Full Version: 86 Casita 16'
Legacy Posts
Last June I bought my 86 for $600, no I stole it! It did need a total redo though. I removed everything from the shell and the shell from the frame. Sanded and painted the frame and started putting everything back. Everything in the shell save the fiberglass had to be reworked.
Here is a shot of the rotten carpet. I got about a third of it up with a shop vac!
Here is a sample of the condition of the metal parts. These were hinges at one time.
Another shot of what I found under the bench where the water tank and converter lived.
This is a shot of where I am now. the tables and wood work are temporary. I'm making new cabinets and table tops out of oak plywood.
A final ,shot of the other direction.
Its been a job but I've really had a blast. Another subject though, How do you get the largere pictures I see in the posts and stay under 80k?
Lanny
Legacy Posts
But to answer your question about the picture sizes:
The resolution should be 72 dpi. That'll reduce the file size.
Also, when you save as JPEG, you should have an opportunity to specify a high quality image, normal quality, or basic. (On the program I use now, I actually have a 1-10 range of choices; but, the program I used before specified as high, medium, low.)
''High'' quality (increases filesize, and) isn't usually necessary for posting to the web, although I do run a pic through a ''sharpen'' filter before saving it. :o
Legacy Posts
Lanny, you have done a tremendous job. Congratulations!
I also have a problem reducing the byte size. I can reduce it down to the proper size, but the bytes always get me. With me it is a combination of the program I use and my ignorance. :o
Legacy Posts
The interior looks great. I love the fact that you still have rear views even though there is an AC unit in the window. Wish I were that handy. Although capable, once I hit a certain age I started getting manicures and there is just so much I'm willing to do now days.
Maybe when I trek out to UGA I can stop by and peek? (Hint, Hint)
Benita
Legacy Posts
Hey Benita, Saw you are in Roswell. I used to hunt down by the river on Roswell road. I grew up in Atlanta. Give me a few more months to finish the wood work and I'd love to show it off. Here is a better shot of the interior.
Lanny
Legacy Posts
Great Job----I love seeing photos of peoples talent.Have fun with your new rebuilt FIBERGLASS Rig:wave
Legacy Posts
Sorry Benita, any idea why my photo's didn't come through. I'm new at this. Could you tell?
Legacy Posts
lanny for some reason the jpeg or gif are missing on the end. hit the edit button and redo the pictures making sure the ending is there. or maybe Michael or Mary F or some one can fix it for you.
Legacy Posts
I don't know about the endings. They look fine to me. Both end with /> Could the name be to long? can I have spaces in the name? I work on a mac and it allows some things a "real" computer doesn't.
Lanny
Just kidding, I love my Mac!
Legacy Posts
We problably need to be in a different place here, but I can alway delete when we get through.
I'll try to do an example.
(img)http://www.fiberglassrv.com/board/uploads/3df3e4e151189Monopoly_dog.gif(/img)
see the gif just before the last img. this what I mean. I have the wrong brackets, so this should't show a picture
Oops forgot -no spaces
Legacy Posts
QUOTE
Orginally posted by Lanny Webb
Lanny
Lanny, I l;ove Macs too as you know. For the Internet, you need to make sure you use a Unix or PC naming convention. Also, on Macs in Photoshop, you can have the program automatically add the proper file type. So you photo needs to be name with either .jpg if it is a Jpeg or .gif if it is a GIF format.
And yes, NO spaces in the file names.
Legacy Posts
Well, it was one of several things. Name too long, spaces in the name, and (" ) marks just before the .jpg.
Now I know, thanks to all. I wish, after all the help I had to get to get them posted, I'd had better shots.
Lanny
Legacy Posts
Oh!! come on Lanny,:) the pictures look great. :jump-r and now your an expert on picture installation if someone else has a problem. :wink
Legacy Posts
Lanny - Your rear window a/c config is exactly like mine. Since you completely stripped your TT down to a shell, I assume that you removed and re-installed the A/C. If so, I was wondering how hard it was.
This is for the day that I need to replace my A/C (which I hope isn't for a long time). Our a/c's also appear to be just alike, so I should have at least three more years left on my '89, right? ;)
Legacy Posts
Sorry Suz, I've been out of pocket since before Christmas. I hope you still get this.
Taking out the rear window and AC wasn't much of a job but it takes two people because of the weight. Taking out is easier than reinstalling naturally. I took both out at the same time.
One thing that worked for me on the reinstall was to use stove bolts and wing nuts on the four sides of the window frame. This held it tightly in place and snug against the fiberglass pulling the two together. I put in the rivets on either side of the bolts then removed the bolts and put them in again two holes down to pull it together in another spot etc.. It took a bit more time but gave me a really tight fit when I was done and once I got the bolts in the first time, I could handle it from there by myself.
Lanny
Legacy Posts
:wave Hi, Lanny
Don't worry about the time lag. I think we've all been somewhat 'disjointed' since December.
What a great idea about the stove bolts holding the A/C tightly in place while putting in the rivets. I'm sure it may seem time consuming, but it's sure a lot quicker than putting in rivets then having to drill them out because they are too loose.
Thanks for a great tip. Let's just hope I don't have to use it for a while.;)
Suz
Legacy Posts
Lanny Webbs information from a previous post. Quite a job!!!
==Lanny, please excuse me for butting in, your information is so-o-o good it's just gotta be posted here. PineConeDon===
Casita Carpeting
Here are some of the pictures of my carpet installation. I used the contact adhesive I got at Lowes. It was the paste type. I rolled it on both surfaces, let dry for about 20 minutes then had a good hour to put it up.
The ceiling went up without a hitch. Once the adhesive is dry it isn’t sticky at all but bonds instantly when it hits the other surface so be careful. My plan went as follows:
I cut a piece 58 inches wide, the carpet came in a 12’ roll. Starting at the back window, this took it well behind the top of the shower and inside the closet ceiling. My camper is the 16”. I marked a center line down the back of the carpet and down the ceiling inside the camper shell. I built a support from a 1x4 and 2x2s. See picture.
I made the legs slightly longer than would fit between the floor and ceiling. I set them at an angle on top of scraps of wood on which they could slide without damaging the new floor carpet. Notice I also cover all the new carpet in case I dropped glue.
I draped the carpet over the wood support frame and aligned the centerlines. Then I hit the base of the support wedging the carpet to the ceiling firmly. Once in place and straight, I rolled on adhesive on both the carpet and the ceiling on one side, let dry then crawled under the carpet and worked it across and down the side.
I then repeated the opposite side. Notice the additional support that was just a 2x23 with a 2x2 top I could use to press the carpet into the contoured area. This worked wonderfully. Once both sides were done, I formed the back curve toward the window working from center out. The corners were a little messy but not bad and they will be inside the cabinet over the table in back. You might note I taped all the new awg 10 wiring along the walls so I would have it for the new fan and inside the cabinets.
The sides were a lot trickier. I had a hard time aligning the new edge against the already mounted edge. If I had to do it over again, I’d trim the carpet backing back at an angle giving me more carpet nap. Fortunately most of these edges will be covered up and I learned a few tricks about filling the joins with nap that should make them almost disappear. This is as far as I got but should be able to finish up some time this week. Hope this helps and GOOD LUCK! Lanny
This shows the original support made from the 1x4 and two 2x2s plus a secondary support I used to force the carpet into the curved ceiling. The second support was made from a 2x2 for the upright and a 2x2 for the top forming a "T." I started pressing the carpet to the fiberglass shell working from the center out toward the side. When I got to the curved edge, I placed the top of the "T" of the second brace in the in the indention and hit the base of the support with a hammer forcing it upward pressing the carpet firmly into the curve. I then continued pressing the carpet adhering it to the ceiling until it was fully attached. The next step was to go to the other side of the center support, roll on the adhesive and repeat the process.
This is facing toward the front of the trailer. Notice the center line on the carpet. The gray square over my head it a tarp covering the vent opening.
Pete, After several weeks of back and forth between Casita, Shaw Carpet Mills in Dalton GA, and Dalton Carpet outlet here in Athens, I was getting nowhere. Dalton Carpet didn't want to fool with a special order as small as mine. Shaw wouldn't sell me direct. I decided to put in a pad first then put in carpet on top of it. Twice the work but it looked as my only option. Low and behold, I went to my local Lowes and they stock the exact carpet with the Konga backing that Casita uses. Oddly, the backing comes in various thickness' depending on the color. I wanted gray. The only carpet color they had with the 1/2" backing was.... GRAY! It sells for $10.39 per running foot. The roll comes 12' wide. If you're interested I discovered several things that made the job much easier. I can post them if you want.
Gordon, usually I'd have used the resperator but if you notice in this shot, all the windows as well as the vent in the ceiling and the door were removed. I had 4 window fans mounted two over two blowing through the window in the back. You can barely see them if you look. It kept a good air flor throughout the trailed while I put up the adhesive but I hear you. lanny
The Roberts 7015 is carpet seam adhesive. I watched a guy install carpet at work and he use it. You place a bead of the adhesive in the join, then cut pile from the scraps and push it in the crack. When its dry you vacuum up the loose carpet and repeat the process if necessary. This is a photo with the rear seams indicated. I did a pretty lousy job joining the side pieces to the top. If I could do it over I would have the pieces overlap the top by a 1/2 inch or so. The carpet compresses easily and can be pushed in to meet the ceiling piece already installed. I tried to have the two butt up against each other and it left a noticeable seam. Fortunate, most of this will be covered up with cabinets etc. but I was disappointed. Once I discovered you can easily press the carpet back in place and have it squeeze together, my seams were almost invisible. Other than mine, I have never seen a Casita in the flesh, so to speak, so I don't k now how it looks on most of them.
Liz, My 86 has the center of the ceiling higher than the rest which results in a curved edge you will have to deal with. If you look at the "seams" picture above you will see them about 3 feet apart in the center. If you look at the last shot, you will see my seam edge on the side. If you overlap the carpet here about half an inch, once the carpet is attached you should be able to compress the extra carpet and push it down so the edges of both pieces will meet. I didn't do this and mine seams show much more than I'd like. When I tried this in other places it worked like a champ.
Good luck Lanny
Legacy Posts
I believe those are photos of Lanny Webb's work.
Legacy Posts
Benita, indeed they are and Don properly attributed the entire article to Lanny; it's a re-post of Lanny's post by Don.
Pete and Rats who want a re-post of the luncheon repast
Legacy Posts
Thanks Don, that's exactly the carpet redo I remembered, but could only find that first post. this is much better.
Legacy Posts
Good old 'edit' feature.
Benitas comment was 'after' I posted a couple of photos, but 'before' I found all of Lannys information, and edited.
Off topic info, but since a couple of folks have mentioned photo posting:
A free image editing program 'Irfanview' has the tools needed for posting photos. Can be downloaded at:
www.Irfanview.com
1. click on 'image', click 'resize/resample', type in the width (500 pixels or smaller).
2. click 'file', 'save as', select 'JPG' from the 'Save as type:' window. Click the 'options' button on the lower right of the menu. Under 'JPEG' is a slilding scale that allows you to choose the compression 0-100. Experiment with this, then check the file size. Gotta be under 80 or 72??? I forget. :)
Legacy Posts
QUOTE
Orginally posted by PineConeDon
www.Irfanview.com
Don:
I had also mentioned Irfanview a few months back. For those of us that hate to see that little REMINDER TO REGISTER/TRIAL PERIOD OVER from using programs like ACDSEE, Irfanview has been great for me for about a year. Simple to use. :) Highly recommended. :)
Legacy Posts
Really getting off topic now....
Yes Rick, I got the IrfanView suggestion from you.
Darn, I'm getting caught again posting 'Other Peoples Ideas'. :E :E
Legacy Posts
Lanny do you have any pictures of the window support that you made. Thanks Robby in NC
Legacy Posts
HI rjohn
Welcome to this forum.Post lots and have fun.All your questions will be answered sooner or latter.:wave
Legacy Posts
lanny, Do you any photos of the AC window support? Robby
Legacy Posts
Sorry everyone, I have had a really hard time getting back on line. I've been off for over a month. Robby, I have lots of procedural pictures. I'm not sure what you are referring to though.
Lanny
