Cheryl,
If you are referring to the interior panel there is no danger of monoxide poisoning, there is an issue with the urethane behind it acquiring mold growth or swelling depending on the era it was made...the fix is to go to the hardware supply and get Locktite 5 min 2 part epoxy. Lift the crack a bit and work in the product after mixing, when set up lightly sand with 150 grit.
Wear disposable nitril gloves, (The epoxy cleans up with Acetone
BUT do not get Acetone on the plastic, IT WILL DISOLVE IT.)
Harry
QUOTE (Cheryl Lee @ Aug 19 2009, 07:41 PM)
I have a crack in the plastic Interior sidewall of my Dometic RM 2411 fridge.
Does anyone have any ideas on how to fix, without making it look unsightly?
I am concerned about possible Carbon Monoxide leaking when the fridge is operating.
