Full Version: 75 Trillium New Clear Coat
Roger Hunckler
Here's a few pics of our 75 Trillium, as I mentioned in earlier posts I was waiting on some warm weather and an afternoon, well, it's 83 degrees today and lots of sun so I set out just 5 hours ago to shoot the trill with some clear. (I've been color sanding for weeks though). I thought I'd try the duplicolor clear coat from Auto Zone, I was going to shoot it with automotive clear but thought I'd give it a try. Here's the pros and the cons in case you want to know. I used my hvlp gun on this project.
Pros:
Easy to shoot, levels fast no runs even on final coat
cost was fairly cheap it took 4 quarts, but could have used up to 6 @ 21.00 quart. (84.00) on this project.
No mixing or thinning, no hardners, low overspray just pour in the gun and shoot (very easy)
You can overshoot at any time for touch up without a problem.
Very satisfactory results no need to color sand and buff
Dries to the touch very fast
Cons:
none, easy and great results
If you're like me, no extra time this is a good bet if you want to shine up your trailer with little expense. Color sand it with wet and dry paper, if you want a really nice finish then do your final sanding with 600 , 800 or 1000. Be sure to wipe it down with wax remover (also availabe at Auto Zone). I'm happy with it and this puppy is going up for sale soon! Almost time to move on to a new project.
Cons:
No real cons on this project.
Booker B.
Looking good Roger!
Randy & Sherrie Baker
It looks fabulous!! What is colour sanding though???
Sherrie in Elmira, ON
Roger Hunckler
QUOTE (Randy & Sherrie Baker @ May 26 2008, 09:29 PM) *
basically it's just fine sanding the fiberglass finish to accept paint or clear. Usually after a coat of clear coat you fine sand and buff the clear out, that's the term for color sanding. It sound's cool but it's just fine sanding!
Roger
Janet G
wow thanks so much. this is what i would like to be able to do with my green grape too. did you rent a sprayer and enclosure to do it at a paint shop? am wondering how hard it would be to do myself
Roger Hunckler
QUOTE (Janet G @ May 27 2008, 05:55 AM) *
I actually sprayed it outside, it only took about 40 minutes, the weather was perfect and no bugs. You can buy a good hvlp spray gun (High Volume Low Pressure) for under 100.00. If you read up on spraying techniques there's no doubt you can do it yourself. This Duplicolor clear coat dried to the touch pretty fast with very low overspray, so there was no trash in it. Make sure you have a proper mask for spraying as well. Spraying is easy, your results will come from good preperation.
Roger
Booker B.
Hi Roger,
Does your HVLP gun work with a compressor or is it standalone? I have always been hesitant to try one as I thought you needed a fairly serious compressor. I have a 60gal but don't have the space in my panel for the 220 breaker... how I ended up with a 60gal is another story.
Booker
Roger Hunckler
QUOTE (Booker B. @ May 27 2008, 09:59 AM) *
Hi Roger,
Booker
It requires a compressor, I have a regulator on my gun, and sprayed at about 25lbs air pressure. It's a gravity feed cup and the fan is adjustable from wide to narrow so you can really shoot into some tight places if you need to. I've painted a few cars with this gun and it really lays on the paint nice, I bought it about 6 years ago and I think I paid 80 bucks for it. A regular compressor will do the job, it uses very little air.
Roger
Booker B.
Ok, so a 4 Gallon Dewalt (Emglo) would do the job?
Sorry for asking these detailed questions but I am sure there are others who will love this knowledge =)
Roger Hunckler
QUOTE (Booker B. @ May 27 2008, 12:41 PM) *
I used 1 gallon but I could have used another 2 quarts, I imagine that another product will cover roghly the same area. If you are going to shoot the roof as well, then I'd say you'll need 6 quarts, that should give you a tack coat, and 2 heavier coats to finish. The consistency of the Duplicolor clear coat is like water. It sprayed out pretty quick, it may be that a different clear that's a little thicker will cover faster with less product.
Roger
Scott S.
nice results. got me thinking now!
the exterior on mine is a planned 2009 project.
Roger Hunckler
QUOTE (Scott Sauder @ Jun 4 2008, 03:43 PM) *
Hey Scott, saw your upholstrey, looks nice! This was an easy job, don't wait!
Roger
SherryNPaul
My parents' neighbors had a Trillium through the seventies and eighties... I think this outshines the original.... Beautiful job.
Rob S.
Roger,
I see great minds think alike. I did my Boler 17' with the Duplicolor Paint Shop Pro as well. I didn't like the colonial white and since the shell need painting after all of the spider crack repairs, I shot the whole thing in white and then cleared it. It is more expensive than mixing your own but the hassel free conveninece was worth it. It does go on very well.
You can see the shell in my other thread: http://www.fiberglassrv.com/board/index.ph...&pid=269654
Rob
