On the inside, I've been busy as well.. I sealed and painted the floor plus sprayed the storage compartments with rubberized rock guard. I wasn't thinking when spraying the side gaucho area and sprayed a little too high for some inane reason.. I also finished the dinette bunk and side gaucho bunk in aluminum:
Click to view attachment Click to view attachment For the upper bunk/storage compartment, we plan to put my 5 year old up there so we can leave the dinette in table form as opposed to bed form. We figure this will be good for a few years... So I welded a rail out of aluminum. I've bought a ladder to mount to here as well. Time will tell whether this will all work out for the better.
Click to view attachmentI'll replace those bolts with proper ones later.
As far as electrical goes, I was hoping to leave well enough alone but I discovered the converter that came with the 1700 couldn't so much as supply enough power to spin the hood fan, I decided to give the whole thing a rototilling. Out came the converter. It must have been someone's idea of a joke. The stove hood fan would barely spin so I figured it was broken. I took it downstairs, hooked it up to my variable DC supply and when I turned the supply on, the fan jumped to life, launched itself off my bench and proceeded to take a chunk out of my thigh. It then hung there by its wires spinning itself in a gyroscopic frenzy while I contemplated what was wrong with the stupid converter that couldn't even supply 800mA to turn a motor (no batteries were hooked up)... Plus the fact that there's 20 feet of cord sticking through a massive hole in the side of the trailer (along with I found an entomologists dream of dead insects which clearly, over the years, had decided to crawl in this 'cable access port' and make their home). So I bought a new cable hatch, bondo'd the old holes, and epoxied in a twist lock 30A 125V male connector. Then I'll cut the cable to length and connect it to the AC breaker panel that was part of the old converter.
Click to view attachmentI'll make some pigtails to convert to 30A male RV as well as 15A household. I've never encountered an RV park with one of those 30A RV plugins so I'll store that 15 foot pigtail deep in the rear storage compartment where nothing else will fit in the event that I wind up in one of those RV parks at some point. I don't know yet whether this is a good idea or not but it has to be better than losing almost an entire storage compartment to a 20 foot black cable that has been pushed in there through a 1inch hole, not to mention the insect ingress... I sleep in a trailer because I don't like bugs crawling on me while I'm asleep.
As far as DC, my plan is to put a 30A fusible link on the battery, run that to a DC breaker panel and use a smart car charger to keep the battery (or batteries, I haven't decided) charged. I also have a 55W solar panel that I'll mount to the roof and a controller to charge the battery(batteries)... I'll probably have to get to this next, since I'm coming close to laying the insulation and fuzz...
New cushions have also been ordered ....
That's all for now ...
