Full Version: Upper Fridge Vent Replacement
Frederick L. Simson
The Fiber Stream originally had a stationary panel for the upper fridge vent.
Click to view attachment Before
I had read about other members adding an exaust fan to help the fridge cool when the ambient temperature outside was above 90 degrees. I had such a problem last summer in Palm Springs when my fridge would only maintain 50 degrees inside, turned up to maximum.
However, when I removed the panel to access the space for the fan, I found that the fasteners along the sides of the vent panel did double duty, also fastening the back if the fridge cabinet to the shell of the trailer. When I removed the panel, the shell "relaxed" and moved away from the back of the cabinet, opening a 1-1/2 inch gap between the cabinet and the shell, and exposing the burner to the living compartment. ohmy.gif helpme.gif
The interior of that vent space was all wood, and was dry-rotted from the exaust gasses. 22.gif
I found a new hinged vent access panel, slightly smaller than the plain one. The cut-out in the fiberglass was small enough for the new panel. I used the original screw holes to install screws to re-attach the body of the trailer back to the back of the fridge cabinet, and installed snap-caps over these screws.
I lined the interior of the vent area with sheet aluminum.
Then I installed the new vent access panel which has a plastic insert piece around the perimeter to cover the mounting screws.
And finally, I mounted a 12 volt fan inside to pull the exaust out and help the fridge maintain 40 degrees even in the hottest weather.
Frederick L. Simson
QUOTE (Frederick L. Simson @ Mar 31 2007, 08:40 PM) *
When the shell "relaxed" from being fastened by the upper vent, it also put pressure on the lower vent, which screws popped out of the cabinet frame.
In this repair, I actually had to remove both fridge vents, replace the butyl tape as if I were resealing a window, and re-install them with longer screws to pull the body of the trailer back into contact with the back of the fridge cabinet.
Kurt & Ann K.
Frederick,
sounds like one of my typical projects... it starts out like a simple fix, and goes downhill from there. They begin as a 1 hr. project and end up taking 2 wks. OH.gif
Thanks for giving us a "blow-by-blow" description so someone else has a little more insight into what is involved. aplas.gif
What are the dimensions of the new vent cover? I've been hoping to find one a little smaller than the lower one on our Casita. Our top one is aluminum like your old one, & I'd like access also. At least I'd like to be able to clean in there. Each year our refer seems a little less able to cope with high ambient temps.
Kurt & Ann K.
Frederick L. Simson
QUOTE (Kurt & Ann K. @ Mar 31 2007, 10:10 PM) *
Kurt & Ann K.
The new vent cover is approximately 21" wide and 11" tall. This measurement is to the outside edge of the frame. I did not measure the size of the hinged door.
Pete Dumbleton
When I first became a homeowner, in the days before Scotty's/HomeDepot/Lowes, I quickly learned to avoid home repairs, esp plumbing, on Sundays 52.gif
Kurt & Ann K.
Pete,
Good advice I'm sure. Particularly about Sundays.
It's a little late to avoid do-it-yourself repairs, however, I've reached an age where I have to admit I can no longer accomplish projects which seemed simple in my youth.
I also learned, quite some time ago, that prayer was and is of immeasurable value before the start of an endeaver, as opposed to after I've brought trouble upon myself.
Frederick,
I was hoping to find another plastic vent panel, but yours provides an alternative.
Thanks for sharing your solution.
Kurt & Ann K.
Con
Your project is timely. This last winter I pull off the louvered panels so I could install a cooling fan and some baffles over the fridge. when I looked at it, I thought to my self "Why not install some hinged louvered panels?" As it turns out the place I bought my windows from also have a plant the produces radiused louvered baggage doors amongst other types of doors.
http://www.rvdoors.ca/products.htm
The nice thing about that is you have instant access to the fridge and don't have to drill out all the pop rivets.
I haven't priced the two doors out yet as I have been involved in other projects around the house.
