Full Version: A Project Begins
Legacy Posts
The attached photos represent the exterior conditin of the trailer as I found it in a salvage yard. And the project began. More to follow, Fx.
Legacy Posts
:omy Oh man, you've got your work cut out for you.
I know it is all fixable though. I repaired a canoe that fell off a car and hit a guard rail. When it was done you could not tell it had ever had a hole in it the size of a basket ball. It was as strong as new as well.
Keep us posted as you make you repairs. Show pistures as you go.
Legacy Posts
Wow, Charles really did a number on this one before he sold it. Course I thought his was a Casita. Frank, are you doing the fiberglass repair yourself? Is all the stuff still inside? (yeh, I know, I'm just a little nosy)
Legacy Posts
Yes, I have been doing the fiberglass work myself. Over the last thirty years I have been involved in racing sailboats, and the need to correct fiberglass dents, (always caused by others, naturally) has been included in this avocation. Glass is one friendly medium to work with. Remember DRY, CLEAN, and MODERATE Temperature and the modern resins and hardeners make it idiot proof. Tho I can still find a way to spill the resin bucket or allow the errant drip to find my body hair. New words are often then expressed, women and children beware.
The interior pieces were all in place, or close to it. The cabinet doors were distressed and the flooring in general had suffered from water, both before and after the accident. Don't know the previous story of trailer or about accident. The salvage yard had acquired trailer from insurance company for storeage charges over two years ago and were very glad to free up the space. No serious frame damage only one rear fram member bent downward, no side twist or cracking. Will send more photos of work and findings, Fx.
By the way don't blame Charles, this tree had indications of red surface coating. Besides only sociopaths don't learn from their mistakes or actions. So you won't be committed always do a new bizarre act, and let the public try to catch up.
Legacy Posts
and its as good as new Frank....
Legacy Posts
Frank>>don't blame Charles, this tree had indications of red
Could have been one of those sneaky Red Oak trees.:) :)
Keep us posted of your progress Frank!
What year is the Scamp?
Also, just curious here ... but does the trailer have an actual title ... or do you have a salvage title.
I'll bet you'll have it back on the road in no time!
Legacy Posts
I'm moved to say what I say to people who have just adopted a pet from our local animal shelter: You just saved a life!
Way to go, Frank!
Legacy Posts
To Charles, the possibility of "sneaky red oak", didn't occur to me. My thoughts were more like Dodge Ram red, both for the vibrant color, and the height of collision hard point damage. The title is a regular trailer title, since it was sold to yard as settlement of claim, (storeage fees,) not a totaled-wreck.
Having followed both the Casita and Scamper Yahoo sites, I was familiar with Charles eloquence about his waxed bottom, and reasons for same. When my initial appraisal of damage showed the floor being more like dust than structure, I copied within the format of the Scamp design constraints and using both 3/8 exterior and marine plywoods I applied fiberglass cloth to all bottom surfaces. the cloth was filled with two coats of resin till all mesh pattern disappeared. The two layers of 3/8 ply were then bonded togeather with a filled resin mixture and mechanically fastened for curing. The new floors were bonded to frame with heavy duty construction adhesive and hardened screw fasteners designed for applying sheathing to metal framework.
I can now wax my fiberglass bottom and have the glow of wood reflecting in my satisfied eyes. Time permitting that is.
My main thought was to eliminate the chance of water penetrating the wooden floor structure, so all edge grain was soaked in resin, all trailer side to floor joints were tabbed both top and bottom with 8 oz. tab-matting. After the bottom tabbing was completed a slurry of resin, heavy filled with Cab-o-Sil, was applied between trailer glass sides and the floor. It was leveled to floor, before top, (inside,) tabbing was completed. The weight of plywoods and fiberglass is within striking distance of the original fiberboard with resin coating weights.
The atached photos represent the last of suprises found during de-construction. Notice the care of electrical circut breaker installation. This is how I found it when removing the sink cabinet. The pictures of entry floor damage was caused by the lack of drain tube routing for closet mounted airconditioner. The condensate was allowed to pool against the outside vent, or run down the inside of exterior wall, traveling both to the lower storage cabinet and between closet wall and entry floor soaking the carpet and attacking the floor materials. Enough for now, more to follow, Fx.
Legacy Posts
Please don't be shy with postings on your progress.There are many of us attempting to perform much less complicated restorations on a variety of trailer types that are following your progress with great interest.In fact from past experience sometimes the visual clues presented in projects such as this give the incentive to try something a bit beyond the norm.Thanks
Legacy Posts
With all the interior and flooring out work on the bent frame member was finished. Simple hydraulic jack and chain procedure until original vertical alignment was held. Then wire brush all frame members of loose scale, tedious, and recoat with RustOleum.
As previously stated all flooring materials coated with fiberglass layer on bottom side. Then first 3/8 ply was attached to frame with construction adhesive and mechanical fasteners. Next second layer of 3/8 ply was attached to first, (overlapping seams,) with mixture of thickened resin and mechanical fasteners. All edges were liberally coated with resin and all seams for both layers were glass/resin taped. this brought the new sub-floor up to the original 3/4 thickness of particle board. The final flooring material will be parquet with strip edges so main floor area was not top coated with resin, except for edges and at door entry area. More to follow, thanks for your followups, Fx.
Legacy Posts
Man, Frank ... you should consider starting your own molded Fiberglass travel trailer company!
I also know now where I'm going next time a tree jumps out and smacks me ... we don't live that far from you!
Sounds like you've got all of the bases covered. I'm enjoying watching the project unfold!
PS I'm sure you've thought of it, but make sure you coat the edges of all the dump valve and gas line holes through that beautiful new best of both worlds floor before you run the lines!
A frame-off restoration! Wow! Take a bow!
It will be better than new when you're done!
Legacy Posts
Charles,
Thank you for the thoughts on any fittings or lines going through the floor. My practice for these is to drill an oversize hole, tape the bottom side shut, and fill with a medium viscosity resin mixture. This allows penetration into surrounding structure, then when cured I drill the correct size hole through the resin and run lines with caulking above and below. I become anal with wood and water, once is enough. More pictures of the basement storage compartment I built behind axle to follow, Fx.
Legacy Posts
Now that evening has fallen I can spend a few moments bringing the last photos of finished work to the forum. The finished sub-floor is installed front to rear. All side cabinet floors have fiberglass tops and bottoms, I don't like water damage. And I even have accomplished a fun task, the Scamp basement.
After haveing looked at the right rear storage area or loss thereof when the water tank is installed I built a lower compartment to house this tank. The basement starts at the rear floor step-up and goes across from the inside of each frame rail, and back to the left/right angle member. The total compartment is nine inches deep, forty-five inches wide and twenty-two inches long. The water tank area is the same depth and width but is only fourteen inches long. A divider seperates the water tank area and the floor then slopes upward to the rear angle member. This angle gives adequate ground clearance for backing, before the tires start to climb, unless I really off-road it. The basement bottom is actually higher than the bottom of the axle housing in a normally loaded condition. I will have access to run plumbing for both water feed and supply lines inside basement and up through setee cabinets and then to destinations. The area between tanks will allow for the 12V supply pump to be mounted. The capacity is two six-gallon tanks, that can be removed at any time. I will use shut off valves on each for control of water use.
The construction of basement was steel angle material with glassed, both sides 1/4 plywood, assembled and then all glassed togeather after fitting into frame. The fitting was done before the rear step-up floor was installed. The access is by a drop in finger board that is twenty inches wide and twenty two inches long. The outside bottom was heavily coated with the aerosol truck bed liner repair coating material, just in case.
Now I have to complete the interior redo before new photos, Fx.
Legacy Posts
Hey mom, dad:
... can Phrank post :cblob BIGGER :cblob photos of his phenominal phix?
This looks like one SUPER project.
Legacy Posts
Frank,
When you're finished with this fabulous project.
Could I bring my Burro over so you can put in a basement?
What a great idea!!!!!
Legacy Posts
Pjanits, aka "Pete"
I was lucky in that the floor had to come out allowing adequate access to the frame for installation of the basement. This would have been a bugger of a job otherwise.
The visual picture of area used is from behind the settee step-up at rear of Scamp going left to right forty-five inches, the water tank compartment extends towards rear fourteen inches, with the balance of basement sloping upward toward a left/right frame member for a total of twenty-two inches from front of basement to rear of same. If you are interested in the possibilities, let's talk about the frame design characteristics you have.
I have a question for you. How did you actually acquire a Burro? I followed over the last two plus years the sad legal saga of that companies ownership and its' business practices. Most respondents were disappointed in what they received, if anything. It looked like the next generation design with modular interior used in a pre-stressed manner for structural integrity. The best always, Fx.
Legacy Posts
Frank,
My Burro is an 1981 13'. I lucked out by finding it for sale locally.
The factory in 1981 was in Plymouth, Minn.
So all the current problems are moot to me.The quality was excellent.
By the way the floor is wood, but coated with fiberglass on both sides, after 21 years no soft spots!!!
Yes, I agree, that the design is an improvement over the original,no rivets to deal with and the inner shell gives the option of adding insulation(which I do not have but have been thinking about using foam once I have wired everything to my liking.)
If I had money I would buy that company and add a few more improvments and sell a really dynamite trailer.
But alas! I have no money, hence the used Burro and not a new Casista 17'
Legacy Posts
Pete,
Before you use foam, please check the foil with bubble insulation sold by the big box stores, (Home Depot and Lowes), it is used for pole barn type buildings and comes in roll widths from 24 inchs to 48 inchs. The thickness is approximately 3/8" with foil both sides. This is very near the insulation used in my Scamp from factory. Very flexible, easy to cut, and apply with water based contact cememt. Your then use foil tape to seal seams. Good luck, Fx.
Legacy Posts
Frank,
I don't think that will work on the Burro, my thoughts on the foam was to get it between the outer and inner walls ( yes I have two walls- that's why there are no rivets). The factory adds sheet insulation when bonding the halves together, once they are glassed togther there's no going back.
Legacy Posts
Oh, Pete
I do love that Burro of yours. Do you only sell too friends too? I could be a friend.
PS, dont tell Surfside I said this.
AND
Hi Frank, It's me again.
I don't think the production problem of Burro was a problem until around 98, and then it depended on the person putting it together. There are some great Burros out there.
Legacy Posts
Frank you must be as tenacious as my Jack Russel! Keep up the good work.
Legacy Posts
Hi Frank,
It's fun to see pictures of a Scamp stripped. Now I know what mine must look like under all that carpet, etc. What floor plan will you have when your finished? Back dinette? Side dinette? Bathroom? I couldn't quite make out from your interior photos what the original configuration was.
You're doing a great job reporting your progress. Kinda like Bob Villa's "This Old House".
Keep up the great effort!
Legacy Posts
Say Frank,
As long as you're stripped down how's about putting in a push out dinette like the big boys have? Just think of the room you'd have.
Sure Janifer I can be your friend, but I won't sell the Burro. I have become too attached to it now.
Legacy Posts
The original Scamp floor plan is rear dinette with side closet. When I finish the side closet will have the Scamp Toilet/Shower assembly in place. Nothing unusual about mine except that I kinow each and every seam, spider and frame member more intmately than necessary.
Now Pete, I thought we acquired these little wonders to escape the mines bigger than yours syndrome, When this possibility strikes my fertile brain, I fall back on a consversation overheard at a campground between owners of two "A" type diesel pushers, each was claiming bragging rights about their grey water holding tank capacity. Lifes to short, let's enjoy the outdoors togeather.Fx.
Legacy Posts
With the onset of Michigan's winter I have been having some fun with the interior components. The original interior condition of my trailer had been modified by the previous owners accident. The laws of physics will not be denied, they had taken an apartment refrigerator and placed it loosely in the cabinet designed for the factory refer. The only mounting point used was to fasten molding around the outer corners to keep it from falling out onto the floor. when the trailer was struck in the drivers side rear corner the energy path took the refridgerator and shot it upwards and forward breaking the front of the cabinets glass work, breaking the stove out of its' mounting points and dislocating the furnace. The rear wall, towards the seating area, of the cabinet was shattered inward by the movement of the rear seat as it pushed forward. The refirdgerator was jammed and twisted in such a fashion it was only after removing the cabinet from wall that it could be extracted.
I am attaching phots of the "as found", "the fun of glass" and a last set that will probably need a second messasge, file size to send.
All work was easily done with glass mat on inside, some strategic reinforcement with 1/4" plywood and glass on inside in structural areas, and the fill of original stove top and blend same into work surface of original cabinet. I plan on installing at a later point a two burner stove top replacing the destroyed three burner unit thus freeing more countertop for more work surface. Keep your powder dry, Fx.
Legacy Posts
This upload will show the finished cabinet, sans doors. After glass work was finished, two coats of Interlux white epoxy primer was applied, then two coats of Interlux "Brightsides Polyeurthane" in Hattaras off-white was applied as finsih color. The method of application was sanding with 320 grit between all applications, and using the foam roller with brush tipping method of painting. This results in a very nice smooth surface. The final step after installation is to rub out with very mild polishing compound for any surface problems. Fx.
Legacy Posts
Fantastic job, it looks brand new.
Legacy Posts
:wave
Frank, wow, you could shave in those counters. I know nothing about fiberglass but I am about to learn. Your pictures makes me believe the impossible will take just a little longer.:)
Thank you for sharing your pictures.
Legacy Posts
Reply to Pat G,
The high gloss reduces after about two days to a low luster. I just had to take pics of the fresh look after seeing so much dull filler disappear.
Have fun with your glass work. The group following this site have much to offer in solid advice, and they even do it with a sense of humor. Good luck, Fx.
Legacy Posts
:) Hey Frank,
Good work on the remodle looks great. We have a mold problem in
our 13' Scamp (I believe it to be just like your scamp) and I think
it is due rain when the windows were left open but moisture must
have gotten behind the carpeted walls and now we have a mold problem and it smells. Is is possible to take out the carpet and insullation replace the insullation and put up wood wall paneling. or will this open a bigger can of worms. We would like to keep the scamp and I
believe that we might be able to handlea job like this.
I would like a small break down of what we need to do or things
we should know about before we start!!! Like how to figure sq ft. how do we attach the panel. If you could or know someone who will Please let me know.
Legacy Posts
Dawn,
I would try a simple approach first, before trying to fit sheet paneling to the multiple complex curves of our molded type trailers.
If you have the teddybear fur type of interior "carpet", this is a type of marine spun polyethelene fiber. It is not backed, and is only press formed into flat form during manufacture. It will hold various forms of dirt and bacteria, but its' material composition will not normally allow for this debris to bond. I would first try cleaning the carpet by using a "Quat" based sanitizer mixed with water. You should be able to obtain this from any bar and restaurant supply house. Tell them you want a liquid third sink rinse "QUAT" based sanitizer. If this type of supply house is not available, a pool supply will have this sanitizer in a more concentrated form that they use in pool water treatment.
The label should list Quaterinary .........Chloride, as one of the first active ingredients on the label from either source.
You want a mixture of no more than one ounce per gallon of water for you application. I would take a garden type pump sprayer, mix my sanitizer with water, and spray all surface areas wet. Allow to set for approx 15 minutes. Then using a rental carpet extractor cleaner with the upholstery cleaning hand wand and suction hose, use the same sanitizer water mix and reapply to all carpet surfaces while sucking dry the surface with the extractor recovery hand wand. When this work is done put a portable dehumidifier inside closed trailer and allow it to run for at least 24 hours. The foil backed insulation that Scamp used since the mid 80's is merely a layer of foil against the fiberglass, a bonded layer of air-cell insulation, and a layer of foil against the back of carpet. The seams of this are taped with aluminum foil and in total should be watertight.
I believe that your mold is retained within the carpet surface and you can kill it with the sanitizer, and remove the remains with the extractor. Good luck, Fx.
Legacy Posts
Thanks Frank,
I will defininatly try that. I have a friend with a pool cleaning business.
I'll let you know how it goes.
Dawn
Kristi Warner
QUOTE
' date='Oct 22 2002, 05:17 AM' post='133818']
As previously stated all flooring materials coated with fiberglass layer on bottom side. Then first 3/8 ply was attached to frame with construction adhesive and mechanical fasteners. Next second layer of 3/8 ply was attached to first, (overlapping seams,) with mixture of thickened resin and mechanical fasteners. All edges were liberally coated with resin and all seams for both layers were glass/resin taped. this brought the new sub-floor up to the original 3/4 thickness of particle board. The final flooring material will be parquet with strip edges so main floor area was not top coated with resin, except for edges and at door entry area. More to follow, thanks for your followups, Fx.<img src=http://www.fiberglassrv.com/board/uploads/3db5179341273FRAME-FLOOR gif.gif/>
What do you mean by "mechanical fastners"? Clamps that are later removed? Please enlighten. Thanks.
Frederick L. Simson
QUOTE
QUOTE (Kristi Warner @ Sep 18 2006, 05:44 PM) *
Kristi Warner
QUOTE (Frederick L. Simson @ Sep 18 2006, 10:01 PM) *
I know this one.....thanks to my ex-cop friend....glued, screwed and TATTOOED!!!
