Full Version: New floor for a Scamp
Bill D
Two things I found out about this Scamp. The floor is molded into the fiberglass sides and wet particle board sucks. I was going to replace the frame with a conventional style frame, but the floor was rotted out and there is no way to lift the body off of the frame, so I cut the rotten wood out and replaced it with 3/4" plywood and fiberglassed it back in. I also added some strength to the frame since I was down that far, this turned out to be quite a job...and I'm not done yet. Every piece of wood in this old Scamp is rotted so there will be more to come. There are way too many places to leak that I am also fixing.
Roy in TO
Looks good Bill!
The link to your pics on flicker shows a lot more of the work you've done, 'cept the pic of your uhaul, that threw me off base for a minute. R U Trying to see if we are awake?
Pete Dumbleton
I forget the name of the material, but that's NOT particle board (which is essentially sawdust and glue), nor is it OSB (the fibers are random) -- If it had been genuine exterior plywood, it would still look like that... Long-term water takes it's toll!
The cabinet doors, bench hatch covers, closet doors, etc. are particle board and deteriorate quickly when wet (Also heavy ). To reduce weight, I replaced my closet door and the hatches with some thin (about 1/8") beaded-board plywood that I had, and none of them have warped!
Bill D
The uhaul was in that group of photo's,I'm glad someones awake,because I wasn't.That beaded plywood sounds like a good idea for the doors,but I have a long way to go before I get to cabinet doors .I'm grinding most of the rivets out and countersinking new ones into the fiberglass and covering with duraglass to try to stop most of the leaks,The PO has so much silicone gobbed all over everything,and it still leaked,I still have more wet wood to replace also.This is turning into a total rebuild.
Raya L.
QUOTE (Bill D @ Mar 9 2009, 09:28 AM) *
Just some thoughts when I read that:
*The shells on these campers aren't all that thick, so I might worry about amount of material left to take the fastener loads if you are countersinking the rivets.
*If I were doing a major rebuild and wanted to eliminate fasteners pentrating the shell, I would think about either tabbing the cabinetry directly to the inside of the shell (probably on the inside, using fillets for the transition; or maybe by glassing in cleats, then fastening to those, but probably the former). This would add quite a bit of strength and "monocoqueness," and would eliminate any rivets (or worry about countersunk rivets pulling through or the filler or adjacent gelcoat/glass cracking).
Of course I'm not there looking at your trailer, so I'm just streaming thoughts here based on my experience with other fiberglass items.
Raya
PS: Except for if you don't like it cosmetically, I do think that new, well-installed rivets or machine screws would also be leak-free. Once POs have gotten to the "globbing silicone on top" stage 29.gif you know there was a problem that wanted a real fix (re-bedding) but got a quick fix instead. One other thought is that if the shell was flexing unduly (due to a rotten floor or other issue), it would have put extra strain on the sealant of the rivets (tabbing would resist this much better; but of course you want to fix the extra flexing anyway).
Ed Harris
Bill
What year is the Scamp?
Bill D
Raya,you're right about the thickness of these campers,I was surprised how thin they are.I only ground far enough down to cover the rivet head,there seem to be enough fiberglass to get a good hold,and that was basically on the roof and on the cabinet side,the ones on the sink side I'm going to use ss bolts with rubber washers after I paint it . I also have some stress cracks near the front window that has to be sanded out and depending on how deep they are,I'll fill with vette bond.It seems that although the fiberglass is thin the gelcoat is a little thicker.It's a 1983 and I'm new to these little fiberglass campers,but after building a teardrop a couple years ago and years of body work ,I'm not shy about grinding into these things.I'm just glad I got a lot resin and cloth left over from the tear,because I'm goint to need it.
Roy in TO
With your experience Bill, I doubt you need reminding.
For the benefit of others reading this thread later. The silicone may have been an attempt to fix the problem but one must figure out where the water is coming from. With a floor rotting it can come from either below or above. That requires investigation to solve the problem.
Raya L.
QUOTE (Bill D @ Mar 9 2009, 09:55 PM) *
...but after building a teardrop a couple years ago and years of body work ,I'm not shy about grinding into these things.I'm just glad I got a lot resin and cloth left over from the tear,because I'm goint to need it.
Just curious, since you have a U-haul too, what you think of them in comparison? Word is that they were built heavier for the rental trade, but then again they did use Burro molds, so maybe that is "folklore," or may be it was just the frame ask.gif
Raya
Bill D
This old Scamp was sitting in a field with a broken window another one open and the door not shut good, a friend seen it when he was hunting one day and knew I was looking one,I had since bought the Uhaul from someone one this site.I tracked down the owner of the Scamp and was told it belonged to his son,whom he didn't see too often but would ask if he wanted to sell it,a few weeks later I checked again and made an offer,this time I got a call that night and said he'd take that offer,I made the offer before I even looked inside,knowing it was fiberglass and the frame wasn't rotten (how bad can it be).LOL.I'm not sure it did leak from the rivets,but I wanted to clean it up for paint & take away all chances of leaking.
The Uhaul is twice the camper of this Scamp but it is also heavier and A little harder to tow with my 4cyl.Toyota ,The Uhaul has an outer and inner fiberglass shell and some nicer amenities (range hood, heater etc.) plus it sits a little higher,but for hunting & fishing,I don't want to get it muddy,that's why the old Scamp.I may sell the Uhaul once the Scamp is finished,not sure I need 2,(at least that's what my wife says.)
Raya L.
Thanks Bill,
I know the U-haul is about 250# heavier on paper. I didn't know if they really were more heavy duty, or if it was just a more realistic weight, since U-haul had to answer to customers with specific tow capacities on a rental basis and therefore couldn't be as "optimistic" as some of the manufacturers seem to have been.
I also wonder if it is partially that they have more tongue weight - don't the wheels/axle look further back than on others? (Or is that my imagination.)
Sure would have been fun to be able to just run out and rent an egg! (But I bet they got tired of cleaning them vs. sweeping out a utility trailer or truck.)
If your U-haul is in nice shape, I can see where it would be fun to have a "beater" to run out to the woods with, and not worry about.
Raya
Pete Dumbleton
Remember that UHaul has *two* shells, inner and outer, where your Boler and my Scamp only have one.
Raya L.
Yes, I realize that. But so do the Burros (same mold, but you don't hear the "they made them extra rugged for rental" about them). I was interested in the possible "ruggedization" done by U-haul. One sees it mentioned, and it makes sense that they might have been, as rentals. Also, they do claim them to weigh 1250# whereas a similar Boler, Trillium, etc. is usually said to weight something closer to 1000# (not sure what dry weight the Burros claim, but that would be an interesting comparison --- I don't consciously remember anyone saying they were particularly heavier than the Scamp, Trillium, etc.).
It does look as though the U-hauls have their typical single-member tongue. Maybe all the extra weight is in the frame and running gear; or maybe it was just a more realistic claim shg.gif
Anyway, just curious.
R.
Pete Dumbleton
Owner of RV repair place in Florida told me he did the molds and based them on Burr0. I doubt that the shell is "ruggedized" (That's why fiberglass in the first place). It's in the large (proprietary wheels and tires, axle, frame, coupler, etc. and perhaps the appliances).
Raya L.
The extra weight being in the frame and running gear makes sense - if there actually is extra weight. From photos I've seen the appliances are pretty much standard lightweight RV stuff. Small DuoTherm furnace, icebox (not refrigerator), and typical RV two-burner stove.
It would be interesting to weigh a comparable Burro 13 to see if there really is a weight difference between that and the U-haul 13 --- probably hard to do in reality though, unless one person owned both, and neither (or both) had a 'fridge.
Curious that a place in Florida did the molds, since I thought they were mostly built in Iowa.
I guess I should have been an archaeologist or a detective - I just get curious about stuff biggrin.gif
QUOTE (Raya L. @ Mar 10 2009, 07:57 PM) *
Maybe we'll have one of each show up at the Oregon Gathering and Frederick can give us the weights. Of course, it would never be 100% accurate due to personal items and the like packed in the cabin. But close enough to get a good idea of the differences.
Bill D
The Uhaul has a heavy tubular frame were as the scamp does not,I'm not sure of the tongue weight,But I can pretty much move the Scamp around by hand,the Uhaul is much more difficult,and I'm sure it's because of the rental demands on A Uhaul.There pretty much set up the same way inside but you don't see any rivets or bolts thru the shell of a uhaul,the only place it could leak (which it don't) is around the windows or vents,the only thing I've noticed with the Uhaul as opposed to the scamp is that the Uhaul has a tendacy to sweat inside,there's nothing to absorb it like insulate or what ever that stuff is glued to the walls of the Scamp.
