Full Version: Wind baffle for water heater
Legacy Posts
I just installed a wind baffle on my water heater door on my Casita.
The last few outings, the water heater pilot blew out several times. Not being wealthy, I thought I'd try a wind break before springing for a re-igniter.
I fashioned the baffle from a double thickness of 6" aluminum flashing cut to 11" length. At each end I made a ½" 90º bend then 1" from that I made another 90º bend. The finished product is 8" wide by 6" high and it is 1" away from the vent screen. I put one rivet in the center to hold the two pieces together.
The first photo shows the finished baffle and the tape I used to install it. The second photo is a closeup of the baffle mounted to the door. The third is the water heater door showing the baffle in place.
I'll let you know how the tape holds.
Legacy Posts
Morgan,
I think I would buzz a couple of sheet metal screws in from the inside.
The tape alone may be iffy.
When I had a stationary 28 foot stick thing, my water heater would blow out from the wind too. It funneled into my site just right, even with a cover like yours it still went out, some days several times.:sick
When I moved the trailer to Wisc. the setup was just right I guess, because it never blew out again.
Now I don't worry cause I don't have hot water in my Burro.
sniff,sniff:weep :weep :weep
Legacy Posts
QUOTE
Orginally posted by pjanits
            Morgan,
Thanks Pete,
I'll let you know how the tape works out. If it doesn't hold, I'll use rivets. I may find the aluminum is too flimsy also; it's a prototype.
Legacy Posts
You do nice work!;)
Legacy Posts
nifty idea! I like it.:)
Perhaps you could drill a couple of holes in the front big enough for a screwdriver shaft and fasten it with screws that way.
(or is that a no-no for fiberglass integrity?)
P.S. That workbench looks kinda new - did you have to buy that to hold the new mod? :E :E *just kidding!*
Legacy Posts
QUOTE
Orginally posted by Suz
            You do nice work!;)
Just not much of it. :bed
Legacy Posts
QUOTE
Orginally posted by Rick
Rick,
The water heater door is sheet metal. I can rivet from inside the door if need be. I just have to get small enough to fit in the compartment. :laugh
The work bench is new, I bought it to hold my outboard motor. Those top planks pivot up 90º and clamp together. It works great as a sheet metal break, too. It cost US$16 at Big Lots. :banana
Legacy Posts
I found that Home Despot does not carry the VHB tape, I bought it at Lowe's.
Sorry for my lying ways. :hide
Legacy Posts
We took the Lazy M camping for three days starting on Boxing Day.
The 3M VHB tape I used to mount the wind baffle worked flawlessly. The water heater went out once, so the baffle may need work.
We didn't go very far, but we were off-roading some.
Legacy Posts
Morgan,
I've looked this thread over, and I can't find where you said if you were moving (the trailer, not you personally) or not when the hot water heater goes out. I read somewhere you weren't to travel with the ref on propane, so I assume the w/h shouldn't be on either. having remembered all this, I surmised you were parked in the beautiful lake spot when this w/h incident happened?
BUMMER :sad what a way to deteriorate a perfect time.
Legacy Posts
QUOTE
Orginally posted by Thomas and Janifer
Morgan,
JJ Pullstrailerwithyellowescape,
Thanks for the concern, but it's not a big deal when it goes out. I just relight it. That's not so easy when the wind is blowing into the compartment, but to paraphrase an old Indian friend, I endeavor to persevere. Before the baffle, it would blow out several times a day during windy conditions.
Your surmission was correct. I always turn off the water heater when traveling. I sometimes drive with the refrigerator running on propane. One has to remember to turn it off during a refueling stop.
I surmise you're not hung over from all your New Year revelry last night. :sick
Legacy Posts
Na! :nope I made it last night just fine. all that -partying- didn't last long. Getting ready for the big game today almost did me in though. Livingroom TV was about to blow, so bought a new one. and of course it was bigger, so had to have a new cabinet to put it on. getting all that off the pickup and set up, I'm exhausted. :zz good thing I only have to do that once every twenty years. why didn't I do that when the kids were here? :bh
