Full Version: Added Generater Box
Legacy Posts
I thought I would share a modification I made to my Casita. The Casita came with two propane tanks. The weight of each full propane tank is about 48 lbs.
I chose a Honda eu2000i generator because of the weight 49 lbs and the noise level is very low.
My new box...
Legacy Posts
Open Lid
Legacy Posts
Inside the box...
Legacy Posts
Note the little hole for the exhaust...
Legacy Posts
If you look close you can see the little front door to access the pull rope to start the generator.
Also, there is a 12 volt fan in the bottom to keep the air circulating and thus keep the air cool in side. It only runs when the generator is running.
Legacy Posts
Nice job Michael,
Really a nice piece of work. Just keep Charles away and make sure its locked.....
Legacy Posts
A generator really does seem a good idea to me, and yours looks like it was made for our little trailers.
Can you run a three-way fridge from this? ... and all the electrical lights, microwave, etc. from it? As you can see, I'm new to all this. I'd like to think I could just switch my system to AC and run it from a generator such as yours here.
Legacy Posts
Floy,
Yes, you can run anything from the generator. One word of caution. You can only run one of the big ticket items at a time; like microwave, heater, airconditioner. To use the microwave, we turn the airconditioner off for the 3 or 4 minutes we are using the microwave. We put refrigerator on propane when we need to use the generator.
I hope this helps.
Legacy Posts
Now I'm embarassed for posting the pictures of my Watt Box in another thread :red
Nice box, Michael. Did you fabricate it, or buy it?
It looks like diamond plate aluminum, but where did you get the corner molding and what is it? Are the corners welded?
Legacy Posts
The sides are made from 1/16th inch aluminum diamond plate. The frame is made from 1 inch steal angle iron. I welded the frame up and then smoothed and filed with bondo to make it look good. I painted the frame with marine boat paint and used stainless steel faseners to put it together. The piano hingers are also stainless.
There is no bottom so that propane cannot get trapped inside and it will run cooler. I think that is about it.
Legacy Posts
Legacy Posts
Michael, the more I look at this great generater box, I keep wondering if I could make something like that out of exterior grade plywood and paint it. I know that it won't be as sturdy or durable as the metal but wonder if it would hold up 'well enough.' I'm thinking of making one that will house both propanes and have a little tool storage in the front. Either that, or build a small one and move the battery in front of the propanes.
If properly primed/painted and I use angle iron on the corners, do you think it would hold up?
Legacy Posts
QUOTE
Orginally posted by Suz
Sure. I made a camp stove that way and it has lasted over ten years and still looks good. The main reason I used aluminum is that it doesn’t rust and I thought it would look good.
The aluminum diamond plate is as easy to work with as plywood, just a lot more expensive.
Good luck on your project. :)
Legacy Posts
Suz,
I got to see the Mike Box on Boxing Day and let me tell you, it is a work of art.
You might consider a thatched box. I'll bet Dena would send you some palmetto fronds. Add a tropical touch. :laugh
Legacy Posts
if there is no bottom, how does the honda stay in, and wouldn't you get road slug thrown up into it? :)
Legacy Posts
>>Michael wrote: The aluminum diamond plate is as easy to work with as plywood, just a lot more expensive.
Does that mean I can cut it with a jig saw using a metal blade (and ear plugs)?
Morgan, I really like your idea about the thatched box. What I'd really like is one of those old european wicker laundry baskets. Now that would be cool. Wouldn't hold up worth a dern, but would look great until it fell apart on the first trip! ;)
Legacy Posts
QUOTE
Suz,
Looky, looky
http://store.yahoo.com/truckstuffusa/chaltrailutb.html
I have no idea what size you'd need.
Legacy Posts
Hey, Morgan, thanks for that link. That looks pretty good. I wonder if the bottom is solid...if so, I guess I would have to vent it someway....
Legacy Posts
Oh! shucks, :sad I thought it was a basket box dipped in concrete or something. :u
Legacy Posts
QUOTE
Cut holes and put in louvers (louvres). That would keep JJs road slugs out. :wave
Legacy Posts
Michael,
Truck Stuff has an affiliate program:
http://www.x-stuffusa.com/TSUSA/affiliate_program.htm
Suz,
Don't order 'til Michael gets signed up and until you measure. I posted that link to show that there are some boxes ready made. There may be others that cost less and are a better fit. Use Google.
Legacy Posts
bobber/dobber= dauber
so slug = road junk = sludge.
English is a difficult language :)
Legacy Posts
I sure don't see a problem with it...I understood exactly what you meant...ah, maybe the problem is mine since I understood ;)
Legacy Posts
QUOTE
I understood and I sure don't have a problem. :nono
JJ, you just keep using your sonic spelling. Your English is much better than my Lenape. We can figure it out, I was just tweaking your leg. :sporty
Legacy Posts
well I should hope so, :omy tweak away. :reye2 and to be honest,:L I was tweaking yours back, so there you are/go. (I'll admit spelling is my downfall, but some of it ends up pretty funny.)
Legacy Posts
This may be of help:
http://www.iespell.com
It is free software that will spell check from within Internet Explorer.
Legacy Posts
I'll have to think about that, Ken. with all the computer trouble I've had lately, I'm afraid to load stuff just yet. at the moment most of my spelling problems are using the wrong word. since/sense/cents. :o does it have a thesaurus?
Legacy Posts
QUOTE
Orginally posted by Thomas and Janifer
What's that, some kind of dinosaur? :chased
Ken, I tried iespell and it may have caused a rash of system crashes. Haven't crashed since removing it.
Legacy Posts
Suz,
Try these links:
trailer tongue toolbox
another trailer tongue toolbox
