Full Version: Bed Mods
Legacy Posts
As some of you may or may not know we have a 2000 16' Casita SD. Well we as I believe many of you do not use the rear bed as a table area at all and keep it as a bed full time.
I just ordered a foam mattress to make it a bit more comfortable, but let me tell you what else I did...
At the end of the bed where Julie sleeps sags a lot because where it has the "V" angle cuts there is no bed support where the bed cusions overlap. So I cut out a 4X4 piece of birch plywood that will fill the gap in this section. Now we have a full bed where there was no support before. Trust me it makes a huge difference for us because now Julie can actually stay on her side of the bed and not smother me... at least not all the time.
It does not seem like much but Julie (sleeping towards the bath side) has that little be extra where gravity does not pull on the cusions as it did before.
Take a look at what I mean...
Legacy Posts
Hi Steve
Good idea you got there.One question.Did you order high density foam.This is the best to have.:wave
Legacy Posts
Steven - that is exactly what we did. In fact, we doubled the front so that when anyone sits on the edge there is zero give. You are correct. It makes a tremendous difference.
Legacy Posts
Ches, when you say high density do you mean firm?
Legacy Posts
Steven
There are different types of foam.High density should be the type that you got in your cushions.Some of this foam is deceving.It looks good but a year down the road its sagging and will not spring back to normal shape.I just put in my Boler today two peices of high density foam for our beds.I still got job to complete.
These are bunk beds.75x36 inches.Works for us.:wave
Legacy Posts
Glad to hear that Michael might have a sibling at some point!
Legacy Posts
I love Michael but another baby at this time is not in the plans. Our little family of 3 works perfect for our Casita I don't know what would happen if we had another little one. I think we want to keep things as they are for now... however the act in producing another baby is not toally out of the question!:wave
Did I just say that...
Legacy Posts
Ches,
I am very interested in how you are doing the bunk beds. Personally, I would rather have the bunk beds in the rear of the trailer. I would then turn the front into a mini dinette. We spend more time outside camping that in. Any info or additional pictures would be great!
Legacy Posts
Looks good...and our trailers are siblings!!! I had the same prob with company and did a similar arrangement with melamine.....added a flare to cover the heater discharge below and protect bedding.
Legacy Posts
What exactly is melamine?
Legacy Posts
You know that cheap/inexpensive (usually white) stuff on bathroom and kitchen cupboards which coats particle board? That is melamine.
It's basically a wood finish replacement.
Legacy Posts
Oh, cripes! I knew that! Duh. :o
Something made me think it was thick like wood. So you just got white laminate covered particle board?
Legacy Posts
I don't think this is the same thing. he talks about it
http://www.fiberglassrv.com/board/read.php...11&page=1#11120
and it's 5/8 inches thick
Legacy Posts
No, I think it is. He paid someone for a large piece. What he paid for was someone to apply the laminate on all sides (or at least the top and sides), I'll bet.
I had a brain-fart and forgot the troubles I have been through, doing just that - laminating. In my misspent youth, I laminated, what seems like, miles of countertops. I completely forgot the term melamine, somehow I thought (from the image perhaps) it was a sheet of white plastic. Doh!
Legacy Posts
QUOTE
Orginally posted by Jamie Auch
            Ches,
Jamie
Ok hope this works for you.
Top bunk steel frame with 3/4 plywood base.
The legs are just 2x4s routered on edges.The legs on the ones closest to you are lagged bolted into counter top and also back wall.The legs on back end are angle brackets on bottom with the big cross brace you see.:wave
Legacy Posts
Thanks Ches,
Is the bottom bunk on the floor or is it raised up a bit? I am going to have to explore the possibilities in The Love Bug this weekend. ;)
Legacy Posts
Jamie
The bottom bunk is 1 ft from the floor.We bought 2 blue plastic containers and slide under for extra storage.Got at Wallmart.
