Full Version: Boler reno help needed
randyl
A few months back I bought a worn out Boler. At the time I posted a note asking for ideas about saving it as original or customizing it. As time went on and I threw away everything rotten or not working, I've come to realize that it's a huge job not for the faint of heart. So far I've learned a lot about fibreglass repair, trailer frames,wheel bearings,wiring, refridgeration and propane fittings. I've had some fun and some hard times.
Once again I need some forum help from members who have converted the interior of these little gems. The interior is completey empty and I'm going to replace the seating area with a queen size futon sofa/bed. I have looked at buying a sofa but there is nothing on the market that fits.
Has anyone done this or does anyone have plans? I'd like to build a sofa frame from 2 pieces of plywood (using a piano hinge?) and have it fold out into a comfortable queensize bed. I don't know whether to use a slide mechanizm or to put the base on a track of some sort. The hardest part is to have it upright as a comportable couch. If I use the original seating suports I'd like to be able to have access to the storage area underneath the seating. Do any of you have experiance at this?
jaye580
QUOTE (randyl @ Jun 30 2006, 07:44 PM) *
I have NO experience in this and really nothing to offer you for advice but I have to tell you something... Ideas like this are EXACTLY why I will NEVER get my projects finished!!!Just when I am happy and satisfied with all I have accomplished someone comes along with a post like this and then I can't rest until I do it too!!!!!!! Thanks alot!!!!!!! Seriously though- please keep us posted with how this comes out and some pics too. I realy do like the idea if it is how I have it pictured in my mind!
Frederick L. Simson
QUOTE (randyl @ Jun 30 2006, 04:44 PM) *
52.gif I think the hardest part would be to match the curve across the back of the trailer in the folding or sliding part. confuse.gif
Suz
QUOTE (Frederick L. Simson @ Jun 30 2006, 10:19 PM) *
Actually, when you think about it, that's exactly what is done on the front bunk. The only difference is that it would be attached at the bottom (middle of the bed) rather than the top.
I would think it could be done like those that use a gaucho style bed (Bigfoot 17). I have looked at this very closely and believe that it is very doable.
To prevent the back curve from interferring or being a total waste of space when it was in the sofa position, a permanent shelf could be there. It would serve as a support when up, but would be a shelf used as a "night stand" for radio, clocks, etc, when it is down as a bed.
Lizbeth
I I had a completely empty Boler I would consider different floor plans. Possibly a front kitchen with a goucho set up on the far side. The standard closet with a cabinet going towards the back. Or I really liked the one that had a U shaped sitting area in the back.
Gotta love a blank slate.
CliveAlive
Someone posted a Scamp or Boler re-done in the image of an Airstream, with the bed at the back. A great looking job. I have used the search function but can't find it again. I'd like to be able to bookmark it for myself also. Does anyone else remember that one?
randyl
QUOTE (CliveAlive @ Jul 2 2006, 06:06 AM) *
I finally got back to check my posts on this subject. It sound like I have a good idea but so far haven't got a plan of attack. Anyone????
Judy N
Hi Randy: Several thoughts occur to me about using a futon in your Boler. Your pull-out distance would be limited to the space between the rear and the wheel wells on the inside unless you raise the back so the bed would be positioned over the wells when open.
Also by just using a purchased futon, you would eliminate storage space normally found in built in boxes below the eating area that makes into a bed. Also, you would loose eating space without going to a folding side table or portable tray set up.
What about a semi-futon set up? Build a box across the back and put a gaucho frame on top holding a futon mattress. The boxes could be made to access from the front or sides rather than the top, allowing storage space (which is always needed) and giving you the quick fold out that a futon allows.
One thing for sure, the great people on this site will be glad to offer "how to" advice whatever you decide. 94.gif
Loren G. Hedahl
Just a suggestion -- go to your public library and check out some books on yacht interior design. Those guys really have it together!
I also like the idea of a front kitchen -- just seems like a good layout. However there are other things involved in designing a lightweight workable camping trailer.
Because it will likely be towed with a lightweight tow vehicle, stability has to be considered. The most stable situation would be to place the most weighty items low and near the trailer axle. Kitchens can be heavy with appliances, food, water. Perhaps that is why they are usually found near the axle.
Loren G. Hedahl
Perhaps 15 years ago I was in the process of repairing a leaky polyethylene water tank in the front of a '70 26ft Avion. Since I had to remove the sofa/double bed unit to get at the tank, while both were out I tried a futon in the space.
It really didn't work out all that well. The main reason was there was no room for the tank underneath. Also the arms were too large, the slope of the seat and back made it almost impossible to set up a table for eating, etc.
I ended up repairing both the tank and the original sofa/bed unit and it served us well for 10 years of family vacations and business trips.
Benny K
I don`t think that it would be practical to put a 60x80" bed in trailer which I`m assuming is a 13' Boler and not a 17'....by removing the interior cabinetry, does it not affect the walls of the trailer as the factory wall support structure,( i.e. the closet on one side and the counter and ceiling support iron bars on the other), is removed....isn`t the consensus on this forum that if this is done, the trailer shape will sag out at the walls? also when the bed is in sleep mode the balance of useable space area is very limited in a trailer that`s 78x122" at it`s widest points inside......Benny
Miriam
Click to view attachmentOur Surfside has a bed in the back that's a full DOUBLE but could convert / extend to a QUEEN or (believe it or not) a KING. Underneath it has a u-shaped seating / storage area that takes up the whole back. Our floorplan came that way - and includes a kitchen in the front and a closet / bathroom across from the entrance. It's a 14-footer (amazing what that extra foot will do). If you want to see more pix, email me. We'll also be at the Oregon gathering if you want to snag a peek. I think our configuration is AWESOME, but then we don't travel with a passle of kids (no bunks) and our dining room is "al fresco" (unless it's raining, which means it's "el ristorante," baby).
- Miriam
