Full Version: sight glass
Legacy Posts
Sight glass and a manual fill valve are stand along improvments the picture shows the sightglass using the plastic drain valves,the easy way for the sight glass is install 1/2" barbed tee in the tank drain line and one in the tank overflow line. Drill a 3/4" hole below level of the bottom of tank in the sink fiberglasss wall and the top 3/4" just above the level of water tank top,pull 10ft. of 1/2" polyurathane tubing thru the holes to the barbed fittings.job done,I think the addition of the plastic drain valves to hold the sight is more professional looking.would like to add a colored ball in the sightglass to be able to see :o the water level better .
Legacy Posts
Roy, neat little improvement for your fresh water system!
Simple, too!
Didn't the Roman's invent this kind of fluid-level-checking?
Legacy Posts
:wave here is finished picture of sight glass and manual fill valve Roman who,charlie??? :r
Legacy Posts
Hi Roy
Good idea.Great job.:wave
