Full Version: Jim's Trail West Campster
Jim Ingram
Okay, it took me a while to figure out how to post pics. Then I had to do the resizing -- not hard, just time-consuming. (I make my living managing the computers for a school district.) So now I have an avatar, a personal picture, and these:
Here's the general idea...
Click to view attachment
Here's the whole rig just after we had all the cancer taken out of the 1990 Eddie Bauer Bronco and installed a new engine and transmission (144,000 miles on that "new" Bronco). It shows off the trailer paint scheme nicely.
This one shows the exterior results of some of the modifications I mentioned.
My mother replaced the original windows in the 90's. I think the original trailer only had an icebox, so my Dad installed a propane 'fridge -- that's the louvered panel on the left and the "chimney" barely visible right above it. You can see the side-vent forced-air furnace below the window. The small silver metal square just to the front of the window is a 1/8"-thick aluminum "diamond" plate added to reinforce the strength of the fiberglass where the crossways bunk is mounted on the inside. Always remember to spread out the load! The green tent on the far left is a Cabela's shower tent. Where we camp there are no showers. It's equipped with a portable camp water heater and a porta-potty (which fits under the closet for travel).
I'll try to take some pictures of the other mods I've made over the years for another post.
Jim Ingram
Oh, okay -- just one more picture. Here's a good shot of the crosswise bunk. We put just enough space under it to raise our knees without hitting them, sleeping with our heads toward the kitchen. When my wife and I are alone in the trailer, the bunk comes out.
And some more "war stories." The shag carpet on the walls is because my folks very quickly discovered that they got "rained on" every night in the trailer because the condensation was so bad. They also added the bead-board insulation on the ceiling for the same reason. Um... the little holes in it were caused by that cutie sitting on the bunk, shortly after she was reminded not to do that and the lights were turned out for the night. Speaking of lights, I removed the original 12v lights (they used up a lot of battery life) and replaced them with doubled-up 12v fluorescent trouble-lights in home-made fixtures. You can see the end of one in the upper right corner of the picture (tube with the black cap on the end).
Steve L.
Gina D.
LOVE the paint job!
Bonnie
Very nice setup. I like the bunk idea. Looking forward to more pictures on your mods.
Bobbie Mayer
I love the paint job. I'd like to hear more about ( and see more pictures of) the modifications.
Bobbie
Robert B
Jim,
Look forward to seeing the rest of the pictures.
Jim Ingram
Okay, folks, it looks like the demands are for paint and bunks!
If you look at the existing pictures you can see the paint job. The wide dark red stripe wraps around the front and two sides of the fiberglass body following the body's natural lines -- the seam between the top and bottom, and the rolled-under edge that supports the seats on the inside. Of course, you can put your paint wherever you want. This just happened to fit really nicely with my two-tone Bronco's color scheme.
How To Do It: If you've never used automotive paint and a real body-shop style spray gun, and you don't have a properly-vented shop area and an appropriate breathing mask, take it to a body shop to have it done. WARNING! The materials used in automotive paint are poisonous if breathed!
If You're Still Interested: Go to a local auto parts store and buy a couple of sheets of 220-grit wet/dry sandpaper, a quart of automotive paint, a gallon of reducer (thinner), and a set of fresh filters for your breathing mask, and anything else they say you need (like "hardener", etc.)
From here on, everything should be accomplished in a single day! Wash the trailer with a good car-wash detergent. If there's any mildew, kill it with Clorox. Rinse thoroughly and let dry. Then go over the surface where the paint will be applied with a clean rag soaked lightly in the reducer you bought. You shouldn't need more than a cup of reducer to do the whole trailer. Turn the rag frequently. Let it dry again.
Mask out the areas where the paint will not be applied. Cover clear to the bottom and top of the body so that "overspray" won't settle where you don't want it. A body-shop-style masker with a roll of two-foot paper makes this go faster. You can use newspaper if you carefully tape ALL seams shut.
Once masked, use a folded sheet of 220-grit wet/dry sandpaper with moderate pressure in a circular motion about the size of your hand and go over the entire exposed surface. Be careful not to damage the masking tape. Once this is finished, wipe it all down with another clean rag with reducer and let it dry. Now it's ready to paint.
Mix the paint according to the manufacturer's instructions for your type of spray gun and your temperature and humidity conditions. (I'll assume that you have a spray gun and a clean, dry supply of compressed air. If your air hose has been used on an unfiltered compressor, it probably has oil in it that will mix with the paint at the spray nozzle, and make your paint job do strange and horrible things! If your system doesn't have an oil/water filter, it's not the kind that should be used for this. Go to a body shop.) Put the properly-thinned paint in the cup, assemble the spray gun, and put on your breathing mask.
Unless your shop has a ventilation system that can make a noticeable breeze inside it, I'll recommend that you do the painting outside. DO NOT do it in a closed shop without ventilation. The fumes can make you VERY ILL, and some effects can be permanent! I can't emphasize this enough!! So... assuming your fully-prepped trailer is out on the driveway and there's only a LIGHT breeze blowing (and your prized 1954 Cadillac is far, far away), connect the spray gun to the air hose and go have fun. The hard work is done! 94.gif
I used DuPont products. It's been on there long enough that one side of it has water marks from being watered by the garden sprinkler for several years, and it shows absolutely no signs of peeling or cracking. If you know how to use body putty and have flaws in the surface, have at it. If a bug settles in your freshly-sprayed paint (because you're painting outside), well... don't try to remove him while the paint's still wet! Let it dry, then pick him out and use some touch-up paint applied with a fingernail polish brush. It's a good idea to wait for a warm spring day before the bugs hatch out, or a warm fall day after a hard freeze to kill the bugs! (Yes, you might have to wait six months for the right "window of opportunity".)
If there's anything here you don't understand, just post your questions here for everyone's benefit.
I'll have to take some pictures of the bunk, but will post them with instructions soon. Happy painting!
Joseph Domingos
Hey Jim,
GREAT RIG! hehe I'm always excited to see what another 'sister' of the Compact/Campster variations family looks like. So this is an heirloom trailer huh, passed down from your folks? That's really great too! And your paint scheme to match the Bronco, very smart looking.
All the modifications over the years sound great too, it sounds like it's better equipped accessory-wise than many brand new rigs!
The pics are great, would love to see a few shots of your galley area to see how everything fits together there too...
Joe
Jim Ingram
Thanks, Joseph. My Dad never was able to settle for "off the shelf." Guess I inherited that along with the trailer, and am happy to carry on the tradition.
An afterthought for everyone on the previous post on painting. If the dangers and equipment described there scare you off, there's another way. It doesn't look as good as the automotive paint, but it can turn out well. Go to your local auto parts store and tell them what you're doing, then ask them for the right kind of spray-can paint (Krylon, etc.) for painting fiberglass. The only difference will be in appearance over the long term. You still should do all of the surface prep the same way. Ask the auto parts personnel what to use for a surface cleaner instead of the reducer. When it's time to paint, apply several THIN coats, allowing each coat to dry before applying the next. They may recommend a spray primer for the first coat. Three or four coats of the color paint should eliminate any areas where the light fiberglass shows through thin paint. Of course, if you're painting the ENTIRE trailer, this will come out looking like one of those redneck camo pickup jobs. Spray cans are less expensive than the auto body paints (even if you need five or six of them). It can work really well if you're just adding accents, like... uh... racing stripes? 61.gif
Jim Ingram
Well, friends, today was Saturday. I spent half the day taking pictures of 35 years of modifications, the good, the bad, and the ugly -- 42 of them. Obviously way more than anyone wants to scroll down to in this discussion thread. So I've organized the pictures into groups and put them on a website of my own where I can go into excruciating detail. I'll continue to put teasers here at FiberglassRV, and each time include the URL to the full article.
Click to view attachment Click to view attachment (more at http://www.sunnyarbor.com)
The first picture shows the completed bunk and mattress outside the trailer. The second one shows it installed in the trailer and tilted up out of the way for daytime storage. There are fourteen more pictures on the bunk project showing many details with full explanations. On the way there you'll see a list of future topics. As they become available I'll notify you here. As always, if you have questions please post them here for the benefit of all. Enjoy!
P.S. - the images on the website are also available in much higher resolution. If you need them, just ask.
Bobbie Mayer
I've already bookmarked the site; can't wait to see the rest of the mods. The cot is nifty, no need for one here, unless I decide the dogs need an upper bunk, but I like the idea.
Bobbie
Jim Ingram
Bobbie, did you see big pictures or small ones? I accidentally loaded 200px and just replaced them with the 500px ones I intended a few minutes ago. Take another look.
Bobbie Mayer
They are the same size as they were the first time I saw them.
I don't know if that is bigger or not! They are a nice size, bout 3x3 on my computer screen.
Bobbie
Jim Ingram
Okay, you probably saw the bigger ones. You can check by right-clicking on a picture and then clicking the "Properties" option on the popup menu. It should say the image is 500px X 375px.
Jim Ingram
For my recreational time today I decided to fill in some more of the modifications shown at at http://www.sunnyarbor.com for your perusal. The "Galley - Kitchen Side", "Galley - Closet Side", and "Non-Trailer Stuff that Goes Along Anyway" sections have been brought to life. More next weekend. Enjoy, and post any questions here! 94.gif
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 11 2007, 08:22 PM) *
Great stuff, Jim!
Q.1. Does your Campster have the Coleman wall lamp? And if so, is it mentioned in the manual?
Q. 2. What do you hook the tarp too on the top (the one that uses two poles and hooks to the trailer? I've been thinking of adding something like that.
Q. 3. You probably said, but what year is your Campster? Mine has the cabinets like a Compact- a metal trimmed edge and then wood veneer inserts. Yours look different.
Steve Hilby
There are some pretty clever things going on in your trailer--I especially liked the "bathroom" shelf/cabinet door!
Jim Ingram
Thanks, Steve, I hope you find more in the pages yet to come. Of course, this trick can be done with any door simply by moving the hardware from the sides to the top/bottom, and adding a little chain. The doors are already prefitted into the holes.
Bobbie, here are your answers:
A1: It did have the Coleman wall lamp. I never trusted it or used it. My Dad put two additional layers of asbestos deflectors above the built-in heat deflector, and there is still minor heat damage to the ceiling. As I recall, you couldn't stand to run it for more than ten minutes anyway because it made the cabin too warm for comfort. When I removed it, it practically fell apart in my hands, so it probably was good that we didn't try to light it recently. I simply capped the gas line that powered it, and pushed the line back into the bulkhead. The real reason for removing it was I wanted to put a shallow cabinet there for magazines, eyeglasses, pocket change, etc. What I remembered as a manual now appears to be a 4-page cardstock advertising folder, "Introducing the fabulous new... Trails West Campster," showing a Volkswagen, a Datsun station wagon, and a Ford something as tow vehicles. The light is simply listed in the Standard Features as "Propane Light," and there's no separate manual for the light.
A2: The edge of the tarp that hooks to the trailer has four evenly-spaced large metal grommets, which hook over corresponding "J-hooks" (like the ones used on the front of the bunk to hook the chains) fastened on the roof. But how you screw them down takes some care. The hooks have two screw holes. The back wall is reinforced with plywood. The kitchen has a liner. Position the hook on the roof (J up and pointing to the rear) so that the inside hole is over the plywood. Drill through the fiberglass into the plywood, and insert a long screw into it. On the second hole (at the end of the hook), drill through the fiberglass BUT NOT THROUGH THE KITCHEN LINER. Use a short sheet-metal screw that barely protrudes through the fiberglass when seated. Don't overtighten and strip this one -- it's only function is to keep the hook tail from moving sideways, and doesn't need a lot of down-force. Don't forget the silicone sealant when you put in the screws the final time.
A3: The pictures in my flyer look just like my woodwork, except all the doors and drawer-fronts have trim around them in the flyer. I don't know if it came that way, or if my folks removed the trim, leaving what you see in my pictures. My registration slip says it's a 1970 Camper DeVille Campster. There's a California vehicle ID plate just to the left of the doorknob on the outside of the trailer that says "M 350" (a model number?) and "S 0377" (a serial number?). From my Dad's handwritten notes on the flyer, it appears he paid $1,396.00, four dollars less than it's 17' predecessor sold for. It appears the vendor was Chapman Mobile Homes, Inc., 12415 Beach Blvd. Hwy 39, Garden Grove, CA. The names Jim Lester and Wally Patterson are pencilled in with phone numbers in my Dad's handwriting. The manufacturer is listed as Trails West/Campster, 16710 S.E.82nd Drive, Clackamas, OR 97015. Options listed on the flyer are "Outside Vented Space Heater", "Gas/110 volt refrigerator", and "Bracket for inside-outside dinette table." I'm guessing the factory-option space heater was under the sink, based on the photo of the outside that's in the flyer. There's a vent there that isn't on my trailer.
I noticed one other oddity that may help identify the manufacturing year. The frame under the body isn't like the photo in the flyer. The flyer shows a box frame, with the A-frame welded on an angle underneath it, rising about 8" at the front of the body, and then stretching out horizontally to the tongue jack. On mine, the frame rails under the body are actually bent just before they come out in front, continuing horizontally until they meet at the tongue jack. You can see this in the pictures I initially posted of the Bronco/Campster latch-up. There always seemed to be a lot of bounce in that bent area on the road, and I took measures to correct it this summer. It will be included in the Miscellaneous Big Stuff link when it goes live.
On a lighter closing note, while looking for info on the Campster I came across my Dad's 1955 Federal Income Tax Return. Listed as a business expense was gasoline at six cents a gallon, along with $4 hotel rooms and $1.20 restaurant meals. 31.gif
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 12 2007, 07:48 PM) *
Mine works, and I'd like to be able to use it in the winter but it sort of flashes on and off, like the gas line is choked or something. (I didn't think gas gases could do that.) I've only tried it for a few minutes, though, maybe if I let it burn for awhile sometime it will work right.
QUOTE
My registration just says Trailswest Campster (or rather Trlswst Campster) and has a plate from Idaho that says S 0149. I will have to look to see if there was an M number.
Quoted: I noticed one other oddity that may help identify the manufacturing year. The frame under the body isn't like the photo in the flyer. The flyer shows a box frame, with the A-frame welded on an angle underneath it, rising about 8" at the front of the body, and then stretching out horizontally to the tongue jack. On mine, the frame rails under the body are actually bent just before they come out in front, continuing horizontally until they meet at the tongue jack. You can see this in the pictures I initially posted of the Bronco/Campster latch-up. There always seemed to be a lot of bounce in that bent area on the road, and I took measures to correct it this summer. It will be included in the Miscellaneous Big Stuff link when it goes live. End Quote
I'll have to look closely at mine. Any chance you can scan in that brochure and post it?
QUOTE
Golly, with prices like that, why did he need a trailer??
At least inflation on the trailers has not quite kept up with gasoline.
Bobbie
Bobbie Mayer
Looking at your tongue; it does look like mine. I have different windows, though. Mine look possibly like replacements. The two sides are sliders, the front is a solid window. No shield.
Also looking at your picture: Are you pumping potable water in from outside instead of using the internal storage tank?
What is the tube that sits on the roof and runs parallel to the pop top?
I was looking at this awning: Awning
It has the same problem of needing to be attached to something but your solution would work. Currently I'm carrying my EZup but those are darned heavy and bulky.
Bobbie
Jim Ingram
Does your light surge rythmically or is it intermittent? If rythmically, how many minutes or seconds per cycle? Do your stove burners also surge in time with the light?
The long tube is a piece of 3" PVC drain pipe to hold the awning and poles. Lately we've gotten lazy and just tossed them inside the trailer instead of putting them in the tube.
I'll have to reduce the flyer before scanning it, but I'll see what I can do.
The water system will be fully detailed in the "Pressurized Water System" section of my website. I'll do that one next since you asked about it.
You probably have the original slider windows. After having owned larger and more luxurious trailers, my Mom highly disliked them -- they only would let air through half of the area, and they got hard to open and close with use. She had them replaced with "jalousy" (sp?) windows -- horizontal slat windows that crank open.
And finally... he needed the trailer because there weren't any hotels where the fish were. Of course, $4 was worth a lot more in 1955...
Jim Ingram
Sorry... forgot to comment on the Cabela's "Reddi-Awning". That's almost exactly how my awning sets up. This one looks a little bit longer than mine. If I remember right, my Dad had ours custom-made by Lincoln Tent & Awning (Lincoln, NE). One trick -- we don't tie the guy ropes directly to the stakes. We insert a short rubber bungee strap between them to give the ropes and awning some flex if the wind comes up.
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 13 2007, 10:52 AM) *
I think it was rhythmically; stove burners do not surge.
QUOTE
That would be nice. Mine are hard to open and close- got easier with cleaning, but are still a pain, and you are right, they only open halfway. For now they are going to stay, though.
Jim Ingram
It sounds to me like the way a Coleman propane camp lantern behaves when the bottle is about empty (or the way the old white-gas lanterns did when you needed to pump them up again). Make sure the bottle isn't nearing empty, and try lighting a stove burner at the same time -- just to be sure that's not the problem. If that's all okay and the lamp is still surging, shut it off and run the control knob all the way out and all the way in (as far as it will go clockwise and then back as far as it will go counterclockwise. Then try it again. The problem may be with the valve on the lamp itself, and this will help to clear it. I've seen cobwebs and bug parts find their way into the valve. If that helps, you may need to disassemble and clean the valve or replace it. I'd ask the advice of a trailer mechanic at an RV sales outlet in your neighborhood before tackling it yourself.
As I recall, replacing the windows was quite pricey. But if Mama ain't happy,...
Jim Ingram
Just gave my propane supplier a call, Bobbie. He agrees that the valve and/or orifice need to be cleaned. If you're in the habit of topping off your propane bottle at a real propane dealer (not one of those bottle exchange racks at a 7-11) on the way out of town on a trip, ask them to take a look at it. They may be able to clean it on the spot for free.
Jim Ingram
Just posted the contents of the "Pressurized Water System" at http://www.sunnyarbor.com, and also added an item that has scanned images of the original manufacturer's flyer. Enjoy!
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 13 2007, 05:01 PM) *
Cool! I love the brochure. I pretty much have the original exterior- striping, that funny symbol, original name (very faded.) My tongue does not lift up like the one shown, though. I still have the original drawer and cabinet fronts, but not the original quilted lining. I haven't done much aesthetically to the outside as I wanted to see how it would shine up and so far it really hasn't. Next summer's project. The reflective striping is in sad shape so I thought maybe I'd replace it with reflective red striping to match my Subaru, if I can find a product to spiff up the gel coat.
The propane light might have clogged a bit when I first started it up with a new mantle. I'll try cleaning the burner nose and the inlet- I should be able to get a fine wire to clean it. (I am a current science teacher (chemistry prof) so like you have access to all kinds of nifty things like rubber stoppers and cleaning wires.)
My water tank works; one thing I need to do is to extend the open-close valve to under the trailer. As it is, I keep the bed permanently made up, and then I don't have easy access to the drain valve, which makes me reluctant to fill the water tank. No problem with bugs- yet- but I'm worried about these giant outside cockroaches we get in the spring here. (They'd never make it into a water hose but might get in other places.)
Bobbie
Jim Ingram
QUOTE (Bobbie Mayer @ Nov 13 2007, 08:23 PM) *
Quilted lining? Huh?
Bobbie Mayer
They say "vinyl impregnated interior paneling" but in the picture it looks like diamond-quilted lining such as is in the Compact family.
Bobbie
Tom Trostel
Jim,
The quilted vinyl used by Compact looks like this.
Tom Trostel
http://albums.photo.epson.com/j/ViewPhoto?...3836963&f=0
Jim Ingram
Thanks for the picture, Tom -- I had no idea they'd ever done that. My trailer came from the factory with it's fiberglass walls as bare as a newborn ba... well, you get the idea. How is it fastened to the walls?
I'll resurrect an earlier comment here. I remember being rained on every morning INSIDE the trailer because the condensation accumulated overnight so badly. My Dad's solution was to cover the walls with shag carpet squares, which remain to this day. Anyone else out there have this experience? I'm betting that they added the quilting to later production runs just because of this problem. Anyone know for sure? Anyone else get a trailer without the quilting?
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 14 2007, 07:08 AM) *
Mine does not have it but I don't know if it originally did or not. When I got it it had (and still has) some kind of synthetic fuzzy material- Gina thought it was like the black stuff they put on speakers- on the walls.
Bobbie
Jim Ingram
Just took the time to look at all of your pictures, Tom. I realize now that yours is a Compact, while mine is a Campster, and mine is three years older than yours. Does anyone know if the quilting was ever used in the Campster? How well does it work, and how does it wear over time?
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 14 2007, 07:26 AM) *
Jim, I looked at pictures of the two I have pictures of (Don's, and one from Ebay in Az.) and neither has the quilting as far as I can tell. (Those two do not appear to have any lining.) None of the other owners appear to be reading the board but I just emailed Don to ask about his. Update: he says no lining and does not appear there has been one but his was painted inside so hard to tell.
Update: Sherry Stephens posted about the 1971 that she later sold that the interior was peeling.
http://www.fiberglassrv.com/board/index.ph...amp;hl=campster
Bobbie
Timmy G
Jim,
I was toying with putting a bunk in our Surfside, much like you have. Great idea for the pivot ... I was going to make a folding type bed that would fold back in three pieces making a shelf at the back of the trailer when not in use ... but now you have me thinking otherwise ... hmmmm
Jim Ingram
That's an interesting idea you've got, too, Timmy. Do I understand correctly that the bunk would be divided parallel to the long side, making three pieces about 9" X 6'-6"? If so, the problem is one of rigidity of the middle piece (the front and back pieces could still have the 3" oak sides. What if you hinged the middle piece on each side with a piano hinge, and the bunk folded up like a "Z" toward the back wall? The outer edge sides' stiffness would translate evenly through the hinge, and the hinge itself would add some additional rigidity just because it's metal (steel piano hinge would be better than brass). The only other problem I can see is what to do with the mattress when the bunk is folded.
Hey, that's what this place is all about -- making us think and share good ideas no matter which direction the saw kerf runs, right? 94.gif
Don Ruetten
Hey All:
We have a Campster as well.
As Bobby mentioned, I see no sign of a lining ever having been there. How was it attached? The interior has been painted so I can't be sure, but given the level of workmanship on most repairs, I doubt they could/would have covered much up.
I love the gas lamp! It does take some extra heat deflectors, I added some thin aluminum ones, but it throws lots of light and does a good job as a heater taking the dampness out before bedtime. More of a feature up here in the frozen north I guess.
There was a plastic awning with it. There is an aluminum channel screwed onto the roof at the edge and the awning has a plastic bead sewn onto one edge which slides into the channel. Works very well. Obviously added by some previous owner but seems like standard trailer type stuff.
The frame has no rise at all at the front. It has been rebuilt/re-enforced so is very different from original.
Very interesting to see the original flyer! It answered some questions I had.
Don
Jim Ingram
Glad the flyer helped, Don. So if you're from the "frozen north," do you remember ever awakening to droplets of condensation bouncing off your forehead? We're not so far north, but pretty far "up", usually camping above 8,000' (not here in Nebraska, but in Wyoming).
Don Ruetten
QUOTE (Jim Ingram @ Nov 15 2007, 09:43 PM) *
Haven't had any condensation problems. We have the windows and the vents up in the canvas open a bit all the time and it seems to keep it down. If it was really cold, I suppose it would be a problem, but we haven't been out in very cold weather yet.
Don
Bobbie Mayer
I finally got around to checking on the Velcroesque properties of my black fur lining. It's the loop part, and if I attach something to a hook piece, it sticks like it was Super-glued! I haven't tried traveling with anything velcroed in place, but I'm going to get some things like an eyeglass holder, etc, and put Velcro hooks on the back of them. I already put Velcro on my push-on LED lights. The black is still a little dismal but being able to Velcro things to the walls and ceiling is going to be useful.
Bobbie
Jim Ingram
Sorry I've taken all week to get back to this -- it's just been one of those weeks. 61.gif
Three new photo sets have been posted at http://www.sunnyarbor.com -- "Low-Current Fluorescent Lights", "Bathroom with Hot Shower", and "Forced Air 12vdc Furnace."
Bobbie, are you serious -- the whole cabin is lined with the stuff? If it's genuine velcro loop, that was one expensive project! The biggest sheets of if I've ever seen are about 12" X 12". Can you see seams to get an idea of how big it was? I'll bet that if you made up several pair of velcro hook pajamas, you could sleep about... let's see... three across the bed, three across the ceiling, one on each side below the window, one across the front... and one in the aisle tunnel. That's 10, with room to keep the porta-potty and the dog in the kitchen! roflol.gif roflol.gif roflol.gif Seriously, that's a great idea... but maybe in smaller quantities.
Thanks, Don -- I'll give the condensation thing a rest, as it doesn't seem to ring any bells with anyone else.
Hope you all enjoy the latest sets of modification photos.
Bobbie Mayer
QUOTE (Jim Ingram @ Nov 18 2007, 08:56 PM) *
I don't think it is actually velcro loop but it is just like it and works great. Gina thought it looked like the stuff they use that is sort of a black felt on speakers. It does feel and look a lot like Velcro loop, though. I don't think the loop part is expensive, though, it is the hook part that is tricky to make. So a fabric like the loop part would be just like a carpet.
Bobbie
