Full Version: Changing from 6 pin to 7 pin on truck - how??
Shelley
My truck came with 6 pin wiring and the trailer is 7. How do I switch it over and how easy is it to add a brake controller...by myself....
Kevin K
6 PIN SMALL ROUND SOCKET TO 7 PIN SMALL ROUND PLUG
$20.00 Click to view attachment
http://images.google.com/imgres?imgurl=htt...1GtbFmQfZquiOBA
floyd
QUOTE (Shelley @ Jul 26 2009, 07:24 PM) *
this should help!...
http://www.etrailer.com/faq-wiring.aspx
Shelley
The wiring diagram is great!
Is adding a brake controller doable for a newbie or should I try a hitch shop?
Bob Elder
QUOTE (Shelley @ Jul 27 2009, 01:03 PM) *
There are 4 wires that go to a brake controller... Black, White, Blue, and Red...
Black is positve battery voltage and should be run to the battery through a 20 amp auto resetting circuit breaker.
White is ground and should be run directly to the negative batt terminal
Blue goes to the 7 pin for the brakes,
Red connects to the brake light switch....
Hope this helps....
Bob
