Full Version: Power Caster Adapter
Legacy Posts
I have to back the trailer down the side of my house between the house and the fence, and there is only about 4" on each side so it took several times to get it just right because I had to go about 80'. The problem is there was no room hardly to make adjustments. If you moved one way a little, the truck fender was against the house or the fence. Thought a power Caster would solve the problem, and it did, but now had a different problem, had to have jackstands to raise the the trailer on, then move the truck and put the tongue jack into the power Caster. All of this was a hassle to deal with. There is now a solution, Power Caster now has an adapter that will fit on the tongue. All you have to do is raise the tongue with the tongue jack, slip the Power Caster under the adapter and away you go. No more hassle or shaky trailer up on a jack stand. So if you have a power Caster that you don't use because of the hassle, order the adapter. Now it's a breeze.
Legacy Posts
Do you happen to have some type of picture of this. it's sound really interesting, but I'm probably way off on what it actually looks like.
Legacy Posts
http://www.powercaster.com/ :)
I think it's a great idea and I am sure many people would find it quite useful.
