QUOTE (Larry & Carrie @ Feb 22 2007, 07:44 PM)
As for overfilling them, since one is pulling off of a 5 gallon tank that is only filled to 80%, overfilling the little bottle is not possible. (it's not like using a pump like used at service stations, etc. Now then it would be possible to overload the little bottles)
This makes no sense to me. The vapour and liquid in a propane bottle are in equilibrium, and that remains true regardless of the amount of vapour. It doesn't take extra pressure to completely fill, and I can't see how the the fill level of the source tank has any relevance; if everything is at the same temperature, I expect that the liquid will
eventually fill up the lowest parts (the tank being filled).
Looking at it another way... how would the propane "know" to stop flowing at 80% full, or any other specific level?
I have weighed the refillable cylinders before and after refilling using the adaptor and have found that on a cool day only get about 75-80% fill (12 to 14 oz). Now on a warm Summer day, 85+ degrees, I get close to 16 oz.
I agree that weighing is the answer, but weighing only occasionally would not be goo enough for me, because the warm-day experience indicates that they
can be overfilled. By the way, if the cylinder is supposed to hold 16 oz, then that's the right amount of weight to gain. From the original supplier, with 16 oz of propane in them, the appropriate free space is still left. The 80% maximum fill for safety is 80% of being solidly filled with liquid, not 80% of 16 oz. It sounds like these cylinders are usually getting filled to a very conservative level.
I assume that the temperature matters because a temperature mismatch between source and destination should produce a pressure difference, which will drive flow. The filling instruction with one of the adapters calls for chilling the cylinder, presumably to speed up filling. More chilling, faster flow, more likely to overfill...?
I check them after refilling for leakage. By doing this, I have never had one leak off on me. I think that one is safe in doing this as long as all suspect cylinders are discarded. JMHO Larry
So the only check is whether it leaks immediately after filling, suggesting that the only concern is that the valve is failing. Can the valve which doesn't leak after filling at a cool temperature then leak when the temperature rises, and the pressure with it? How do we know this hasn't been happening, just not in noticeable amounts?
