Full Version: Restore boler 78
Yvon Chayer
I am restoring a boler 78
First I remove front window because i dont use it and i have some leak around the glass
I take the gravel shield and install it with fiberglass and finish it with epoxy boddy filler
I sand all the shell , i remove 2 coats of old paint and repair somme scratch
Also i remove the furnace and patch the exhaust hole
The next opration is paint with interlux Brightside
Excuse me i speak english just a bit , i am french canadien
Norm Roy
Hello Yvon,
How bad was the interior?
Good luck on the project.
Brian B-P
That's the first I've time heard of replacing the front window with a solid section of wall. It should certainly eliminate any weather sealing issues, and the new front end looks nice and smooth.
Yvon, how are you finishing the inside surface, where the window was? I assume that you will have an insulating lining of some sort, like the Ensolite material which is presumably on the rest of the wall surface.
Catherine H.
Yvon
I would also like to know about the inside where the window was and if you will insulate it. How did you sand it? What tools and materials did you use? Was it difficult?
Yvon Chayer
Hello
For the interior finishing i use a sheet of 3/16" cork buy a Rona hardware
I use contact ciment for stick it to the inside fiberglass
I make joint with latex silicone and paint it with a hight quality latex paint ( same color of insolite)
I will take some pictures in the next week and post it
Yvon Chayer
Yvon Chayer
To Norm Roy
The interior was in good condition, very clean , no mildew and moisture
When i finish the exterior , just put new curtain and recover the foam
Yvon Chayer
Yvon Chayer
Hello Catherine H
For sanding i use a random oscilating air sander
When i fit the fiber glass pannel in the front of the boler i use a small grinder to make grove betwenn to part of fiber
I center it with 12 bolt and washer to ensure that the pannel was flush to the wall of the boler
I use premix ( fiberglass fiber mix with resin ) sale at autoparts
When the first coat was hard , i remove bolt and washer and finish the fiberglass
After i make finition with catalyse putty for automotive boddy finishing
It is not very difficult but require mutch time
Yvon Chayer
Loren G. Hedahl
Thanks for your hard work in writing your process out in English. I now know exactly how you did it!
Catherine H.
Yes. Thank you, Yvon. Keep posting your pictures so we can see your good work!
gregshannon
Yvon;
I am going to start the same project in October and hope to be finished by spring. So i'm very interested in how long did it take to sand the whole egg. Keep us posted on the paint job
Also, how big was the compressor that you used to run the sander. I have a 2.5 h.p. that can supply 3.5 CFM at 90 lbs PSI. Will this work.
Yvon Chayer
Hello Greg
I take aroud 20 hours to sand completly the boler but i remonve 2 coats of old paint
I take aroud 2 hours to remove accessories ( light , propane regulator . door etc
For the compreesor i use a 8 cfm at 90 pounds andit dont supply the sander continusly , i stop the sander regulary to give the pressure go up
Now the primer surfacer is apply and i will paint the lower of the boler this week end
I will post some picture of the next week
bye and good luck for your project
Yvon Chayer
Loren G. Hedahl
I've been through this using small compressors for DA sanders.
What I did was to throttle the air down with the valve on the sander. (It actually seemed to sand better at the lower speed.) Then when the speed dropped too low for good sanding, I would stop for a moment to change paper and let the compressor catch up.
I found it was a good idea to not let the pressure come up to the point that the compressor motor stopped, because it was hot enough that it really didn't want to start again.
Also, if possible, don't run the compressor on an extension cord. Having full voltage sure helps.
If it turns out your compressor just isn't up to the task, consider getting a good electric DA sander. Back when I was painting cars for a hobby, they just weren't available. Now just about every tool outfit has one. From some of the other forums, the Ridgid is probably the best buy, with the Festool the best overall. However, as with anything else, there are a lot of opinions floating around. I happen to have both a Porter Cable and a Festool RO125.
You can also hook your vacuum up to most of the electrics. This is important, since the stuff you are sanding off isn't the nicest stuff to breathe.
Yvon Chayer
hello
This afternoon i paint the first coat ofthe lower of my boler
I am happy of the result of my labor
Yvon Chayer
Catherine H.
Loren, what is a DA sander?
Catherine H.
QUOTE (Yvon Chayer @ Sep 10 2006, 06:11 PM) *
hello
Yvon Chayer
Wow, Yvon! What a glossy shine you have! 94.gif What did you use for primer? What kind of paint and how did you apply the paint? confuse.gif
Yvon Chayer
Hello Catherine
I use for primer Dupont epoxy primer and for paint i use Interlux Brightside paint
I spray this with air pistol
The Brightside paint was heavy and the pressure use is around 80 psi for best spray
Yvon Chayer
Brian B-P
QUOTE (Catherine H. @ Sep 10 2006, 09:17 PM) *
I had the same thought, but then realized that it probably means "Dual Action": not just a spinning disk, or a rectangular pad which moves back in forth in a straight line, but a more complex combination of "actions".
Loren can correct me when he gets a chance to see this.
Catherine H.
QUOTE (Brian B-P @ Sep 11 2006, 05:45 PM) *
Makes sense to me. So would an electric Random Orbital Sander be effective enough? I have to get this stuff off! See pics.(thank you, Benny!) I'd sure like it to look as nice as Yvon's Boler!
Benny K
Catherine, your best bet would be to find someone to borrow a random orbital from and try it......they are fairly cheap to buy in an air driven version, as long as you have a compressor capable of running it fairly steady......I believe the dual action is switched from a back and forward action to a orbital rectangular pad and a random orbital which is switched from a disc sander to an action that kinda wobbles and spins somewhat at the same time by moving a metal disc to engage or disengage the action ....hope you don`t run into problems with that right rear roof area....looks like some previous damage wasn`t repaired too well.....but luckily it`s fiberglass... 94.gif ... and almost anything can be fixed........how`s every thing else coming along? Benny
Yvon Chayer
Hello Catherine
How is the fibergass and gelcoat condition under the old paint ???
The sander that i use is a chicago pneumatic CP 865
Why do you not consider rent a compressor and a sander ????
You rent the kit for a week end and you make the job !!!!
I put the link oh my sander for the specification of the air supply
http://212.75.80.201/CPIndustrialSite/Default.asp
Yvon Chayer
Catherine H.
QUOTE (Yvon Chayer @ Sep 12 2006, 06:16 AM) *
Hello Catherine
Why do you not consider rent a compressor ans sander ????
Yvon Chayer
Yvon
I don't know the condition of the gelcoat underneath. The "gelcoat" is just the smooth paint that covers the raw fiberglass right? I own a new air compressor and may just purchase a sander for it. I assume you started with a 220 grit and worked your way closer to 100 grit? Any advice for me and others doing this?
Loren G. Hedahl
QUOTE (Catherine H. @ Sep 10 2006, 08:17 PM) *
Sorry, I was away for a few days.
Yes, it stands for dual action. Maybe it's local parlance. I still see them sold and Home Depot and Lowes. They either lock the shaft for direct rotation, or mechanically offset and release it for large semi-orbital, semi-rotating action. They were used by auto body workers and boat builders, probably still are. Use a lot of air, make a lot of noise and spew a lot of dust.
james kent
Click to view attachmentI also am going from this
james kent
Click to view attachmentto this
james kent
Click to view attachmentto this. Am using a 1/4 sheet dual action Mikita and a random orbital 5 in disc sander. Once I cut the surface of the metalic paint with no 80 paper and the small sander I can use the random arbital with 220 weight. does a reasonable job. Can only do about 6 sq ft at a time before Arthur Rightus tells me to stop. I don't expect to be ready to paint before spring but the original colour is looking pretty good. I'll keep following this thread to learn more about what to do so... keep it coming 4.gif Jim
Catherine H.
Yvon Chayer
Hello Catherine
I have finish ma paint job on my boler
I am happy from the result
I reinstall all the componemt with stainless steel bolt and jamnut . install a Maxair on the top vent
and i add a picture from the first ride of 800 km in Beauce in border of Maine , a beautyfull 3 days weekend for the tankgiving in Canada
Yvon Chayer
Brian B-P
colin k
Nice Job. Your boler doesnt have a front window? Never seen one without until today.
Yvon Chayer
Hello Collin K
Same of i have write in the first post , i remove the front window and replace by the fiberglass pannel ( front window gravel shield)
Probably the gravel shield was made with the fiberglass piece remove to make the front window opening!!!
Yvon Chayer
Kristi Warner
QUOTE (Yvon Chayer @ Sep 4 2006, 07:38 AM) *
Hello
Yvon Chayer
Hi,Yvon. I am very interested to see the cork wall covering. I have been debating how or if I could use cork for the interior walls and ceiling of my Scamp. Did you sand the interior fiberglass walls first to remove loose shards of the FG or just glue the cork on? Oh, by the way...your English is 1000% better than my French. 94.gif And your exterior paint job is a masterpiece. BEAUTIFUL. bowdown.gif
colin k
OH.gif What was your reasoning in removing the glass and replacing with the gravelguard?Perhaps building cabinets where the window was?
Robert B
Yvon,
Merci pour vos postes et photos. Vous avez fait un travail merveilleux avec le Boler.
P.S. Your english is very understandable - better than my little used french.
Yvon Chayer
Hello
I take some pictures of the inside of my boler
First pic is a pictures of the paint cork of the front window opening ecuse the quality of the picture but the flash give some bad effect
The second pic was when i install the new window , i install a sheet of arborite back of the stove and i put the same think in front of the fridge
The last pic was when i replace the plate of the lpg tank and a put a battery box on the side i made this with aluminium checker plate
Yvon Chayer
james kent
Merci Yvon
Thank you for the updates and the pictures. you're doing a fantastic job.I'v enjoyed watching your project.
