Full Version: Cabinet door latches
Ian R
Does any know where I can get replacement cabinet door latches for a '74 Trill?
They are the sort that have a little spring set button in them. Mine are so worn that they no longer hold the doors closed when under way.
Greg A
Don't know if they are the same you want for the Trill, but I just replaced all of mine on an 81 13' Scamp at Lowes. They are called self closing hinges and are $1.79 per pair. About four or five color options. They also have the cabinet catches with the lil roller and spring assembly for about $.98.
Fit right in the existing holes. I am changing some over to SS 1/2 bolts and nylon lock washers if they have much weight to the door.
Alistair Camelford
Ian...had same problem...found them at the RV dealer (about $12 each!!!) but you can't travel without a secure interior shg.gif I bought an extra set after ANOTHER original one broke on me during our Florida trip. So...buy some extras...not all RV places stock them as I was to discover. The good news is the latch socket doesnt need to be replaced...the handles/catches are still compatible with the 35 year old stock. 31.gif
Cheers...Alistair
Doug Mager
.....in a recent re-do of our cupboards I found that the latches (not the hinges) were impossible (for me) to find, so I ended up taking all of mine apart, tweeking the l'il springs and while apart, painting the latches grey (to match new hinges) before re-assembly, worked for me!!!
Alf S.
Hi: Lee Valley Tools has an extensive line of hinges and cupboard hardware...not trailer specific but might work!!! 4.gif Alf S. North shore of Lake Erie 4.gif
mitch
QUOTE (Ian R @ May 19 2007, 04:04 PM) *
Hey Ian ! Have you tried trilliumtrailers.com ?? They are here in Calgary and I keep hearing great stuff about them....Happy trails 94.gif mitch
Myron Leski
I just ordered two of these push button latches from RVgod on ebay. Worth a look. Howe this link works....
http://cgi.ebay.com/RV-PUSH-BUTTON-LATCH-M...9QQcmdZViewItem
Mike Watters
An online store called "TJ Trailers" carries a very wide selection of goodies. I've ordered things from them before and been very satisfied.
Are the latches the same as these?
latches
Mike
