Blair,
It's not necessarily a king-of-the-hill feeling that folks are looking for. In my case, I don't have the experience that many of the folks here have with RVing; and I'm reluctant to spend the limited amount of free time that I have gaining that experience in any way that's harder than it has to be. So going with a brand (e.g., Bigfoot) that seems to be (after a bit of research that includes rejecting Airstream and listening to the undercurrent of wisdom on this site) high quality is hopefully worth the additional expense.
There is the very real risk that the $ doesn't buy what I'm after. For example, I ordered the integrated Onan generator because I figure that Bigfoot knows power requirements of a typical user better than I do and that way I don't have to spend the time figuring out capacities and designing a monitor/control system. That might turn out to be not true. But I'm gonna have fun finding out, and I won't get too angry if it's not perfect.
That said, the verdict is still out on the "buy-premium-with-most-all-the-options" approach (it's worked for me in the past). I wouldn't recommend my approach to anyone other than someone situated the same as me, and the jury is still out on whether it'll work with RVs.
Guess I'm just spouting this stuff to see what, if any, reaction it gets - and then learn from the reaction.
Mike
Mike
Hi Mike D.
I am planning the following modifications for my coming in March Bigfoot 21RB:
- Adding 2 X 27 size batteries behind the main battery.
- I did not ordered Bigfoot's BAL stabilizing jacks. I designed mounting brackets and my dealer will install BAL 22" C-Jacks. I will add 4 BAL power drives.
- I am designing and will build the Soundproof Enclosure for the Bigfoot's Onan
under-floor mount and will add Onan Microlite 2500 by myself.
- I ordered moving TV bracket 4" to the left so 15-19 inch TV will be within the wall without protruding into the walking space at its resting position.
- I am planning to replace 45 amps Parallax 7300 converter with the new model XADC 80A converter by Xantrex. It will not boil batteries with its 3 phase charging. It should fit into the lower cavity of the 7300 single charge phase PPS converter.
If you want more info send me an e-mail.
George.
This Topic was split off to bring it to a more appropiate discussion area.
