I got a cheap carpet piece from Walmart ($20) so I am overlaying the ugly, cootie, water stained, probably dirty blue that is in there.. I have cut the pattern for the corners... and also the front part of the bunk. It's the only way I know how to pattern the corners... still working on one end... but need to find someway to tack down the front part so I can get it smooth...
I want to put trim on the front part where the curve is... what if any suggestions would be nice to use.. as I don't want the raw edges of the carpet showing... something flexible would be nice.
curves cut on one end...
Click to view attachment
paper pattern for curves
front needs to have trim??
I am planning to just use a staple gun to tack around the carpet insead of gluing or anything... with the new cushions the upper bunk it should look pretty good.. at least it will be CLEAN!!
