Full Version: Converting dinette into a "U" with more accessible storage.
Pages: 1, 2
peterh
QUOTE (Coach George Jessup @ Mar 19 2009, 12:36 AM) *
is the LED light panel running horzontal or verticle on the back side of the tank. If Horzontal.. are you saying you put light along the bottom edge of back side of the tank?
It's mounted horizontally to illuminate the bottom-most back edge of the tank. I did it that way so that the light gets trapped in the water, forcing it to act something like a fiber-optic cable and illuminate the front of the tank where the water is much better than further on up the tank wall where the water is not. If you ran it vertically you'd illuminate the "thermometer" viewing window much more evenly.
peterh
QUOTE (peterh @ Mar 19 2009, 03:13 PM) *
That's a good point. No, they're not grommeted, but the wire and piping is zip-tied into a tight bundle that runs through the center of the over-sized hole.
peterh
This week new upper cabinets made of 1/4" birch plywood with pine and hemlock framing replaced the smaller & heavier cabinets from Scamp. The new cabinets weigh 4 pounds each without their doors; the old cabinets weighed 7-1/2 pounds each. The new doors are bigger than the old so they weigh only slightly less . . . but the best thing about them is the larger door openings make it easier to get things in and out of the cabinet.
From this Click to view attachment to this Click to view attachment.
Yet to be decided is last "big" change inside our trailer, which is possibly adding a shelf or cabinet over the back window to span the distance between the two new white cabinets over the dinette.
peterh
The last cabinet I'm building for out 5er is taking shape. This one spans the back of the trailer between the two left and right upper cabinets I installed last month.
The center opening is designed so it'll fit a board game and will have a traditional door like the ones I made for our other cabinets. The smaller side cabinets are going to be more challenging. They're meant to be open storage cubbies that Lynne and I can easily reach up to while sitting in the dinette without having to open or close a door, but we still need a way to close the cubbies off so their contents don't spill out while we're towing. A standard swing-type door won't work here, though, because it would block the swing doors on the side cabinets.
So I'm making an oak "roll" door, like you find on a roll-top desk. That way we can keep the cubbies open when we're camping without blocking the swing-up doors of the side cabinets but still close the cabinets off for towing (or to hide the mess inside).
Don N
Excellent idea with the "roller" doors. Will also look very appealing when they are closed.
peterh
The new dinette upper cabinet with its swing-up and roll-up doors. I still need to make a curtain rod.
Roll-up doors Closed:
Open:
(Sorry about the lousy view out the back window: Our trailer is parked at the storage yard right now.
Bill K
Bill K
QUOTE (peterh @ Jun 27 2009, 01:56 PM) *
QUOTE (Bill K @ Jun 27 2009, 05:11 PM) *
Bill K
He does have two trailers Bill, just not that sticky you see through the window. Peter and Lynn bought a Surfside last year: Inaugural trip of a new-to-us Surfside If the 5er is any indication, Peter has some fine, fine mods going through his head for the Surfside 94.gif
Frederick L. Simson
QUOTE (peterh @ Jun 22 2009, 10:46 PM) *
Class, today's vocabulary lesson is:
