Full Version: Poli Glow
FiberglassRV > All About Our Unique Little Molded Fiberglass Trailers > Care and Feeding of Molded Fiberglass Trailers
Pages: 1, 2
Jeanne and Steve
Practical Sailor reviewed eight different fiberglass restorers in 1998, including Vertglas. The link to this (on the Poli Glow website) is here. Of these, for the do-it-yourselfer, Poli Glow got the highest marks for initial shine. Has anyone tried it?
Jeanne
Kevin K
I just bought some of this Poli Glow. I will be taking pictures ------before and after application------ Will keep you posted. Not to much luck getting it applied this weekend. The weather forcast is for rain all weekend here.
http://www.ahoycaptain.com/shop/poliglow.html
http://www.poliglowproducts.com/index2.phtml
PAUL J
I have used it and it WORKS better tahn any other product. It is not a WAX but a recoating on your gel-coat. I met the owner of this comapny at the Tampa RV show last year nice guy - great product! But you have to have a place out of direct sun to work with the stuff.
Kevin K
I put some Poli Glow , only on the Scamp Ft. window cover.
No ----------Poli Glow http://i67.photobucket.com/albums/h296/imp...63/cover001.jpg
1 Coat of---Poli Glow http://i67.photobucket.com/albums/h296/imp...3/cover1001.jpg
2 Coats of--Poli Glow http://i67.photobucket.com/albums/h296/imp...3/cover2001.jpg
This stuff looks like it works. It says you need 3 to 7 coats. I will do the rest of the trailer and post some pictures.
Jeanne and Steve
QUOTE (Kevin K @ Oct 7 2007, 11:59 AM) *
Kevin,
Do you have any areas on your trailer that are a little problematic like discolorations or other blemishing of the gel-coat? I'd love to see before and after shots of those areas. So far I'm really impressed! 94.gif
Thanks Paul for your feedback!
Jeanne
Kevin K
Jeanne and Steve
I have a couple of bad spots. I will take before and after pictures and post later.. Looks like rain now, I'll have to quit.
Bobbie Mayer
It looks like it works great. I might try it. How long does it take to dry that it has to be out of direct sun? Are there fumes; could I do it in the garage?
Bobbie
Kevin K
No fumes but wear rubber gloves. Do small areas because it drys very fast. Yes you could do this in side your garage. There is NO sun shine here today and looks like rain any minuate. Takes about 1 minuate to dry each coat.
This photo is the 3rd coat http://i67.photobucket.com/albums/h296/imp...3/cover3001.jpg This will be the last coat on the window cover.
For once a product works like they said it should. I'am very happy with the results. The 13' Scamp should look like new when done.
H. David & Leslie de Beaux
No argument on how good your gravel shield looks after 3 coats. However, FYI from the Scamp Owner's Manual:
Exterior Fiberglass:
Scamp trailers are built using an FRP open mold process. FRP stands for fiberglass reinforced resin. The exterior paint is called Gelcoat. It is a resin with pigment added. The Gelcoat bonds chemically to the FRP structure and becomes part of the supporting structure of the trailer. The pigments in the Gelcoat can be gradually broken down by sunlight. Over the course of time sun causes the Gelcoat to change, either yellowing to oxidizing. Waxing the trailer, covering it, or storing inside greatly reduces this process. Wax that works well on fiberglass products can be purchased at any boat dealer or many auto parts stores. If Gelcoat becomes chalky looking over time buff the chalkiness out using fine rubbing compound.
Don't work too hard! L 'n D
Kevin K
I finished the Poli Glow on the Scamp . I put 4 coats on and used about 11 oz of the 32 oz jug. This stuff goes on easy and looks GREAT. The first 2 coats you can hardly see, but the last 2 really make it shine. This product gets a A+ in my book.
NO Poli Glow http://i67.photobucket.com/albums/h296/impalaman63/no002.jpg
With Poli Glow http://i67.photobucket.com/albums/h296/impalaman63/no009.jpg
No Poli Glow http://i67.photobucket.com/albums/h296/impalaman63/no003.jpg
With Poli Glow http://i67.photobucket.com/albums/h296/impalaman63/no008.jpg
Curious to see how well it holds up. How long do you think it took you to do all four coats? After the initial four coats, is it a once a year, one coat kind of product?
Kevin K
They give you a special soap and a scrub brush to use on the trailer to get all the junk off.. That took about 1 1/2 HRS. Then you let it air dry. I pulled it in my garage to put on the 4 coats because you don't want any dirt getting into the clear sealer. Also DO NOT put Poli Glow on in direct sunlight , it will dry to fast and have streaks. Wait for a cloudy day. The final 4 coats took about 2 HRS to do. It drys very fast in about 1 minuate. I have enough left over to recoat once a year for the next 8 years ( They recommend once a year). Only takes about 2 1/2 oz to do a 13' Scamp 1 coat
Jeanne and Steve
It looks great Kevin - nice job! 94.gif Many thanks for the report and photos.
Jeanne
Joy A
So Kevin,
Now that you are adept at applying the Poli Glow, could you maybe come up to Sonora, CA........I've got a little 13 footer that could use some attention. smile.gif
Greg A
So, someone that has applied Verglas how does what Kevin is going thru compare to applying Vertglas?
Price seems just a bit cheaper than Vertglas, but not a lot.
Do you need four coats with Vertglas?
Ease of Application of Vertglas?
How often do you need to reapply Vertglas?
Anything else?
Maybe, comparison photos of Vertglas application so we can see the difference?
Jeanne and Steve
QUOTE (Greg A @ Oct 11 2007, 01:31 PM) *
The May 2007 issue of Practical Sailor has a follow-up article comparing Poli Glow and Vertglas 3 years after their application.
Jeanne
Kevin K
For the money this is the BEST you can get. Great shine,No fumes,easy application(Do NOT put on in the sun)and easy clean up. From chalk white to GLOSS white in 4 coats.
Jeanne and Steve
Kevin, did your Scamp have any stubborn stains? If so, was the Poli Glow cleaner able to remove them? ask.gif
Jeanne
Greg A
Interesting threads on these products.
Restorers
Restorers
Kevin K
I used navel jelly for the bad rust stains. (Works GREAT, leave on for 20 minuates then wash off) The Poli Glow prep soap and scrub pad will take out a lot of the other stains. I will have to wait and see how the Poli Glow holds up after a few years.
I wonder if I could put a good coat of wax on top of the Poli Glow , to protect the fiberglass better?
Bonnie
So would Poli Glow seal a mural? Seems like it would. Just considering..... jumpBL.gif
Kevin K
Bonnie Yes
But you would have to do the whole trailer. Because this stuff is very shiney after 4 coats.
Dan B
QUOTE (Kevin K @ Oct 12 2007, 04:44 AM) *
Bonnie Yes
not trying to hijack the thread but just recently i washed my scamp with a solution of borax and warm water and the results were rather dazzling. it really made the thing shine. has anybody else tried that?
Kevin K
Dan B
Have any pictures of before and after.
This sounds very interesting.
B)-->
QUOTE(Dan B @ Oct 12 2007, 09:22 AM) *
[/quote]
Borax? As in "Twenty Mule Team" ???? Yeah, I agree with Kevin, pictures would be grand!
Greg A
QUOTE (Donna D. @ Oct 15 2007, 12:36 PM) *
Check it out under fiberglass it says it will make it sparkle:
Borax
Lisa H.
Poli-Glow is currently on sale online for $37.31 on this website:
http://www.defender.com/product.jsp?path=-...1&id=197398 winky.gif
Dan B
by the way, Donna, those mules made an awful mess in my lawn! Spring is here so will try to do the borax thing again and get some photos this weekend. does not sound much like camping weather here.
But think how well the lawn has been fertilized!
I haven't used the Borax on the trailer, but do use it to keep the ants down from around the house foundation... multiple uses for the same item. I love it!
Roger C H
QUOTE (Donna D. @ Apr 23 2008, 07:14 AM) *
Donna, yet ANOTHER use for the miracle Borax. My parents used it on their Christmas trees as a fire retardent. (We have an artificial tree.) My mother used to spray a mixture all over the tree and let it dry before bringing it into the house. Then after it had been up for while, she would break off a small twig in the back and try to light it with a lighter or match. When it stopped putting the match out, she knew it was time to take the tree down. I don't know what the mixture was except that it used Borax. They applied it with the sprayer from their Electrolux vacuum cleaner.
Roger C H
Come to think of it, I think it was a mixture of Borax and Boric Acid... confuse.gif
Here are some more uses:
http://www.ehow.com/how_2123273_use-borax-around-house.html
Although another website says do not use with acid like this site says in No. 2. (Lemon juice is acidic)
I guess just try a little. The only thing I know not to mix is ammonia and bleach - it will generate chlorine gas. 22.gif
Roger C H
Yet another discussion of Borax:
http://en.wikipedia.org/wiki/Borax
larrygerrymck
Kevin, where do we buy the Poli-glow? We live in Southern California and have a sweet little 13' Scamp that really needs a face lift. Thanks Gerry
Lisa H.
Hi. I live in Orange County too and purchased my Poli-glow online from Defender Industries. Poli-glow is pretty expensive but it appears they have the lowest price online. I can't recall how much the shipping was, however. Here's their website: http://www.defender.com/product.jsp?path=-...1&id=197398
You can also just Google "poli-glow" and you'll get the price comparisons. Good luck.
Kevin K
Buy the kit it has the cleaner also.
http://www.defender.com/product.jsp?path=-...0&id=211177
Bobbie Mayer
I agree with Kevin; the kit was great with the cleaner and applicator (which I fit onto a 3 foot broomstick for easy use on the top.) I really like how the PoliGlo worked. (Though bugs still get stuck on it!)
Jake Jacobson
I would suggest reading the comments on this thread before going through with a poli glow application: http://www.fiberglassrv.com/board/index.ph...st&p=293854
Just make sure it is what you want to do to your exterior - I have seen what happens to it after a few years and it is difficult to remove... just an FYI...
Deb & Chuck
QUOTE (Jeanne and Steve @ May 30 2006, 04:36 AM) *
Jeanne
Vi and John own a 70's Trillium. They were at Bandon, Ore last July. I commented to them on how shinny their trailer was. They told me about Poly-Glow. I plan to do both of my Bigfoot trailers this winter.
Chuck
Bobbie Mayer
Supposedly the cleaner will also remove Poliglo. I haven't tried it.
Bobbie
Booker B.
From various sources I have read Acetone will remove it - however, Acetone is pretty nasty stuff.
Daniel V.
QUOTE (Booker B. @ Nov 10 2008, 11:21 PM) *
Actually I've found acetone to be really easy to work with in a vented space. Only problem is it's extremely volatile so you go through a can fairly quick. But it sure takes out a variety of stains and leaves no residue.
drdoyle
On fiberglass boats with stains in the gel coat, Oxyalic acid will take out rust and tanic stains. Oxyalic acid is a white powder to mix with water, available at many hardware stores. The fiberglass must be cleaned of oils, grease, and waxes before the acid wash. This is a mild acid and we have no trouble with skin contact (but will sting cuts). It will also take rust stains out of clothing. --Dan--
Alexandra B
how about using TSP anyone ever done that?
Alexandra
Paul Richter
Is Poli Glow available in stores here in Canada or is it just available online??
Bobbie Mayer
QUOTE (Alexandra B @ Mar 9 2009, 11:46 AM) *
Alexandra
I used TSP to wash my trailer initially (first summer.) I don't think it would remove PoliGlo and it did not do as good a job of cleaning as the PoliGlo prep solution did (second summer.)
PoliGlo was definitely easier to use than it sounds like (the number of coats sounds like a lot but it goes on so fast that isn't an issue.)
J.S.Lahm
QUOTE (Kevin K @ Oct 6 2007, 03:36 AM) *
Kevin K
Good stuff--PoliGlow has been on my trailer for almost 2 years and still shines, like it was NEW.
Carolyn Patterson
I poli-glowed my trailer this year and DO NOT regret it one bit! I've been told several times by other campers that my trailer looks like new. They're surprised to learn it's 24 years old!
We decided to keep it at a private campground this season. It sits under pine trees. This past weekend I washed it for the first time since placing there mid-May. I used car wash soap and a car brush and all the crud from the trees easily came right off.
I swear by this stuff!!
Paul Richter
QUOTE (Carolyn Patterson @ Jun 30 2009, 07:33 PM) *
Carolyn, I have a couple questions how long did it take for the first cleaning? Also how long did it take to apply the first coat & are multiple coats able to be applied on the same day. I have purchased the kit & the next time we are out we are thinking of doing it then. I'm looking forward to doing it & seeing the results of our hard work.
Paul
Bryan L.
Weird. I just placed my order and came to this forum and this thread pops up. I'm looking forward to using it.
