QUOTE (Booker B. @ Jul 13 2008, 07:51 AM)
Hi David,
I actually have an awning to give away. Our Trillium came with a slide in awning with 3 pole system. It's a complete pain in the butt as you need to setup guide lines to the poles. The problem is that most pads in our provincial parks are so hard you can't put in a peg to hold the guide lines. I am going to buy an awning from
We are still in Vancouver on our way back to the Island. I was going to post the awning as free if someone paid for shipping. You want it?
What works in that situation is to bring a stack of small buckets that you fill with rocks, water, or whatever works.
Tie a line to each buck bail, then install a boater's cleat to each awning pole.
Our water supply is several plastic jerry cans that are carried in the back of the Jimmy. From these we fill one-gallon bottles for use in the Scamp. If the weather warrants it, I will use a couple of the six gallon bottles filled on the awning ends. Normally a gallon size works great.
