Full Version: Replacing Electrical Cover
jimtesla
Hey
I am replacing my Electrical cover and as I took everything off....there was some type of
seal that was on between the cover and exterior that is just powder now...
My question is what is the best sealant to use with the new piece...Silicon? or is there another that is recomended for our Fiberglass rigs...
thanks
Jim
BobB
Jim,
Not sure what you mean by electrical cover. Butyl caulk tape, is that what you are looking for? shg.gif
Jim, read this topic...especially the info offered by Per Walthinsen, a fellow Burro owner:
Buytle Tape, Silicone and sealing
Byron Kinnaman
QUOTE (jimtesla @ Oct 7 2006, 03:22 PM) *
Hey
thanks
Jim
You might want to consider a couple options. Purchase a electrical hatch, complete with gasket and all mounting hardware. They are extremely cheap at Camping World
The other option is not so cheap, but where power cord goes through it would all be sealed. You can go to Camping World to see it.
Benny K
What is now powder was probably about a 1/8" thick foam cover gasket that comes with the exterior receptacle cover when new....normally it`s not glued on .....Benny
jimtesla
The cover I got did not come with a gasket or hardware...
is also a little bit larger than the orig so I will have to enlarge the opening
is there a gasket material that I can purchase...the one at camping world is the same thing...just the cover..no gasket or hardware...
is there a screw that is preferred.one that wont rust over time?
thanks for the replies
Joe MacDonald
If this is the type of cover you mean, use butyl tape behind it, and rivet it in place with 3/16 blind rivets.
jimtesla
QUOTE (Joe MacDonald @ Oct 8 2006, 06:40 AM) *
its round like the camping world model
I will get some butyl tape and rivets
Pete Dumbleton
What I did when my elec entrance door started disintegrating was buy a new set the same size and just put the new door on the old entrance, but nothing seemed to be leaking.
jimtesla
QUOTE (Pete Dumbleton @ Oct 10 2006, 10:09 PM) *
this one is the same size as mine on the exterior..the interior tube is larger...
the holes line up as well..
Kurt in BC
I used butyll tape on mine,
