lloyd (aka Santa...
post Jul 12 2009, 01:11 PM
Post #19
QUOTE (Phillip @ Jul 10 2009, 07:31 PM) *
I wouldnt attempt to use a part from a fridge on my A/C... :nono
Ok, here's a further report. This weekend a huge group of us were dry ( I use the term loosely, we ran the river, rapids and all) camping. One of the guys had a Yamaha EF2800i, which runs his A/C (13,500 BriskAir), converter, and fridge, with no problem. On our unit, with fridge on LP, his generator ran the A/C for about 4 min, and kicked off (overload shut down). So, maybe my A/C is drawing a lot more than it should, although it will run for days, at home, on a 15a household breaker (1800Watt), with converter and fridge. The home supply has about 70ft of # 14, from the main panel, plus about 30 ft of # 10, so maybe the long feed has the effect of limiting the current a bit? Many years ago I had a table saw that would blow breakers, if plugged directly into an outlet, but at the end of a 25' extension, it was fine.
This post has been edited by Lloyd (aka Santa) Coltman: Jul 12 2009, 02:48 PM
+Quote Post
Lloyd (aka Santa...
post Jul 12 2009, 03:12 PM
Post #20
This looks exactly like what Dometic did on the the later BriskAir. That, along with a separately controlled 3-speed fan, seem to be the only differences. Do you have any idea what the values are on the 'hard start' capacitor? BTW, my old A/C works just fine with my old (1978) Honda industrial generator (rated 3600, max 4500watt), but I'm sure, if it was close camping, somebody would shoot me (because it's a thundering beast). Not just exhaust, but mechanical noise too.
My next test will on a spare later model 'BriskAir' 13,500 with a 'Mitsubishi' 1800 watt max rated generator that I have. If that comes close to working, there'll be an A/C change in the works, because I want a smaller, quieter, lighter generator
This post has been edited by Lloyd (aka Santa) Coltman: Jul 12 2009, 03:16 PM
+Quote Post
Phillip
post Jul 14 2009, 09:11 AM
Post #21
RV Type: 13' Casita
QUOTE (Lloyd (aka Santa) Coltman @ Jul 12 2009, 03:12 PM) *
The spp6 will work on any A/C from 1-5 tons... cost at a part house around $30
But if it runs for 5 min then shutoff this wont help it.. IMHO..it is only good for Start ups..not during the running cycle..
It sounds like you may have bearings in the compressor that maybe getting rough and causing it to run a higher amp draw than normal... you might also make sure your condenser is good and clean,A dirty condenser can also cause a some what of a higher amp draw on a hot day..
This post has been edited by Phillip: Jul 14 2009, 09:17 AM
+Quote Post
Lloyd (aka Santa...
post Jul 14 2009, 12:48 PM
Post #22
[It sounds like you may have bearings in the compressor that maybe getting rough and causing it to run a higher amp draw than normal... you might also make sure your condenser is good and clean,A dirty condenser can also cause a some what of a higher amp draw on a hot day..
[/quote]
Then it definitely sounds like a change-out is in the plan. Strange that it will run for days on a 15Amp(1800watt) household breaker, with converter and fridge, without 'popping'. It was the 'overload' on the 2800watt generator that popped, not in the A/C. The test was run at 11:00am, temp about 70f. Oh well, I like the idea of the multi-speed fan anyways, just need to get the proper ceiling unit (it was set up ducted, with remote thermostat, not self-contained, and the plastic finish cover was melted by a flash fire). Thanks for the tips, you've been a lot of help. Maybe I'd be wise to run a draw test on both units, too.
+Quote Post
Phillip
post Jul 14 2009, 01:30 PM
Post #23
RV Type: 13' Casita
QUOTE (Lloyd (aka Santa) Coltman @ Jul 14 2009, 12:48 PM) *
h84.gif that would be a good idea...something sounds fishy but without being there its really hard to say..
+Quote Post
Lloyd (aka Santa...
post Jul 14 2009, 04:33 PM
Post #24
QUOTE (Phillip @ Jul 14 2009, 02:30 PM) *
How come you've got my picture on your reply?
+Quote Post
Pamela H
post Jul 15 2009, 07:01 AM
Post #25
RV Type: 1960 28' Airstream, 1982 Burro
QUOTE (Eddie Longest @ Jun 15 2009, 06:24 PM) *
I just got home from Wally World after wandering around the store while the wife shopped. In the hardware department I found a small Hailer 7K BTU self contained floor A/C unit. The unit is much smaller than any self contained floor unit I have seen, 18"W, 13 1/8" D, 24" H. I measured my 13 Scamp closet and it will fit in the closet by only cutting the door opening one inch wider and you should still have about an inch clearance on either side inside the closet and plenty of room for the depth. All you should have to do for an outside opening is cut a 4" or 6" (Not sure which size.) round exhaust hole in the side of the trailer and cover with a small grille. Of course you will have to fabricate supports to hold the unit in the closet and provide power. I'm not quite sure how the condensate is dealt with on this unit but even if it collects in a reservoir you could easily fabricate a drain hose. The unit sells for $299 at my local Wally World and it comes with a remote control. It's higher than a window unit but may be well worth the extra money in ease of installation. I did not open up the unit and I got all my information from the outside the box but if I were considering installing an A/C in my Scamp I would definitely take a look at this unit.
You don't by chance have the SKU number on that unit, do you?
(The SKU is the number under the bar code...)
Pam
+Quote Post
Lloyd (aka Santa...
post Aug 20 2009, 01:26 PM
Post #26
Sorry, but Santa's back to ask more questions. I've been monkeying with my A/C again, and I've come up with more symptoms. The other day, I tried to run my A/C after completing a mod to remove an UGLY toggle switch the previous owner had put in to give option of continuous run on the A/C fan. I removed the switch, and spliced the wires together. Then I installed a regular light switch in the power junction box (next to A/C). Now, I set the thermostat to warm/off, and turn on the "light switch" to start fan. After about 10 seconds, I set the thermostat to cool, which starts the compressor. Next day, in the heat of the sun, after about 5 sec of running, I popped the 15A breaker in the power bar I have feeding the trailer. I took that out of the circuit (wasn't there before). Now, if it's less than about 75f, the A/C will start and run just fine. However, if it's in the high 80s, and the sun has been beating on the A/C for a while, the compressor struggles to start, and usually blows the house breaker (15A). Now, if I run the fan for about 15 minutes, lowering the temp in the housing, then start the compressor, the A/C will work fine for an indeterminate period of time.
+Quote Post
Darral
post Sep 25 2009, 12:00 PM
Post #27
RV Type:none
Phillip,
I hope you're still around to comment on this, but do you feel there is enough room on the outside of the A/C or in the "storage area" of the Scamp for sufficient cooling of the condenser coils and compressor??
I'm not sure what the fuss is about on the other....it's simple that those A/C's pull air through the bottom/front and exits it cooled at the top/front. But again, I'd be more concerned about the exterior portion getting enough air to keep from damaging the A/C's compressor. Am I missing it totally here from an 'inexperienced' A/C guy??
Thanks in advance,
Darral
QUOTE (Phillip @ Jun 16 2009, 02:31 PM) *
I'm a Heating an A/C Tech...You need to have intake air for the Condenser from the outside... and also a separate space for Exhaust air from the Condenser for it to work properly... this is what is done in mine... mine is located under the front bench with supports on both sides and air intakes on both sides under the bench and exhaust air out the filter grill in front..This seems to work very well..this is a semi permanent solution... as for road grim I just open the front grill and insert a piece of plexi for traveling the keeps the rain or debris out ....it can be removed in just seconds and the A/C is ready for use... Just another Idea ..I fixed the unit so it doesnt move any and helps add support under the front bench ... other wise at least 2/3 of the unit needs to be mounted past the exterior of the shell (Window/hole) or the return and supply would need to be ducted from the outside in some fashion..
+Quote Post
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 21st November 2009 - 02:32 AM
