William L.
Oct 7 2008, 04:11 AM
We've just started thinking about a 13-footer and have been educating ourselves and researching what is out there. I've noticed ACs factory installed on the door side, external units, window-mounted over tongue, rear-mounted over dining table, under dinette table, and roof-mounted. What are your thoughts about the pros and cons of location? Also does anyone have any thoughts about buying one that has "lived" in the southeast? Would mold and mildew be a problem?
April Wilcox
Oct 7 2008, 05:50 AM
We are also trying to figure out a good AC solution in our new (old) 13' Scamp. So far the best place looks to be the closet by the door, but that would also limit our storage space in that closet. It seems the least expensive option would be to get a small window unit (around $100) We are not going to do anything just yet though, as we are starting to move into the cooler season. I am filling my head with information at this point so we can make the best choice when we do install it.
Greg A
Oct 7 2008, 07:54 AM
I inherited the Rear Left window dinette location and recently corrected the old installation mess with a replacement unit. Having camped in the 13 for close to two years now I like the location for two reasons.
1. In a 13 I personally wouldn't want to sacrifice the closet space.
2. There is nothing better on a hot day or evening then laying on that rear dinette bed awash in the AC blowing over you. The curvature of the roof brings the air right around the roof and down over you. Wonderful.....
Of course, everyone is different on how they view things so these are just our personal approach.
Here is our current installation:
Click to view attachment Click to view attachment
Sandra Lair
Oct 7 2008, 09:30 AM
We didn't want to give up closet space or a window, so we opted for installing our AC through the back wall at floor level (under the table/bed.) The only drawback is that when the bed is in position, the air flow from the AC is not as good, so we place a small fan on the floor to draw the cool air out into the room. It works well unless the temp stays in the upper 90's.
Sandra
William L.
Oct 7 2008, 10:07 AM
Greg,
Your side window mount is one I hadn't even seen yet! Do you experience any problems with balancing the weight while towing; and what about road vibration? I'm getting the impression that there is a lot of room for creativity in modifying these campers and not necessarily a right or wrong way.
Bill
CindyL
Oct 7 2008, 01:57 PM
We cut through the fiberglass in the back of our 13' Burro, built a mount that also held our license plate that kept blowing off with the original mount, and disguised it with a cut-up cooler. When camping, we took the cooler off. One guy even asked the hubby for a cool one from the "cooler."
CindyL
CliveAlive
Oct 7 2008, 03:15 PM
QUOTE (William L. @ Oct 7 2008, 02:07 PM)
Greg,
... I'm getting the impression that there is a lot of room for creativity in modifying these campers and not necessarily a right or wrong way.
Bill
I plan on installing the A/C under the stove where the fridge/ice box are usually located and a dorm fridge in the tall closet.
This is what I think is going to work best for my wife and I, as she will be able to enjoy the A/C inside with less noise kerb-side while I am outside.
This is in the Boler I'm still renovating which I got basically as a rolling shell.
Greg A
Oct 7 2008, 03:34 PM
QUOTE (William L. @ Oct 7 2008, 11:07 AM)
Greg,
Bill
Bill,
No issues at all. That AC unit is almost like it is molded into the camper. After I installed it I grabbed the outside of the AC unit and shook the entire trailer from side to side for about 15 minutes pretty violently and had no movement in the unit or ill effects. You just have to be careful pulling through fast food drive thrus and not forget to watch your side clearance....
Lizbeth
Oct 8 2008, 10:13 AM
I opted for the back window mount, my Boler has a sliding window. The AC rides in the trailer in front of the closet on the floor which makes a nice table when not in use.
click here.
