Full Version: Roof Mounted Fiber Glass Shelf
Kurt in BC
I want to acquire one of these for my '70 Boler. Just extra strorage for blankets and things. I see Scamp sells them for about $134 (seems fair) and I recall there was a guy making his own and selling them through the Internet (Anyone have the link?). I am skeptical about the strngth of them and do not like the idea of more holes but I need the storage.
If anyone has one they want to sell let me know.
Kurt in BC
PS - Does the Scamp shelf fit in the Boler....I assume it would?
Kurt you might check with Paul Neumeister at Fibreglass RV Parts, bet he'd know. Click on the Catalog for more info.
Kurt in BC
thanks, Paul is the guy I was referring to.
Called Scamp. Shelf is only $134 but shipping to Washington was about $170 29.gif
Ed Harris
Kurt
I made shelves for the Trillium 1300 I had.
It was simple once I figured out where I would attach them.
I used clear pine 1"x2" and 1/4" Baltic Birch plywood all just screwed together.
By making lightweight frames and skinning with thin plywood they are very strong and still light.
I was also able to run wiring through them to have new circuits all over the trailer.
Oh and it was fun too.
Ed
Ed Harris
Here are some better detailed shots of the framing.
Booker B.
Ed, these are very informative pictures - though a bit small =)! I was asking about this on another thread as I would really like to put lights around the table for reading books and not many of the Trilliums came with the fiberglass shelf. Did you attach them to the plywood surrounds on the window tops?
Alf S.
QUOTE (Kurt in BC @ Mar 24 2008, 03:39 PM) *
Hi Kurt... We have an origonal/optional upper dinette cabinet in our '77 Boler. The fit is not 100% even from Boler!!! My brother had 2 front / back added to his '72 Boler. The cabinet requires 6 holes around the edge 3 on the walls(each end and center above window) 3 in the roof. I replaced the poprivets in ours with S/S Bolts and weatherseal washers to avoid leaks. Yes they are very handy for clothes etc. Ours has a divider wall down the center between the two doors...kinda his n hers. I have seen Pauls as that is where my brother got his and his work is top notch!!!
Ed Harris
QUOTE (Booker B. @ Mar 24 2008, 07:54 PM) *
Send me your email address in a PM and I will be glad to send bigger pics.
And yes I attached them both to the Plywood window frames which I beleive only the Trill's have and to the cabinets which gave great strength.
Ed
james kent
Click to view attachment
This is a picture of one of the original end cupboards in our Boler. You could cut a cardboard pattern and make your own using 1/4 or 3/8" plywood. Ours are held in place with 6" wide layers of fiberglass tape so no holes are necessary. The side shelving is metal closet racking turned down side up to create a ledge. Cut about 4" extra long and just pushed through the holes. [No clamps] Gives extra shelving without giving a closed in feeling.
Kurt in BC
Thanks. I thought of making my own too but though I would stick to F/G to keep it looking stock and to hide the clutter.
I do like the idea of having wire type shelf attaching to it though.
Alf - thanks for the heads up. I have to call him, I see he does not go through email (just phone numbers). I am already using SS pan head bolts so I would be repeating the same. Only 3 in the roof is not as bad as I thought.
Any idea what he charges for them?
PS - I asked Scamp about fitting theirs in the Bolers. He says the fit is not perfect but they are close enough to mount in there.
