Full Version: Vehicle sun roof addition
Mike jagular
Seen lots of fiberglass trailers as well as the stick/aluminum trailers that only have a pop-up vent cover.
What I haven't seen is the use of large sun roofs like those found in vans and cars. Why?
The window is sandwhiched between a 'H' design type seal and really shouldn't leak. The side windows on my Scamp are sealed in a housing which has a seal only on the outside panel. I would think that with the large window, a lot of natural light would be a great thing for the interior.
To keep debri and bugs out, a screen could be added.
Christi V.
personally I wouldnt want a "sunroof' in my egg.. for one thing it would be HOT HOT HOT and its bad enough if you dont have some kind of a/c or a good fan. I had a car with a sunroof and would never get one again...I guess one could put one in if they wanted too.. each to what they like....
Oh i forgot to add that the vent on top is also an
escape hatch'....
Brian B-P
Dometic (the same people who make many of our refrigerators) have a Windows and blinds selection which includes Heki "roof lights". Most of the available models are substantially larger than the common 14"x14" roof vent, and they routinely have integrated insulating blinds. I had not seen these before following a mysterious (to me) reference to a "Midi Heki" in the web site for the recently discussed Deseo trailer, and these products appear to be common only in Europe.
Automotive sunroofs seem generally unsuitable for conventional RV use because they are designed to install in the sheet metal roof of a car, but maybe that would be a reasonable fit with a moulded fiberglass trailer shell. The sunshade (not always included in an auto sunroof) would be required, in my opinion.
By the way, I dislike sunroofs in cars, because they add weight and complication while reducing available headroom.
jack maloney
Cars have sunroofs because when they're in use, you can't step outside. OH.gif Fortunately, we don't have that restriction with our eggs. 35.gif
Brian B-P
I had to smile when I read Jack's post - definitely a OH.gif moment.
On the other hand, it is nice to have a sunny interior. For those who truly don't care, because they only go inside to sleep 11.gif , maybe we can get one of the current trailer makers to make some up with the extra-lightweight and extra-well-insulated no window option? thinkerg1.gif
Mike jagular
QUOTE (Brian B-P @ Mar 17 2006, 04:34 PM) *
Like this Pod camper/hauler? I only asked the question as a teardrop manufacturer is now offering it as an option - sunroof with also a slide curtain. And it has a screen! Though just a simple pop-up style sun roof, there are some car manu's that have a slider sunroof where the glass is over the roof.
For getting manu's to add options, I'd like to see a parking brake added. My driveway is 23* at steepest point and its nerve racking uphooking the trailer at times hoping the chucks don't slip or the trailer goes forward even an inch. I usually have to turn the camper 90* sideways to feel safe enough.
Suz
confuse.gif I dunno, but I really don't think I would like one in my trailer. A couple of decades ago, I had one added to a car. Although being tinted kept the inside of the car from heating up, I can't begin to tell you how much fun it was driving along out in the middle of nowhere with a major lightening storm in full force. No place to duck and hide till it was over ... just keep going. ohmy.gif That happened more than once. That cured me until I purchase my present car. It happen to come with a sun/moonroof. While it totally closes off so that storms are not a visual issue, it does take up valuable headroom that I sure don't have in my trailer.
I have been in fowl weather several times while camping. I always feel safe and snug. If I had a sunroof ... ohmy.gif Ah, for me? No thank you ... very much. winky.gif
Kent
QUOTE (Brian B-P @ Mar 17 2006, 01:04 PM) *
The new Winnebago View has the new Dometic Heki Skylight over the lounge/Bed area. It can be opened and has a screen as well as pleated shade built in. Not sure if it was also an emergency exit.
The View has molded fiberglass roof so it seems that it might work on Casita. As stated it has been available in Europe. Since it has made it's way to at least one American RV it might be available to aftermarket sector down the road.
Pictures are the same or very similiar to what I saw in the Winnebago View.
Ed Harris
My 1300 does have an automotive sunroof above the table area.
It is amazing how bright and open it makes the trailer seem compared to my other,bigger trailer without the sunroof! 14.gif
The trailer came with it installed and I was nervous about leaking but I lubricated the rubber seal and used a little silicone caulk and I have not had a problem with it.
It does get warmer inside than it would without the sunroof but in the winter that is a good thing.
I have a Fantastic fan where the factory vent was and in the summer it can cool things off quickly even with the sunroof.
I made a little panel to stick under it if I need to but so far it is not an issue.
I also can tilt the sunroof up to exhaust hot air and it really helps even with the fan so close to it.
I will try to get a picture of it this week.
Mike Watters
The PlayPac had a 2 foot diameter dome in the ceiling. Mostly acted to give you a little extra headroom in a spot - but also acted as a sunroof. It DID bring in a lot of light - but the main downside was that you really couldn't put a shade up there. Would have made it awkward to catch an afternoon nap if you weren't parked in the shade to begin with.
mkw
Brian B-P
I really like the interior look of the Winnebago View (also sold as the Itasca Navion). Given that the chassis is a Mercedes Sprinter (built in the U.S. and sold as a Freightliner and Dodge, but still the German design), perhaps the whole thing is a European model, much like the T@B is a European trailer made in North America. Both bring in styles and actual components which would otherwise not be seen here.
Brian B-P
QUOTE (Mike jagular @ Mar 19 2006, 12:47 PM) *
...For getting manu's to add options, I'd like to see a parking brake added. My driveway is 23* at steepest point and its nerve racking uphooking the trailer at times hoping the chucks don't slip or the trailer goes forward even an inch. I usually have to turn the camper 90* sideways to feel safe enough.
At the risk of encouraging a sidetrack from the main topic here (sunroofs)...
It appears that European trailers routinely have a parking brake, operated by a hand lever at the coupler; it is easily added to them because they use cable-actuated surge (over run) brakes.
Dexter's catalog shows that cable-actuated parking brake hardware is optionally available for all of their drum brakes. Adding the parking brake function to an existing trailer would presumably mean replacing the backing plates. I wish I had known this when I had my hubs and brakes replaced - I would have considered choosing the parking brake version then.
Anyone who has serviced typical rear drum brakes on a car or light truck has seen that the parking brake mechanism is just a lever added at the slack adjuster point of the mechanism, acting on the same brake shoes as the regular hydraulic function. It's the same idea adding a parking brake to an electric trailer brake.
Ed Harris
QUOTE (Brian B-P @ Mar 19 2006, 09:10 PM) *
Brian
The Sprinters I have seen are all built in Dueseldorf??Germany and are all Mercedes but sold as Dodge and Freightliner here in the U.S.
I have a close friend with one and I have almost brought one home a few times.
In fact they are so German that the Dodge service guys still have no good clue about servicing them. Luckily they do not seem to require a lot of service but here in St.Louis they seem challenged even to do an oil change.
What a great vehicle though!
Brian B-P
QUOTE (Ed Harris @ Mar 19 2006, 08:32 PM) *
...The Sprinters I have seen are all built in Dueseldorf??Germany ...
It may be that the U.S. assembly plant is still not in operation. FedEx took delivery of 1000 Sprinters in Canada, made in Europe and complete with European model and brand badging (Mercedes star, etc.) - they just didn't want to wait for North American production. The plan was apparently to bring all major assemblies from Europe (complete engines, etc), but do final assembly on this side of the pond. They are now selling well here, but I don't know where they are actually being made.
Athough they are sold as a Dodge, they are also a Freightliner, and the Freightliner dealers are familar with Mercedes diesel engines (in larger series) already - that's apparently who is servicing the Candian FedEx vans.
All of this has nothing to do, of course, with sunroofs; however, it does underline the importance of having either manufacturer support, or a product which doesn't need it!
Benny K
Since we are off on a tangent...apparently in Winnipeg there is one Chrysler dealer that handles Mercedes sprinters and the vehicles have a european VIN number, hence are imported from europe and are used as vans or customized as motor homes or other special uses here by van conversion companies....the mechanic/technician that works on them at this dealership has training especially for the Mercedes units.....Benny
Ed Harris
What I was really trying to say is that the vans are built by Daimler/Chrysler the newish company that is Mercedes/Dodge/Freightliner etc.
They are built in Germany and the quality really shows from the inside.
All of the Technicians over here that work on them are specially trained to do so but with so little actual experience they are still somewhat inept at it.
The Sprinter came over first with a Freightliner badge and thus those dealers do have the most qualified service people so far but the consumer Dodge dealers are largely in the dark about them.
My friend and I did actually consider hacking a sunroof or even a large skylight into his Sprinter which is also a window model but the roof was not something we wanted to destroy to do so.
It turned out that they recallled the air conditioning units on the Sprinters of his vintage and replaced them with a different style unit all together and we would have ruined his chance to get the new AC unit had we installed anything on the roof.
We have driven his Sprinter all over the Midwest in all kinds of weather and it is a fantastic vehicle. Somehow it handles well even in bad wind and weather even though it would seem that you are driving a giant sail. It gets great mileage and has a lot of torque at all speeds.
They make a 1 ton version with dual rear wheels that would be great for towing and I have seem some doing so. The only oddity with towing anegg with one is that they are larger than most eggs by far and I thin they are bigger inside than my Trillium 4500.
On the other hand I have not let reason interfere with my Eggstacy so far....so why stop now?!? shg.gif
Joe MacDonald
Dexter makes brake kits that have a provision for an emergency brake.
