Full Version: Wiring Inverter, Converter, and Power Transfer Relays.
GeorgeR
I am in the process to getting 21' Bigfoot trailer. I purchased Xantrex 80Amp converter/intelligent charger (3 battery banks) to replace PPS 7300 single phase charging converter, AIMS 1500 Digital Inverter and I am designing a complete electrical system. Ground and the neutral will be connected at all power sources.
I would welcome any feedback regarding this design. Attached are 3 slides 3 modes of operando, Shoreline, Generator, and Inverter power.
George.
Steve L.
When I investigated this I was going to "plug" the inverter into a dedicated AC breaker. Then any item to be run by inverter power plugged into the inverter. The inverter handles the switching between the AC and the battery.
I understand the ATS301 between the breaker box and the AC inlets but I wouldn't have thought it was appropriate on the inverter side. But, I can't tell whether the AIMS inverter includes automatic switching.
I expect you'll want some pretty serious diameter wires running from the battery to the inverter.
Byron Kinnaman
As Steve said you're gonna need some pretty big wire. According the charts 125Amp line will need at least a AWG 4 wire. AWG 4 conductor is almost 1/4" in diameter, then add insulation probably a bit over 1/4" maybe up to 3/8".
Another thing, all electrical equipment runs on smoke, when you let the smoke out they stop working. With the kind of current you're talking about letting the smoke out could happen pretty fast, then it spreads to fiberglass, rugs, etc. Make sure you're insurance is paid up and will cover modified electrical systems.
GeorgeR
Thank you for your feedback. I want to permanently wire the inverter for convenience. I am sure that just plugging directly into the inverter outlets would be easier. The AIMS Digital inverter does not have power transfer relay built in so I added ATS301 ($51).
Byron, you have a good point regarding potential insurance issue with electrical modification. Less modification would be better. I need to rethink my approach.
George.
