Full Version: Sewer Hose Holder
JIM KRAMME
I believe I read on here before that someone used 4 inch vinyl fence posts for a sewer hose holder that connects to the rear bumper. That seemed a little cramped for me. So I bought a 5 inch vinyl post which I think is perfect. It is large enough to hold the hose and the connectors at each end very easily. I drilled holes in the side of it and on the back bumper and bolted it on. Then for the ends I used the vinyl caps for the posts that push on each end. I drilled a hole through the top and bottom of this assembly and use a long nail (about 8 inches long-galvanized of course) to drop down through the holes and then a 1 inch piece of small hose to push onto the pointed end of the nail to keep it there. The white vinyl bumper actually looks good - after all all the new cars have plastic bumpers.
lwehrly
what a great idea, and so simple! This doesnt rust like the metal bumpers do. Easier to sanitize. I love this site and the great ideas. Even if I don't have a fiberglass egg yet, I'll use these ideas for my stick and tin trailer till I can find my own egg. Thank you all!
Al V
Might be a whole lot Cheaper then 4 Inch pumbing stuff to boot
Frederick L. Simson
QUOTE (JIM KRAMME @ Mar 21 2006, 09:28 AM) *
53.gif That would be me. It replaced the wood 2x4 that the previous owner installed there. 29.gif The 4" size is just big enough for the hose & fittings... I do have to feed it in carefully, though. shg.gif The curb-side end of mine looks identical to yours. 94.gif On the driver's side end, I use a rubber bumper plug from Camping World.
Suz
I used the 4" post cover to make a carrier for my sewer hose extension. The fittings on that hose will fit, however, the one on my regular sewer hose will not. I have a clear elbow that won't fit in either one. confuse.gif I'm still working on it.
JIM KRAMME
The reason I used the 5 inch is so it would fit any hose ends. I couldn't seem to get the "L" shaped end into a 4 inch one very well. And it is much longer than that little tiny holder they put on from the factory that won't hold a hose long enough to go anywhere and then where do you put your end fittings? You can get the vinyl fence post from a fence installer. In my case I got lucky and bought a remnant for almost nothing and I think the end caps were a couple dollars apiece. Then I installed the caps and drilled a hole through the cap and pipe on top and bottom so that the long galvanized nail would drop down through them. To attach it to the bumper I drilled a hole on each end and also through the rear bumper of the Scamp and attached it with stainless steel bolts and nuts (I think I used 3/8 inch)and large stainless washers insite the hose holder. Put the heads of the bolts inside with the hose and the thread end with nut on the trailer side. It is easier on your hose that way.
