QUOTE (Roy in TO @ Aug 4 2009, 10:06 PM)
Last year I installed my P3 controller to go with the new axle and new electric brakes. This year they have stopped working. When I connect the trailer to the TV, all the signals etc. work, but the controller says the trailer is not connected.
I'm not sure where to start looking for the problem. The TV has a 7 pin male connector, the cable has a 7 pin female on both ends and the the trailer has a 7 pin male to plug the cable into.
How would you troubleshoot this?
What sequence would you follow?
Hi Roy,
I often find the contact surfaces on the seven pin plugs oxidize between uses and lights or brakes or both will not funtion until the plug has been inserted and removed a couple of times. Is there a fuse in the line supplying power to the controller? I have a flat 4 test plug with L.E.D's to indicate proper function of TV(bought at Princess Auto $4). I understand there is something similar for 7 pin but havn't seen one yet. If you have a means of testing the TV it eliminates 50% of your possibilities and you can then concentrate on the trailer. I have also found the 7 pin plug corroded from salt spray coming off the tires in winter. Dielectric grease inside the 7 pin can extend the life.
Bill
